Question about Coby TF-TV1022 LCD TV
My tv does not power on - I think is the ad/dc adapter
We had a lightening storm. I think the AD/DC Adapter/battery charger is dead - no lights
The tv is a coby TF-TV1022 10"
  • 431 Answers
Hi I am Vortash If the set was struck then it may be beyond repair , if however you had a spike due to the mains lines being struck you may get away with a new charger and recharge the batteries .. But it may have had a serious electrical spike go through it from the mains also and again would be beyond economical repair get a free estimate from a local service dealer and if it is too extensively damaged maybe claim for it on your household insurance ... Regards Vortash
Posted on Jun 14, 2009
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Alba tv blowing the 12v dc adaptor
Check the adapter itself bow out, when it is plugged to Wall AC socket. Do not load it to TV, and check this. If it blows up, the fault is with the adapter itself. If it don't, the fault must be within the TV circuit.
Jun 18, 2013 | Televison & Video
Sony vaio not charging while charger plugged in
Seemingly your laptop dc jack is dead. How to confirm it? If you should wiggle your laptop charger on a position to let your laptop charge, it indicates your dc jack is loose. Either replace it or repair it. If your dc jack works well, please check your ac adapter. Maybe your charger is dead.
http://www.chargerbuy.com/laptop-ac-adapter/sony-ac-adapters.html
Oct 27, 2012 | Sony VAIO VGN-NS160D/W Notebook
Can you supply a replacement 13 V, ac/dc adapter (HP5230, HP 6414/16/24)?
Bernabeu, we do not supply anything at fixya except information. I will ad links to where you can purchase a power supply. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Power TM 6 6ft Long Cable AC ADAPTER Philips Norelco Satinelle Electric...
Amazon com UpBright AC Adapter Charger For Philips Satinelle Soft Epilator...
NEW AC Power Adapter Charger For Philips Satinelle Epilator HP6400 HP6401...
Results for Epilator philips charger
Jan 24, 2011 | Philips Satinelle HP6409 Epilator
The light goes on, it seems to start...then light goes off and then nothing. Optiarc DVD RW AD-7560A ATA Device HP Pavillion Vista
Remove the dc battery, and unplug the dc adapter.You will hold or press the power button for 40 seconds.Now you will get positive result,when you plug the adapter to your laptop and the Battery also.Almost 80% laptop can solve for this problem through the proceses.
Hope it help you.
Dec 31, 2010 | HP Computers & Internet
The battery will not charge if it runs down
HI there,
When a laptop/netbook will run on the A/C Adapter but the battery won't charge, there are only 3 things that can be wrong.
1. The battery is dead (replace the battery)
2. The A/C adapter's charging system is not functioning but the power function is. (replace the A/C adapter)
3. The DC power jack which is where the adapter plugs into the laptop is partially failing, providing power but no charging. (replace the DC jack)
Try to find a friend with an adapter/charger that fits your netbook and see what happens with that first. If that doesn't work, try to find someone whose Netbook takes the same battery and test if yours will charge in their laptop. After that, if your battery's not dead and you have a working charger, it's the DC jack and that costs about 80 to 100 to be replaced. They have to take apart the netbook, remove the jack and solder on a new one.
Good Luck
Marcus
Sep 14, 2010 | ASUS Eee PC 1000HE Netbook
My c500 presario won't charge and i think it's the charger. But when my battery went dead other times and i try to turn it on the lightning bolt indicator would always blink for a few secs. But now it just...
You probaly have a broken DC JACK on the motherboard. Therefore, regardless if you have a good power adapter. The power is not making a connetion to the battery because the DC JACK throught which the power flows is broken.
Try another adapter and remove the battery. If the computer is powered up using the new adapter then the old adapter is bad and the DC JACK is good. Replace the battery and if the batter charges, you can identify the old power adapter as the culprit. If the batter does not charge but the laptop powered on. Then both the battery and the charger is faulty-battery not holding charge.
Good luck
Sep 27, 2009 | HP Compaq Presario C500t Notebook
I need a replacement for my ac/dc adapter
I am listing one on ebay on 9/25
Sep 19, 2009 | Televison & Video
Replacement ad/dc power cord
you can get a replacement ac/dc power cord for durabrand portable dvd player model # PVD-707 here;
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Dec 11, 2008 | Durabrand PDV-705 Portable DVD Player
Toshiba laptop battery or AC/DC adapter
step 1.First remove the battery out
step 2.Try to plug in the AC/DC adapter and see any Power light or something on your machine. If you have power light on your machine that mean your adaptor is supplying electric.But still there're some adapter that don't really supply a good DC voltage
we need to further check.
step 3: incase no light nothing on your machine you need to use analog meter or digital meter to check that your adapter is giving out DC Volatage around 16-19V
Best of luck, takecare.
Apr 19, 2008 | Toshiba Satellite L25-S119 Notebook
Coby TF-TV1022 LCD TV Logo
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
