Question about RIM BlackBerry Pearl 8100
My blackberry is showing hourglass and white screen wtf
  • Don_Digi May 11, 2010
    Does the white screen have any details? Have you recently added any 3rd party apps?
    President:
  • RIM Master
  • 688 Answers
First, remove the battery from your Blackberry and put it back in a minute later. This will reboot your phone and probably fix you problem.
if it doesnt fix your problem. you have options, one would be to reload the software onto your blackerry with the desktop manager and that would be a fresh install of the software and almost surely take care of the problem.
usually this type of issue is caused during an update or some type of software change. but you can always fix it with a reinstall.
Go to Blackberry.com and you will be able to download desktop manager and you device software.
Warning: if you blackberry is unlocked, reinstalling the software will relock it and you will have to have it unlocked again, unless it was unlocked with multiloader mfi
Posted on Jun 14, 2009
  • 173 Answers
Thats strange. Usually after the hour glass it either turns on or doesn't and shuts off or just gives you an Error message after wards. In any case the 1st action is to reflash the phone to eliminate the software as being at fault. When the phone gets the white acreen, plug it into your computer and run blackberry desktop. Does it recognize the phone? Can you then get a backup of your phone? If so then do that and then proceed with Updating the software by selecting App Loader on the Blackberry Desktop (4.7 OR HIGHER). Please write me if you needed further instructions. Thank you
My bb screen is all white and I cannot turn it off as well. Please help
Hello
First of all what you need to do is to perform a reset on your BB by hitting ALT+RIGHT SHIFT+DEL your blackberry will reset itself. It will go black for about 2 to 4 seconds then you will see the famous blackberry hourglass. Be patient and in about 2 to 5 minutes your blackberry will reset.
ALT+RIGHT SHIFT+DEL can be used for continuous hourglass issues, JVM Error 200 "White Screen" to name a few.
If that does not work then you should perform a battery pull by just pulling out the battery out of the phone while it is on this is also a reset option.
Go to your service providers website, download the software from there, and then install it on your pc. Once done, delete the vendor.alx(xml file) file, open Desktop Manager (DM), connect the BlackBerry, and follow instructions
Apr 20, 2011 | Computers & Internet
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
The screen whites out n only way to get it back is take battery out n let it start back up
Hi there
Whenever your screen goes white again just hit the ALT+RIGHT SHIFT+DEL your blackberry will reset itself. It will go black for about 2 to 4 seconds then you will see the famous blackberry hourglass. Be patient and in about 2 to 5 minutes your blackberry will reset.
Try freeing up some space on your blackberry by deleting some unecessary files and do not run too many applications at once.
Oct 11, 2010 | RIM BlackBerry Curve 8310 Smartphone
Hi , i bought a curve 8520 3 weeks ago and it has been brill ,however last night the screen went white wiv the hourglass..i hav took the battery out for several hrs..and then replaced it...and my phone...
The BlackBerry has the feature on auto-start. When you insert the Battery, the device will automatically boot-up. It'll be showing an hour glass while loading the settings. But if it is longing for more than 10 minutes, there might be some error in the OS. It's better to contact a near-by authorised Service Center.
Regards
Vineeth K.
Aug 05, 2010 | RIM BlackBerry Curve 8520 Smartphone
Curve with white screen with hourglass and red light on
If the flipping hourglass stays for longer than 2 min our Blackberry may just need a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings.Download the Blackberry Desktop manager and run the application loader. Make sure you check to delete old applications in advanced tab. Carefully all you datat will be wiped.
Aug 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
Hourglass of death need help
have you tried downloading and reinstalling the handheld software? if not the phone probably needs to be replaced.
Aug 03, 2009 | Sprint BlackBerry 8703e Phone
My blackberry pearl keeps showing a hourglass
Try removing your Facebook app from the phone. Had the same issue and I stopped receiving emails. Once I removed the Facebook app from the phone - it rebooted and all my emails showed up.
Jan 31, 2009 | RIM BlackBerry Pearl 8100
T7100
same thing to me but not off ebay when i first bought my 7100t all it would do was show an hourglass but i never used it for a month then i charged it then it worked fine
Jul 22, 2008 | RIM BlackBerry 7100t
Blackberry 8100 screen wont work
check your display! i think display is problem in your mobile! IC fault in display!
Jul 10, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
584 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
