Question about Black Box ServSensor Jr. with 1x Temperature Sensor - environment monitoring dev
Reset factory default settings
Why won't the number 1,0 and space bar button work?
Have you tried a battery pull...... restart by removing the battery while your device is Powered On , try it and see if you're able to access your keyboard . you can try factory default to reset phone ...When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
All phone data will be deleted. Data on your SIM isn't deleted.
1. Find "Security Wipe"
  • Press the Menu key twice.
  • Scroll to Options and press the Navigation key.
  • Scroll to Security and press the Navigation key.
  • Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Cardand press the Navigation key.
  • When the box next to the menu item is ticked (V), the selected data will be deleted.
  • Highlight the field at the bottom of the display and key in blackberry
  • Scroll to Wipe and press the Navigation key to restore the factory default settings.
  • Follow the instructions on the display to set up your phone and prepare it for use.
May 13, 2014 | RIM Blackberry Curve 9320 Smartphone -...
Srw2024 factory reset
when you reset the switch it turns it back to the settings it had when it came out of the box. Try the default factory username, password and IP address
Nov 05, 2013 | Computers & Internet
Forgot lock code for LG Extravert , need to reset to factory default.
Steps to Reset Settings This will reset the phone to factory default settings.
  1. Unlock the touch screen by dragging Slide up to unlock up and touch the Menu Quick Key.
  2. Touch Settings.
  3. Touch Phone Settings.
  4. Touch Security.
  5. Enter the four-digit lock code. The default lock code is the last 4 digits of your phone number.
  6. Touch Reset Default.
  7. After reading the warning message, touch OK.
  8. Touch Revert.
for Steps to Restore Phone visit my Blog
http://pcgadgetdeni.blogspot.com/2013/02/factory-reset-lg-vn271-extravert-to.html
Feb 14, 2013 | LG Extravert MobiPhone - Black Verizon...
My scan & photo buttons are both lit up as is the on button. It won't turn on or off and the communication box in black. Can it be fixed?
Try to reset your printer to factory default settings. On the printer operator panel, press the Setup button -> Defaults -> Set Default -> Use Factory. You will be prompted to enter the date and time, etc. Then power cycle your printer. Remove the power adapter from the printer.
Wait at least 10 seconds before replugging the power adapter.
When your printer turns on, check if it's properly working now. If problem continues, please contact Lexmark technical support for additional assistance.
May 02, 2011 | Lexmark X4650 InkJet Printer
We have lost the password for Linksys srw2008mp switch and would like to reset it to factory defaults we cannot get into it to reset it.
To reset to factory Default settings you need to do the below steps
1. Look for the reset button. The reset button is a tiny black button on the back of the switch.
2. Power Off the switch.
3. Press the reset button (preferably with help of a ball point pen or a small head scew driver) keep the tiny black button pressed and do not release that.
4. Power On the switch and the sys LED will blink slowly and then rapidly. 5. Now release the black button
6. Wait for 5 minutes. The switch will boot up with factory default settings.
Best Regards
Nov 13, 2010 | Linksys SRW2008MP 8-Port Gigabit Ethernet...
How to reset factory defaults to CK31? How I can put the settings to access WPA2 in wireless network?
Restoring Default Settings
You can restore the CK31 to factory default settings from
Intermec Settings.
Note: Using the Restore Defaults option restores all parameters
including network settings. When you choose to restore defaults,
you erase the registry. As a result, you may lose network
communications.
To restore factory default settings
1 From Intermec Settings, select Device Settings > Restore
Defaults.
2 Select Restore Defaults and choose the Run App button. A
Run Application dialog box appears asking if you want to run
the restore defaults program.
www.portablesolutions.com
May 12, 2010 | Intermec CK31 Portable Terminal
Voip
Hi
Warning This will RESET to FACTORY DEFAULT
There should be reset hole with a button in it if you press this and hold it in. count to ten then release, this will reset it to factory default setting.
If you are not wanting factory reset you will have to login to the linksys the default IP is 192.168.1.1 login name admin password admin.. that is you havent change it. and from there you can find your settings and change them..
Good Luck
Jan 28, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Can't set printing preferences to "print in black and white"
try to reset the preferences to factory defaults. Open print preferences > Click on Profiles on the top right > click on factory defaults....
It should solve the issue
Aug 04, 2008 | Dell 924 All-in-One InkJet Printer
SANYO DS32920
Did the black box disappear or disappear and then re-appear?
If yes> TV station is broadcasting a caption text signal without any textual data. > Press the RESET key twice.(Customized settings will be reset to factory defaults).
To retain customized settings just turn captioning OFF.
1. Press the CAPTION key on the remote control.
2. Use the 0 key to select OFF, cap1,cap2,Text1,Text2,or Quickcap.
Feb 05, 2008 | Televison & Video
Hardware reset
Double-clicking the System icon in the Control Panel opens the System Info dialog box.You can use this dialog box to allocate thin client memory and reset the thin client to factory defaults.
The General tab contains a check box that allows you to reset the thin client to factory defaults (the check box is active for administrators only).
You can reset the thin client to factory default settings by selecting the *Reset the terminal to factory-default property settings* check box (the System Settings Change message displays and you can confirm and follow the instructions provided to reset the thin client).
Mar 01, 2007 | WYSE Winterm S30 Network Terminal
Black Box ServSensor Jr. with 1x Temperature Sensor - environment monitoring dev Logo
162 people viewed this question
Top Black Box Computers & Internet Experts
Johnny Massengill
Johnny Massengill
Glyn
Are you a Black Box Computer and Internet Expert? Answer questions, earn points and help others
