Question about Sharp Korean Electronic Dictionary Rd-cr3100
Keypad does not work, and the dictionary makes the sound of pressing keys all the time.
I bought it 14 months ago, and I have seldom used it.
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
How can i set the date n time in Panasonic TX-TGA542AL cordless phone?
This is how to set date and time on panasonic KX-TGA542AL.
Press the "Menu" key.
Use the up and down arrow keys to select "Date and time." Press "OK."
Enter the month, date and year using two digits for each on the keypad.
Enter the hour and minute in 12-hour clock format using the keypad.
Press the asterisk (*) key to toggle between "AM" and "PM."
Press "OK" and then "OFF."
Regards
Jul 12, 2011 | Panasonic KX-TGA560 Cordless Expansion...
Keys are not working correctly on key pad
It may be that you have NumLock on - these function represents a KeyPad on the Letter Keys - usually the U,I,O,P,[,J,K,L,;,M kEYS are replaced with numbers - to switch on/off you should have a key with Number Lock on it possibly abbreviated to NumLck or NumLK etc - activate that Key - may need to use in combination with the FN key as well to toggle the Number Lock on and off - also often a light appears to show its ON
Apr 13, 2010 | Lenovo IdeaPad S10-1208U Netbook
Samsung SGH a727 forgot password to turn on phone
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (10)
  4. Highlight, using the navigation keys, any of the following:
    • All: Phone, Display, Profile and Alarm settings will be returned to default values
    • Phone Settings: only phone settings will be returned to default values
    • Display Settings: only display settings will be returned to default values
    • Profiles: only profile settings will be returned to default values
    • Alarms: only alarm settings will be returned to default values
  5. Press the center navigation key to check the box(es) of reset settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is “00000000”
  8. Press the left soft key for Confirm
  9. Enter the password again to confirm, using the keypad
  10. Press the left soft key for Confirm
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Sep 25, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Keypad Chaimberlain 32B2171-1 does not work any more
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad
You're kind of vague on your problem. If it's the smaller blue numbers for the calculator, you will need to use the function (fn) key. Hold the fn key and press the key the reads number lock (num lock), this should return the keys back to letters. You can find more info on the fn key and numbers lock under help in the start menu. If this isn't your problem, be more specific, and I'll be more than happy to help.
Jun 29, 2008 | IBM ThinkPad T42 Notebook
Keypad problem
hi my n73 keypad is nt working' all keys nt work
Jun 02, 2008 | Nokia N73 Cellular Phone
Errors list : 46, 50, A1
CP315C/310CN/120C/115C/117C/110C
(1) Press the (1) Press the
Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
enter the maintenance mode. enter the maintenance mode.
(2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
Set keys.* Set keys .*
(*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the display the numerical code to be entered and then press the
Set key. Set key. Repeat this operation for each Repeat this operation for each
numerical code.) numerical code.)
(3) Press the (3) Press the
Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
(4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
(5) Press the (5) Press the
Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
(6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
5 key nvigation key works on and off
hi it could be that you have dirt on your keypad or that you need a new keypad if it is dirt then it will either cost you a fiver to clean it or you can do it your self just look on google and you should find steps on how to do this. hope this helps
Feb 20, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Stuck on scan mode
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
Jan 04, 2008 | Radio Shack Pro-97 Handheld Scanner
Sharp Korean Electronic Dictionary Rd-cr3100 Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
