Question about Brother InnovIs 4000D Computerized Sewing Machine
Bobbin thread wont form a stitch
The bobbin thread gets caught and pulled up by the needle, but then doesn't connect with upper thread to form a stitch - with the result being only upper thread that tangles under the work. Please help!
    Champion:
    Habit-Forming:
  • 201 Answers
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Posted on Mar 20, 2014
2 Suggested Answers
  • 1788 Answers
SOURCE: When i start to sew
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Posted on Sep 25, 2010
Wont sew thread keeps coming out of needle
you have to hold the loose end for a couple stitches when starting off
Dec 16, 2015 | Sewing Machines
Singer bobbin thread not being caught
try rethreading the machine top & bobbin
change the needle--flat side to the back of the machine, make sure the needle is the right one for the fabric being sewed
clean under the needle plate & in the bobbin area for lint or theads
May 10, 2012 | Singer 3323S Sewing Machine
SINGER MODEL 3130 WILL NOT STITCH CORRECTLY
Have you tried cleaning and oiling your sewing machine.Sometimes old thread gets caught up under the pressure foot near bobbin if not cleaned out the bottom teeth that pull material through will not move bobbin thread up to be caught by needle thread. P.S. Are you sure your using the right needle for the machine? To short of a needle will also cause this problem
Apr 10, 2012 | Sewing Machines
Upper thread get s caught under the needle plate when free motion quilting. Forms a loop and the fabric can't move.
change the needle
clean under the needle plate & in the bobbin area for loose threads & lint
rethread the machine top & bobbin
Mar 16, 2012 | Husqvarna Sewing Machines
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
Good day!
Jun 07, 2011 | Brother CS-6000
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
My problem is between the needle and the bobbin. The tread continues to get caught just below the needle- inside of the machine. The bobbin seems to be lifting up and thread gets caught beneath the needle
Hi. So is this a horizontal hook? Where is the thread getting caught beneath the needle? Maybe on the hook? Check your upper threading to make sure the thread passes through the thread take-up lever. If thread is not through the lever, it wont get pulled up , which can lead to multiple thread loops getting caught on the hook, not pulling off after the rotation.
Apr 15, 2011 | White Sewing 2037 Mechanical Sewing...
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
Brother InnovIs 4000D Computerized Sewing Machine Logo
99 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
