Question about Konica Minolta Konica 7020 7022 7025 7030 7035 7130 7135 Genuine Drum 950-253 950253
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
    Habit-Forming:
  • 64 Answers
Try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Posted on Mar 21, 2016
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
How i can adjust the position of the Touch Panel display konica 7020
Go to Touch Panel adjustment you will see "+" to the 4 corner of the touch panel use pointed object point it MILD on the center of the 4 "+" . Off / On
Oct 06, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
F-28-1 curently appears on my screen
F 28-01 High voltage power supply abnormality.
Ihe charging ON/OFF operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging.If there is a paper in copying process when this jam occurs,the machine stops after completion of copied paper ejection.Verify the charge wire,change and the holders.Check the high voltage unit.
F - 28 -02 Toner transfer wire malfunction
F - 28 -03 Toner separation wire.malfunction
Feb 11, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Image blurred
take it back to the store where u bought it and report the problem
May 08, 2012 | Konica Minolta Magicolor 5450 Printer
Unclear copies
yes, u have 3 clean comb electrode, scorotron grid and corona channel of corona unit....
Feb 23, 2009 | Konica Minolta bizhub C250 All-In-One...
KONICA 7020 - Blank copy
I have never heard of a developer moving backwards!!!!!!!!!!!!!!!!???
the motor that runs it, the .... there is too much involved to mention. A developper moving backwards will spill so much toner in the machine anyway.
If you get a copy and then it goes blank, that tells me you have a problem with the SEPERATION UNIT, it may be shorting out causing the paper to rise against the drum giving you blank copies.
A blurr copy tells me there is a problem with the Scanner/Optics area. maybe the rails that the scanner run on are too dry or has a problem, the optics(mirrors) may be misaligned.
Not sure what you mean by (hanging) ??
Jul 31, 2008 | Office Equipment & Supplies
Blur copys
The 1015 / 1120 were prone to the lens drive gear cracking, and not holding to the shaft.
Sometimes you will get a lens initializing error, sometimes you wont.
But this is most likely the problem.
Feb 01, 2008 | Konica 7410 Laser Printer
Misaligned copies
Please be more specific in the problem:
Are they crooked on the glass, or through the RADF?
Jan 09, 2008 | Office Equipment & Supplies
Konica Minolta Konica 7020 7022 7025 7030 7035 7130 7135 Genuine Drum 950-253 950253 Logo
19 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
