Yamaha tsx shuts down
I have a yamaha tsx-120 and sometimes it shuts down. I mean even the led display goes off. This is not good specially when it happens during the night because I use it as an alarm clock..
  • Joo Lopes
    Joo Lopes Mar 24, 2014
    Hi, I don't have any iPod or iPhone in the device. Also, it's not that the music just stops playing, all the system shuts off. it makes a mechanical click noise, like the one of an amplifier going into protection. a friend suggested it might be a faulty condenser
  • 18 Answers
SOURCE: Theft Alarm goes off every 60 seconds
In order to disarm the alarm system, you need a tech 2 computer (usually Saab indy repair shops or Saab dealers only will have this very expensive computer and the flash cards needed) in order to change the programming in the TWICE theft alarm computer so the vehicle thinks it is not equipped with an alarm system. Two other more expensive options are replacing the entire module, or cutting the module open and replacing the internal batteries.
Justin Duthie
Strictly Saab
Melbourne, FL
Posted on Sep 15, 2008
SOURCE: alarm clock came with chinese instructions manual,I need English
1.slide "return to time"to off, slide "backlight" to on
2.each press of the mode button goes through "time, temperature, year, month(M looks like an H) and day(D), alarm1, "2, "3, , Birthday Celebration, countdown/stopwatch"
3. when on the category u want to change, press and hold set button for 3 secs, adjust with up and down and the hit set when done with each adjustment
Buttons on the bottom in order from left to right are(buttons on the top part of the clock bottom when turned on its side) mode, set, up, down
Posted on Jan 23, 2009
SOURCE: the alarm clock on the nokia 1661 goes off before
Apparently there's a bug in the auto time update function - turn off auto time update and the alarm will work correctly.
Posted on Jul 30, 2009
SOURCE: Cannot turn off the alarm on my RCA clock radio rp5430
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
Posted on Aug 05, 2009
Am here
  • 36 Answers
SOURCE: I have a Yamaha TSX-130. Won't play CD when alarm set.
hi go to the alarm option in your system and diable the repeat option and enable play all it will work thank u
Posted on Aug 24, 2009
Yamaha tsx 120. When ipod is fully charged when playing music,the yamaha unit goes into pause mode and music stops! I've checked its not in sleep mode too!
See one of my other posts re a TSX130 issue that turned out to be some corruption of the iphone. when the OS was changed it cured it.
Try another ipod first to prove/disprove this
When my iphone 3gs was fully charged it used to turn the TSX on playing...OS upgrade cured this too
May be the same issue you have?
AW
Aug 15, 2010 | Yamaha TSX-120BL Desktop Audio System ...
HP Pavilion dv6225us won't boot (power not the issue)
Check http://www.fixya.com/support/t3440299-presario_f500_laptop_problem
Nov 16, 2009 | HP Pavilion dv6225us Entertainment -...
Aug 24, 2009 | Yamaha TSX-130BL Desktop Audio System ...
Dell Dimension 9200 keeps shutting down and won't start up
the key issue on the uncommanded shutdown is the POWER LED. If upon shutdown, the power LED Flashes AMBER, then the power supply is suspect.
If no flashing amber indication, then the next think I check is the heatsink (Processor overheating) remove, clean and apply arctic Silver heat transfer paste, see if the issuje goes away
Last but not least if the system is failing to boot, and displays a 3 4 diag LED code, then you may have a RAM module that is bad or may just need reseating. Running diags off of the Rersoujrce CD is something to look at too
Mar 28, 2009 | Dell Dimension 9200 PC Desktop
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Ignition Module Troubleshooting White Rodgers 50A52-120
This is OEM special part you need to contact Goodman Manufacturing. Website Phone 866.304.0137
Oct 02, 2008 | Heating & Cooling
2004 acura tsx 6cd changer jammed
I CAN HELP YOU GET THE CODE OFF YOUR RADIO NEED TO REMOVE RADIO AND AND WRITE DOWN SER# AND EMAIL ME BACK AND I CAN HAVE YOU A NUMBER YU TYPE INTO RADIO AND IT WILL TURN ON LET ME KNOW
Jun 30, 2008 | Car Audio & Video
Shows "LE" in display.
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
This yamaha receiver goes on for 1 second then off.
This is the protection circuitry. Mine is doing the same thing. I'm trying to get a schematic for it right now ;-)
Jon
Oct 23, 2007 | Yamaha RX-V2092
82 people viewed this question
 Grubhead
Grubhead
