Question about LG Heating & Cooling
My power indicationlight is blinking thus the ac is not cooling
After about 30secs where power is restore the ac will cool then suddenly it will cut off even at this the power still blinks
    Problem Solver:
  • 14 Answers
Could be some of the overload protection: low or high pressure,
Check for a clogged filter or dirity condensor or evaporator, condensor or evaporator fans not running.
Posted on Mar 20, 2014
  • dave2001auto Mar 20, 2014
    Could be low or high pressure overload protection. Check for dirty filter, dirty condensor or evaporator, fans not working for the condesnor or evaporator. Other problems get more costly to fix.
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
  • 33 Answers
SOURCE: carrier central airconditioning heat unit - breaker trips when cooling turned on
well mineswas a blowen compressor
Posted on Jul 19, 2008
SOURCE: Cool/AC light is blinking
Try cleaning the filters & coils good with a shop vac, or a scrub brush.
Posted on Aug 04, 2008
SOURCE: a continous blinking operation light and no indicator light
HAS THE UNIT EVER WORKED?
Posted on Oct 09, 2008
SOURCE: Carrier Air V roof mount with remote. Does not
We have the same problem as of this morning . . . don't have the fix yet, but have located (2) manuals that I will enclose the links for. The 5 flashing green lights is mentioned in the "Service Manual" in Section 2 "Troubleshooting" with 5 possible remedies. Manual http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298.pdf and Parts List http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298PL.pdf We're under warranty so will take our RV in ASAP
Posted on Sep 05, 2009
The upstairs ac display is blinking cool on, but not cooling the house. The outside fan is running. please help. The downstairs display and unit working properly
Normally Honeywell will "blink" COOL ON when its in a timed delay, usually 3-5 mins. And then COOL ON will stay on without blinking. If you turn tstat off then wait about 5 mins, then turn to cool, watch for the blinking, then wait 5 more. If it doesn't turn on, check/change the batteries if it has them. Try turning the AUTO/ON to the on position to bring on the fan only. It won't cool doing this but it helps in homeowner troubleshooting.
Aug 05, 2015 | Honeywell Heating & Cooling
In my 2000 ford expedition my temp gauge keep jumping back and fourth when I run my ac. Y?
Running the AC does increase load on the engine, and thus heating, so if gauge changes gradually, this is because the compressor kicks in for a while, then kicks out. If cooling system is not working properly, small additional load could cause temp change. Other possibility is compressor going bad and causing excess drag.
If change is sudden, loose wire somewhere near compressor could be the issue.
Jun 08, 2015 | 2000 Ford Expedition
AC power light blinks but not starts
The outside unit has a problem. Have it tested.
May 05, 2017 | Hitachi Heating & Cooling
My ac compressor broke. I had a new compressor and expansion valve replaced. It cools a little on high but not enough. Any ideas on the problem?
You need to check the refrigerant pressures (high & low) and learned the reason for the cooling problem-the gauges are the only way you could ever know what is going one with the AC-low pressures (both sides), low refrigerant-high pressure, over charged and not allowing the AC to cool.
Jul 23, 2010 | 2006 Chevrolet Malibu
Fan Runs, AC Doesnt, Blinks 5 times
Need to look around and should have an error code and give more detail of what the problem is. If you post that i can maybe help you more. I need to know......
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Sony KDF-46E2000 - Screen Goes Blank
The lamp can cause the picture to cycle without spitting out a lamp error. I'd replace the lamp and clean out the dust/dirt from fans, etc to hopefully resolve your issues.
Dec 06, 2008 | Televison & Video
Carrier thermostat
I hate to say it but Ive had trouble with Carrier's Tstats doing similar improper things. Unfortunatly the only repair is going to be replacement of the whole tstat. I recommend Honeywell's FocusPRO or VisionPRO tstat. Ive yet to have one fail and they have a 5yr warranty if they ever do.
Nov 25, 2007 | Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
