TV reception band no longer works
It seems the TV reception band portion of the Zenith Z212B Radio no longer works with the digital transition. Static only, any fix?
  • 161 Answers
All analogue signals going out means EVERY analogue signal is gone in the TV band. these are now apparently assigned to emergency services in some states.
Posted on Jun 14, 2009
How do I keep it on Digital? When I try and turn the channel, it goes to Video 1. It says Digital channel signal strength is low.
How to fix digital TV reception problems - Simplify Digital
www.simplifydigital.co.uk > Guides
SimplifydigitalJul 11, 2014 - This handy guide will help you fix simple digital TV reception issues with Freeview, satellite and cable TV set top boxes. ... If you're suffering from poor digital TV signal, it may be possible to fix reception issues quickly, at home. ... We're here to run you through how to fix TV ...
Digital television transition in the United States - Wikipedia ...
Dec 26, 2015 | Televison & Video
AM and Fm radio reception poor. Suspect bad ground since radio and antenna have both been changed. The static sound while on AM increases when I press the accelerator. How do I isolate an intermitt
static sound on AM band can be reduced by the adding of a capacitor to the alternator terminal. Check the coax cable especially the outside braid is connected to the body for earth
Jan 07, 2014 | 2002 Toyota Highlander
How to get TV audio on the FR300 radio?
Your TV band radio won't work anymore now that the US has switched to digital broadcasting. The frequencies now in use aren't the same now, so the radio can't receive them. Plus, the radio doesn't have the circuitry to decode the digital sound even if it could pick up the broadcasts.
Sad to say, you have a radio that now picks up only AM/FM/weather and static. Also, as far as I know, nobody is yet marketing a radio for TV sound with digital capability. All you can do during a power outage is use a new TV with battery capability and digital tuning.
Mar 02, 2010 | Eton FR300 AM/FM/Weather/TV Radio
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Unable to get tv stations on my Sony Sports Walkman
yes that is correct it in most cases the small portable tvs only recieved analog signal now that the signals are all digital you have no way of watching tv on your walkman anymore
Jun 30, 2009 | Sony Sports Walkman Digital AM/FM Radio...
I have a Sony Walkman TV/Weather/FM/AM SRF-M37V. I need to know
The radio won't get TV sound anymore after the switch. And no, nobody is selling a digital receiver for the TV sound yet. All this radio is good for now is regular broadcasting and the weather band.
Jun 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
No AM radio reception in my 2002 Audi A4
do you get any stations, even weak stations on the AM band?  If not you have a bad radio and need replacement.  Try having someone hold the antenna as you scan the AM band.
Apr 01, 2009 | 2002 Audi A4
FM RADIO Reception
No, it should work, although it will depend on how good your reception is. This depends on how strong the signal is where you are trying to receive. If you have tried scanning for channels and all you receive is static, it's possible your tuner is bad. Have you tried to tune it to a known good station manusally?
Jan 20, 2009 | SanDisk Sansa e250 MP3 Player
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
AM reception/AM power problems
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Oct 08, 2007 | RCA RP7887 High-Performance Super Radio
134 people viewed this question
 Grubhead
Grubhead
