Question about Garden
I have a Hitachi EX30 ur-2 and the system light stays on I think the sensors on the side shift on the arm need recalibrating as we had them diconnected what do I do?
It would be good to get a technical book for this machine
5 Suggested Answers
  • 70 Answers
SOURCE: dregs light stays on (even when emptied!) - can't use machine
the various lights are controlled by either magnets that hit various sensors or microswitches.
the dreg light i'm pretty sure is a microswitch.
Its pretty common for them to go out, they're standard in almost all super automatic machines.
that particular switch is a pain in the **** to get to. You can order them direct from saeco, but if you can, it may be easier to send it out.
There should be a microswitch for the grind box, for the drip tray, for the water tank, and there should be one if i remember right for the grinder.
Its different for each model.
Hope this helps.
Posted on May 25, 2008
Cogz
  • 1326 Answers
SOURCE: CANON IR6000 COPIER
Is this a new problem??? Did you replace a major PCB? You may have to reinstall the door spec's back in from the pannel on the front door. Also, is the display sceen cracked? If so you need to replace the display screen... There is not a recaibation screen that I know of....
Posted on Sep 21, 2008
  • 1608 Answers
SOURCE: all fluid levels are full, all guages good, engine light stays on
The check engine light is on because the computer has detected a fault in the system.It could be a sensor,wiring or bad connection.You have to get the codes read to find out what could be causing the problem.Most parts stores will do this for no fee at all.Hope this helps.Good luck.
Posted on Apr 04, 2010
emissionwiz
  • 76132 Answers
SOURCE: i have a 2000 mazda m i keep on getting code p1522 and o2 sensor bank 1 sensor 2 i put a new sensor still light comes on i switched sensors from bank 2 senwsor 2 too bank `1 sensor 2 light stays off
P1522 is not an O2 code in any Mazda model. Please go to this LINK and read about it.
Posted on Apr 07, 2013
The tv has red stripes on one side, and the red color phase shift
could be a mirror not lined up properly and needs recalibrating , some tvs have this option in settings
Nov 05, 2013 | Hitachi 57F500 57" Rear Projection...
92 dodge ram 150 not shifting
Two things happen on the Dodge's. 1. the rear O2 sensor shorts out and meses things up. 2. the Inner seal on the Direct drum (3rd) shrinks and causes a delayed up shift.
Aug 05, 2008 | 1996 Dodge Ram 1500 Club Cab
Vista-20p/ps series. when set for ARMED AWAY and after the delay period, the system become ARMED STAY. why is it?
If you arm and do not open the door programed as an entry/exit the system will still think you are inside. So it will only arm your perimeter and not the interior motions. Be prepared for your motions, if any, to set off your alarm if you arm, open door then close it and stay inside.
Sep 18, 2013 | Honeywell Ademco Vista 20p And 6160 Keypad...
My 05 taurus hesitates at cruising i am thinking fueling problem
2005 Ford Taurus maybe needind a recalibration of the ECM.For lack of power at highway speed,Misfire at load?low RPM also,The operation of a fuel pressure sensor is to limit voltage to the fuel pump when certain amount of fuel is not needed,and increase voltage when fuel is needed.If anything you need a recalibration of the ECM.
Aug 11, 2012 | 2004 Ford Taurus
Why does my traction off light come on?
You either have a problem with your engine control system, the traction control system, or you are not in the correct gear. See the explaination below. This is from the 2000 Chevrolet Cavalier Owner's Manual.
TRAC-OFF LIGHT
... If you turn the system off by moving the shift lever
to FIRST (1) or SECOND (2), the warning light will
come on and stay on. To turn the system back on,
move the shift lever back to a position other than
FIRST (1) or SECOND (2). The warning light
should go off. (See "Enhanced Traction System"
in the Index for more information.)
 The warning light will come on when you set your
parking brake with the engine running, and it will
stay on if your parking brake doesn't release fully.
If the transaxle shift lever is in any position other
than FIRST (1) or SECOND (2) and the warning
light stays on after your parking brake is fully
released, it means there's a problem with the system.
 If the traction control system is affected by an
engine-related problem, the system will turn off
and the warning light will come on.
If the Enhanced Traction System warning light comes
on and stays on for an extended period of time when the
transaxle shift lever is in any position other than FIRST
(1) or SECOND (2) your vehicle needs service.
Aug 08, 2011 | 2000 Chevrolet Cavalier
CAN'T FIND WHERE TO REPLACE THE TRANSMISSION RANGE SENSOR ON 97 PONTIAC BONNEVILLE
you may need to remove the air box to able to see the transmission range sensor . with air box removed look for the shift cable and where it attaches to the transmisson shift arm . the range sensor should be right under the the shift arm and where the cable attches. It should have a 15 mm bolt on the arm and 2 13mm bolts holding down the sensor . the sensor is adjustable so try and make sure you put it back in the same position
Mar 04, 2011 | Pontiac Bonneville Cars & Trucks
How do I turn traction control on? Light on dash says "traction off" all the time.
The Enhanced Traction System warning light may come on for the following reasons:
If you turn the system off by shifting to SECOND (2) or FIRST (1), the warning light will come on and stay on. To turn the system back on,shift to THIRD (3) or AUTOMATIC OVERDRIVE
If the traction control system is affected by an engine-related problem, the system will turn off and the warning light will come on.
If the Enhanced Traction System warning lightmcomes on and stays on for an extended period of time when the system is turned on, your vehicle needs service. Adjust your driving accordingly..
Oct 17, 2009 | 1993 Buick Park Avenue
Airbag light goes off when passanger seat in use, & on when not
even with exchanging the sensor the calibration could be off. without pulling codes from the airbag system it would be hard to guess for sure but id say you need to have the dealership do a recalibration on the seat
Jan 29, 2009 | 2006 Dodge Durango
20080 sequoia platinum edition with load leveling issue
I think that you need a recalibration of the ride height sensors. Unfortunatly, this can only be done with a tool that the Toyota dealership has in the shop. I just did a Landcruiser with the same suspension, and it took me a while, could NOT get it right, I ended up having to replace one of the height sensors, but there were NO DTC codes in the suspension ECU. You either need a recalibration, or a sensor replacement, followed by a recalibration. I know this may not help you "do it yourself", but, this is what you need. A FixYa rating would be greatly appreciated. Hope I helped you out. Sorry about the sweating in TX. Nice here in PA.
Nov 06, 2008 | 2007 Toyota Sequoia
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
