Question about Samsung ProXpress M3320ND Laser Printer SL-M3320ND
Reset IP Unable to login
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
Can't find IP address 192.168.1.2
Your IP address 192.168.1.2 is a Local IP address. Local(Computer) IP address ranges from 10.0.0.0 to 10.255.255.255, 172.16.0.0 to 172.31.255.255, 192.168.0.0 to 192.168.255.255. Normally you can login the Local IP address within a single building (or) campus using LAN. If you need to access around the world, it should be a Public(Network) IP address. To check your Network IP address, visit IP-details.com .
Apr 16, 2013 | Zyxel Wap3205 Wireless N Access Point -...
Unable to access a fresh Audio codes box via http using default IP address.
What IP address are you pointing at? 10.1.10.10? 192.168.0.1? try with 10.1.10.10 and worst case scenario install wireshark on your PC and take a trace when connected directly to MP and power it on, there you will see some bootp messages (IP address 0.0.0.0) and after that you will see messages from MP announcing its IP address. If device is brand new you should login fine using Admin / Admin. Beware that some internet explorers do not allow login even with right user/password, try with a couple of them.
Aug 22, 2011 | AudioCodes MediaPack MP-114 FXS and FXO...
Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw] Receiving response... [FAILED] *** ...
sometimes YM is very busy for connecting people..that is why you are unable to connect but try reconnecting again...it works
be sure your password and username is correct and your internet connection is stable...
Jun 27, 2011 | Yahoo Messenger
Trying to connect to wireless modem, i am within range of the modem. but i am not getting any bars on my DSi connection meter. i have reset modem and security settings, but still unable t get connection
it's possible that the option BROADCAST is off. You would need to login to your routers IP address, go to Wireless Settings and enable SSID broadcast.
Feb 05, 2011 | Computers & Internet
I don't know why I am unable to get to login page help?
Where you normally type in the URL for a web site in your browser, instead simply type in the correct IP address for your "login page" for your router. For Linksys/Cisco, the default IP (version 4) address
is 168.192.1.1, but other routers use 168.192.0.0
Jan 02, 2011 | Computers & Internet
I am unable to login and the reset does not work
Bro you can reset your configurations bro in order to go back to the default setting of your router. default ip address: (http://192.168.0.1), user name: (admin), password: (default password). follow the image shown bellow. 6f8fc35.jpg
May 15, 2010 | Computers & Internet
I want to log in to my routers ip address
Connect your router to computer with ethernet lan cable.
Then you can access with below link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
If you are unable to login with above ip then you need to reset router.
For that press RESET button for 10 seconds it is in back side of router.Hold it for 10 seconds thenj all settings defaults.
Then try with above ip .
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 22, 2009 | NetGear WGR614 Wireless Router
Voice mail password reset without current number mitel 5207 ip ph
What voicemail do you have? Login to admin mailbox or login to phone system if you have Embedded voicemail.
Dec 11, 2009 | Mitel 5207 IP Phone
Samsung ProXpress M3320ND Laser Printer SL-M3320ND Logo
74 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
