I have a Hisense TV with original remote working fine until recently. The remote lights up and is obviously on, however it is not controlling the tv at all anymore, no idea why. Any ideas on how to fi
Not a smart tv, remote number is EN-31611a
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. Ome among its posts have details about it. Surf the site in "Mosaic" view. It will make surf easier.
Posted on Mar 20, 2014
SOURCE: Proline tv remote control code.
try 0067 0568 0655 0664 0321 0102 0651 1406
good luck
Posted on Jan 03, 2008
IrishDruid
  • 2712 Answers
SOURCE: hisense remote does not work with hisense tv
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • 374 Answers
SOURCE: 118575 remote stopped working
The receiver more than likely received a software update or reset itself and reset the codes to the receiver and tv. We will need to set the remote address again and run a power scan to control the tv. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. Now we need to do a power scan - press and hold the upper left TV button until all buttons across the top light up and release. Press the red TV button and release, The TV button should be lit constantly. Now press the channel up button slowly until the TV turns off. Once it does press the channel down once and then cannel up to see if the TV turns back on. If it does press the pound sign. Now press the record button and you are back in business. If you have further issues let me know. Thanks for using Fix Ya.
Posted on Apr 10, 2009
SOURCE: oneforall remote wont work with my dynex tv!!
I used 0463 for my 19 inch DYNEX LCD TV. It's the code for Emerson & Admiral. :)
Posted on Jun 22, 2010
CWRobinson
  • 119 Answers
SOURCE: I have a Hisense TV,
Hello tacey55 and welcome to FixYa. I have compiled a list of your Hisense television codes below.
hisense LHDN32V66AUS 32 "...Hello Four digit universal remote code for Hisnse TV are:- 0073 0182 0216 Code Entry Press and hold the SETUP button until the red indicator stays on, then release the">0073 0182 0216
If your remote only accepts three digit codes just remove the first zero off of the codes I provided. Example 0073=073.
I hope you found this helpful tacey55 and thank you for visiting FixYa.
Posted on Apr 26, 2011
Hello I have a 50h5c Hisense tv ,well problem is my son had the control he was biting it and tv tuened off the red light is on but I press on button on control and tv but wont turn on.
The quickest way to fix this will be buy a universal remote or the original remote from amazon or ebay. All you will need is the make and model number of the tv for the original remote.
Jun 12, 2017 | Hisense Televison & Video
Hisense tv
so whats the remote you have there?
Oct 23, 2008 | Hisense TA42P40M 42 in. Plasma Television
Hisense Remote
Use the "auto search" method to program the remote and it found a code on its own and get your tv unlocked. Try using 0478 code
Oct 17, 2008 | Hisense TC24FS2H TV
Hisense LCD remote code
Turn on the TV and point the remote at the TV,press and hold TV and OK at the same time for 2 seconds,all the buttons on the remote will light up,for 2 seconds,after that only the numbers 1-12 will remain lit. Press the CH/PG button to send a series of off commands to your TV,repeat until your TV turns off,press the TV button to save the code and exit,all the buttons will blink 3 times to confirm code. hope this helps..
Mar 27, 2010 | Televison & Video
I need the code to program a rca systemlink3 remote for a hisense tv
0748...but if its like mine it wont work. these HiSense remotes are JUNK!!!
Aug 17, 2009 | Televison & Video
Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
Sep 16, 2008 | Hisense LCD1504 15 in. Television
Hisense remote does not work with hisense tv
Hope that helps!
IrishDruid
Apr 29, 2008 | Televison & Video
Remote does not work for TV
I assume you had new batteries in the original remote and that the Universal remote was programmed correctly for your TV.
Are there any lights on the old remote that flash when you press a button? If so, does it light?
If the TV doesn't respond to a remote, and the remote is verified to be in working order, then the infrared sensor in the TV is defective amd needs replaced.
Good Luck,
- Jim
Jan 27, 2008 | Sansui TVM1916 19" TV
Televison & Video Logo
562 people viewed this question
Top Televison & Video Experts
Electro Med Services...
