Question about iPhone Apps
Compare and contrast Quasars to Pulsars
What are the difference between contrast Quasars and Pulars
Fine tuning the contrast & darkness
Right click the display go to properties and on the advance tab try reducing or advancing the refresh rate to see if there is a difference. If negative restore the rate to the original setting. Good Luck. Ed Pinero
May 29, 2014 | Envision Peripherals 19" envision g917w1...
What is the correct picture setting for a vizio smart tv model E322AR?
Contrast = 60 to 80%.
Brightness = 40 to 55%
Color = according to personal viewing taste.
Sharpness = 15 to 20%
The best way to tune to a perfect picture is, set the color to Zero first. Without any colour, increase the contrast to at about 65%. Adjust the brightness to get a perfect picture in B/W. Then increase the color, according to your viewing taste. Compare the skin tone of a person. That's all.
Oct 07, 2013 | Vizio Televison & Video
Internet speed slow
You can do multiple things to improve the speed of your computer's internet.
  • Try using a different browser, such as Google Chrome, Chromium, or Firefox.
  • Upgrade your internet speeds with your internet service provider (Time Warner cable, road runner, or the like)
  • Buy and install a better processor.
  • Buy and install more/better RAM.
  • Uninstall programs you rarely or never use.
  • Run a registry cleaner.
Jul 17, 2011 | Computers & Internet
My bike has a very low pick up compared to other bikes.acceleration of the bike is not at all smooth.sound of the engine is also different from other pulsars.i replaced the clutch plates,but there is no...
With respect to your discription of the problem , it would be worth to check the timing of the bike's engine. It could be ******!
Hope this helps!
Aug 08, 2009 | 2006 Bajaj Pulsar 150
service your carb, change the plug and airfilter and check you timing and compression.These are simple things that will improve your performance ...but changing your clutch plates?Is your clutch slipping?
Aug 08, 2009 | 2005 Bajaj Pulsar 150
I have a Nikon D200 camera. It's now 2 years old and I'm having difficulty with the auto focus. The camera focuses but it comes in and out and I have to depress the shutter several times to get it clear....
the auto focus works on the basis of contrast. If you aim your chosen auto focus square at an item that fills that square with only one color or shade of color light a blank wall or a solid blue sky the camera can't focus because it is trying to compare the contrast in order to focus the camera. try to make sure that you choose an item with contrast to aim your auto focus square on like someones eye and part of their cheek so the camera can see somre contrast to evaluate then focus. Obviously you depress your shutter half way to activate the auto focus let the camera do its thing keeping the shutter half way depressed move your field of vision to where you want it then fully depress the shutter to take the picture. the camera relys on seeing some contrast within your autofocus square in order to auto focus
Jan 14, 2009 | Nikon D200 Body Only Digital Camera
Vibration and knocking sound from engine
Many p180's facing tiz problem (old ug 1 or 2) . Change ur clutch plate and change spark plug. Clean carburater. Gearbox problems already in pulsars.. Need this maintenance at all 15000 km for pulsars
Nov 10, 2008 | 2005 Bajaj Pulsar 180
Flash on ist DL
Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
Sep 08, 2005 | Pentax *ist DL Digital Camera
iPhone Apps Logo
98 people viewed this question
Top Apps Experts
ray gallant
Are you an App Expert? Answer questions, earn points and help others
