Question about Acer TravelMate 6293-6727 (LX.TQP0Z.C54) PC Notebook
Connect acer 6293 to tv with vga
I am unable to connect to tv. The graphics accelerator states that there is no tv option.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 57 Answers
Check your graphics card option/settings
Posted on Apr 23, 2014
3 Suggested Answers
bullet_okarn
  • 108 Answers
SOURCE: How can I connect to my TV to play DVDs?
ur laptop has a S-video/TV-out (NTSC/PAL) port, which can be used 2 connect 2 a compatible TV or a AV reciver. try using a svideo cable
Posted on Mar 02, 2010
Lacerz
  • 92 Answers
SOURCE: my laptop is acer travelmate 6293 i want to make
Restart your laptop. Press ALT and F10 together continuously quickly when you see the Acer Logo at start-up. Keep pressing this combination until it says "Loading Files".
Note that you have to have the original Acer Setup and did not format the hard drive then this option will work. Also note that when you do the restore, all info on "C" Drive is lost so it would be advised to make a backup before restoring.
Posted on Jun 01, 2010
Connect acer to tv
Assuming your TV has a VGA input socket, plug the VGA lead in, select Computer input on your TV and power up your laptop.
Mar 20, 2014 | Acer TravelMate 6293-6727 (LX.TQP0Z.C54)...
Screen blank with white dot
Problem with;
1) Video cable:
A) Video cable connection on motherboard side is loose, and/or on back of LCD screen.
B) Video cable is damaged.
2) screen Inverter:
screen Inverter is bad.
3) LCD screen:
LCD screen is bad.
4) Graphics chipset:
Graphics chipset is bad.
Suggest you connect a VGA monitor to the VGA port (Connector) on your laptop.
See if the problem is the graphics chipset, Or video cable, Or display assembly.
You didn't state what manufacturer and Model Number of laptop this is.
All I can do is state generic information.
This is an example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
The VGA connector will be on the side, or back of your laptop.
For the VGA monitor you can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
Laptop OFF, monitor OFF, connect the external VGA monitor to the laptop.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
There are at least 3 display options.
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(For an example HP's usually use the F4 key for a Display Toggle-Over key)
Display shows the same on the external VGA monitor?
You have a bad graphics chipset.
[ Some laptops have been erroneously stated as having a graphics card, when in fact they do not.
The GPU (Graphics Processing Unit) is soldered directly to the motherboard.
This is Integrated Graphics.
http://en.wikipedia.org/wiki/GPU
There is no changeable, replaceable graphics card. Therefore the solution is motherboard replacement ]
IF, the display is good on the external monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
After diagnosing with an external VGA monitor, post back in a Comment.
Also post the manufacturer name, and model number of the laptop.
Regards,
joecoolvette
Apr 22, 2012 | Computers & Internet
Trouble with HDMI output on Acer Aspire D257 Netbook.
VGA Driver? Does your tv have a VGA Connection? Have you selected PC or HDMI as your input source on the TV? Have you hit the FN Function Key on the laptop + the corresponding F1 thru F12 key that displays the image on the TV?
Press and Hold the FN key then hit the correct F1 thru F12 key that displays on the tv. The correct F1 thru F12 key will probably have LCD/CRT on it or it might have the icon of a display.
For Drivers: They won't be called VGA but either (Display, Video or Graphics Drivers)
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes). Look for downloads and drivers. Enter your model number and operating system when requested. Download andinstall the drivers.
Apr 01, 2012 | Acer Aspire One Netbook
My laptop is acer travelmate 6293 i want to make
May 31, 2010 | Acer TravelMate 6293-6727 (LX.TQP0Z.C54)...
How can I connect to my TV to play DVDs? I have a ACER travelmate 6293.
Mar 02, 2010 | Acer Computers & Internet
Acer AspireOne D250 tv/out capability?
This probably will not work. The rca jacks are for a RGB monitor.
If you want to use a monitor, you can. Get a proper VGA cable and remember the drivers will need to ge updated, probably.
Sep 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
How do i use my computer and pc to tv at the same time
Connect the computer to the TV
1. Through an S-Video cable or
2. A VGA cable,
depending on the input option of you TV, and the output options of your computer.
Then from Graphic properties, extend your desktop to a TV if S-Video, or to a second monitor if VGA cable. For older TVs resolution on computer screen may have to be set to 800x600.
Hope it helps.
Sep 24, 2009 | Acer Computers & Internet
Unable to see the TV option in Shuttle Centre
go to the acer site and download the software for your model and install each one esp any graphics card drivers. then check your advanced graphics options. you should be able to see tv options in there
Aug 09, 2009 | Acer Aspire 3690-2196 Notebook
Vga to tv, to show presatations
you need to have VGA WITH TV-OUT!!!
Oct 29, 2007 | Compaq Presario Notebook
Acer TravelMate 6293-6727 (LX.TQP0Z.C54) PC Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
