Question about ZTE Cell Phones
My zte warid zem's touch pad is not responding and it entires multiple commands at the same time by itself.
When I open an application. It goes ahead to click and open other commands without me even touching the phone so it makes it impossible for me to tell it want I want open thus rendering the phone hard to use
  • 6 Answers
SOURCE: Blackberry Storm the keypad has become very slow to respond.
You don't have a virus. Just make sure that you get the over the air updates whenever available. The latter versions of the phone are much more efficient than the earlier ones. Try closing applications when not in use to speed operation. Press the blackberry button choose switch applications and then close the ones you are not using. You can also delete the default third party software that comes on your phone if you don't need it. For instance, if you never use Verizon navigator, take out a few messengers i.e. aim, yahoo, remove flicker (you can always get this applications back later so no worries).
Posted on Jul 01, 2009
  • 1382 Answers
SOURCE: MY SAMSUNG GTS5233A'S TOUCH SCREEN IS NOT RESPONDING TO TOUCH.
The mobile screen would have been damaged or a device connected to your screen my be defected .Try to remove your touch screen safe guard sticker then clean the display. If this doesn't work out for you consult your dealer for replacement of new display.
Thank you !!
Posted on Jun 17, 2010
SOURCE: I have Samsung Corby s3653 touch screen phone,
.@to all who have problem with the touchscreen
things you should do first.
1. Remove the sim card and Memory card.
2. Your unit should have fully charge battery.
Procedure in updating the phone.
1. Turn- on your S3653 W
2. Touch the keypad
3. Enter *#2665#
4. touch the 1
5. Wait for few minutes
6. Done.
This procedure is for S3653W only.
What the procedure will do is..
This will update the firmware from X08 to X09 which will automatically fix the touchscreen issue.
Posted on Jun 22, 2010
SOURCE: HTC Touch - Screen & touch flo problem
i did all things described to get the screen workin,pressed the red n green buttons simultaneously n with the friggin stylus i pressed the reset button underneath, pulled the battery out a coupla million timesn put it in, but it jus doesnt unlock, the touchscreen aint workin, i can call, mssag or do anything except recieve calls, Arpan
Posted on Sep 01, 2010
SOURCE: My Samsung Star GT-S5233W touch
phine lock solution
Posted on Feb 01, 2011
HOW DO I CHANGE THE DATE ON THIS PHONE SYSTEM. I GUESS IT WASN'T PROGRAMMED TO ALLOW FOR LEAP YEAR. NOW THE DATE IS ONE DAY AHEAD.
without make and model impossible to say.
Google
make model manual
and it would be better if you turned the caps lock off :>)
Mar 09, 2016 | Lands Phones
What is the unlcok code for a huawai valiant
The unlock code for every individual mobile phone is unique and based upon the IMEI number of the device. You can visit ClassicUnlocking.com submit the required details and get the accurate unlock code at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
f your Huawei Device is a mobile phone:
1.Switch on your Huawei Phone using another networks SIM card.
2.Your phone should ask for an unlock code(NCK Code).
3. Enter the unlock code we sent you.
If your Huawei Device is an USB modem, please follow these instructions:
If your modem software asked for an unlock code when you tried using another network's SIM card, directly enter the unlock code we sent you when prompted by the software.
Otherwise try one of the following
Method 1:
This method requires your PC to have a software called Hyperterminal which can be found on the Start Menu in Windows XP, 2003 and other older versions of Windows:
Start - > Programs -> Accessories - > Communications - > Hyperterminal
1.Remove all other modems, printers and other devices connected to your PC other than your monitor, keypad and mouse.
2.Start your pc, connect your USB modem and open Hyperterminal.
3.Enter any name and select any icon and click OK to continue.
4.Set Connect using to your modem port, Huawei Mobile Connect - 3G Modem or the right COM port.
5.In the properties window that opens, without changing any values, click OK to continue.
6.Type the following command(replace the word UnlockCode with the unlock code we sent you):
AT^CARDLOCK=UnlockCode
and press enter.
7.Your modem should now be unlocked. Close Hyperterminal, disconnect your modem and connect it again.
Method 2:
Use this method if Method 1 does not work or if you are not able to follow method 1.
If your PC does not have Hyperterminal or if your using Windows Vista or Windows 7 you can use the following method.
1.Download our Modem Communicator Application. This application has been scanned by Mcafee and contains no virus. For your safety, please scan the application again after you download it.
2.Switch off your PC, remove all other modems, printers and other devices connected to your PC except your monitor, keypad and mouse.
3.Start your pc, connect your USB modem and open the application you downloaded(mc.exe).
4.Click on the Check for Ports button and wait for the response.
5.Click on the Check for Modems button and wait for a response.
6.Click on the Send AT Command button and make sure you get the response "OK".
7.In the text-box next to the Send User Command button, type the following command(replace the word UnlockCode with the unlock code we sent you):
8.Click on the Send User Command button.
9.Your modem should now be unlocked. Close the application(Modem Communicator), disconnect your modem and connect it again.
Jul 29, 2014 | Huawei MetroPCS M735
PLEASE help unlock my device E5331s-2 IMEI::860667017553111
Hi. You can unlock your Huawei E5331S-2 safer and easier using unlock code. You can get the unlock code for a Huawei E5331S-2 from SimpleUnlocking.com at affordable cost.
If your Huawei Device is a mobile phone:
Method 1:
and press enter.
Method 2:
Jul 14, 2014 | Huawei Unlocked E5331 Wireless Hspa 21m...
I need the sim unlock pin code so i can switch over to Tmobile without getting a new phone.
Hi, You can get the unlock code for a Huawei U8652 Fusion from www.unlocking4u.com/huawei-fusion-u8652/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Huawei U8652 Fusion,
Method 1:
and press enter.
Method 2:
Sep 22, 2012 | Huawei U8652 Fusion Blue/blackandroid In...
I have a problem with my 21.5in imac it is stuck on a grey screen with spinning wheel
Hold down Command+Option+Escape to bring up the Force Quit Application menu. One or more of your programs will likely have a '(Not Responding)' beside them. Select that application and click Force Quit, it will ask you for confirmation but go ahead. Then turn off your computer. Hit the power button to turn it on and immediately hold down Command+Option+P+R until you hear the tone happen twice. Log in normally and try to open that application again.
Mar 13, 2011 | Apple 21.5" iMac Desktop
I have bought and installed Nero Multimedia 10. When I am trying to run it, it displays: "This application has failed to start because the application configuration is incorrect." Not even...
Try creating a super admin account. In command promt type this command: net user administrator /active:yes ......restart the pc after that. Then log in with the super admin account and try installing and running nero. Hope it will work.
Feb 17, 2011 | Ahead Software Nero 10 Multimedia Suite...
My E71 won't function probablly..it won't let me go to applications..I tried writing a text and it goes to different application and same with the other applications..I reset the phone but problem remains.
I have a Nokia E71 and i have a big problem, whenever i teun on my phone it seems to go crazy and start to do all sorts even when im not pressing anything, it starts to go on voice commands and calls people without me pressing anything, and when i do try to press a key it wont fuction, i have alot of things on my phone and i have not backed them up what do i do i really need help please help me thank you.....
Sep 09, 2010 | Nokia E71 Smartphone
Is there a way to show all of my open OSX applications across the center of my screen so I can select any one with one mouse click?
Just hold down the Command key and press the Tab key (Command-Tab). Mac OS X immediately displays a mini-Dock with icons for each of your open applications. At the left side of the mini-Dock, you’ll see the icon for your current application. Next to it (and highlighted), you’ll find the icon for the application you last used. Each time you press the Tab key (without releasing the Command key), you can cycle through your open applications.
Source: http://www.apple.com/findouthow/mac/#switchapps
Sai.
Jan 12, 2010 | Computers & Internet
Sir how i can set my picture as a screen saver when my mobile phone nokia 6300 command unlocked.
i dont know what you mean by command unlocked,,but if you open pix and click options you should get option use image as,,even without opening pix just select it and press options (the key on your top left above call key)
Dec 08, 2009 | Nokia 6300 Cellular Phone
Excell 2007 very slow to open
Speed up Excel 2007 startup The Problem If Excel isn't running already, double-clicking a file will start Excel itself almost immediately, but the clicked file will be loaded only after about one minute.
The Solution At least on Windows XP the problem can be solved as described below.
  1. Application Explorer
  2. Menu Tools
  3. Menu item Folder Options
  4. Tab File Types
  5. List item XLS
  6. Button Advanced
  7. List item Open
  8. Button Edit...
In the dialog box that appears you need to make two adjustments:
Application to perform action:At the end of the line after /e append a space character followed by "%1" (including the quotes)DDE Application Not Running:Insert new text: [rem see command line] (including the brackets) Details We experienced the problem after updating to MS Office 2007. My father noticed that an Excel sheet gets loaded immediately if you include the path of EXCEL.EXE in the command line. Loading documents via DDE, as Explorer does it, seems to take much more time, at least if the application is not already running. The modifications described above will pass the file path immediately when the application is started, the DDE command that gets executed later on is only a remark, as an empty field would result in passing the default action from two lines above that field. The /e seems to ensure that Excel will not open an empty sheet, so I originally dropped that because usually no empty sheet is opened when a file is specified. However I got a report from someone using /e, and as it didn't cause any harm for me either, I now suggest to leave it in place. If Excel is running already, additional documents will be opened via DDE as before, resulting in only one Excel process running.
Word Time and again I've been asked whether I knew a similar trick for Word. Even without any tricks Word starts fairly fast, but even there adding "%1" gave me a slight increase in startup speed. I don't exactly know what this [REM _DDE_Direct] is. It looks like some kind of "special comment", that could have some effect despite being a comment. I decided to copy that comment to the DDE Application Not Running box, and could not detect any ill effects. I also kept the /n and the /dde on the command line, simply because I could find no harm in it.
Uninstall If you try out these suggestions, but they don't work out for you, reverting to the way it was before might prove more difficult than you would expect. It seems the dialog where you make your changes will always append a %1 to the command line when you press OK and it isn't present already. The only solution I could find was using regedit to remove the %1 without using the dialog. The command is stored under the default key at HKEY_CLASSES_ROOT\Excel.Sheet.8\shell\Open\command. If you choose to revert the DDE settins using regedit as well, you can simply remove the whole ddeexec\IfExec subtree.
Feb 02, 2009 | Computers & Internet
Cell Phones Logo
13 people viewed this question
Top ZTE Cell Phones Experts
john smith
Nyte_Ryder
vince
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
