Question about Microsoft VISTA Computers & Internet
Gfive keypad not working
W1 g five how strip conect
    Master:
  • 680 Answers
I would take it in and have it bench tested and repaired.
Terry
Posted on Apr 06, 2014
Password of g five w1
Your password will be whatever you selected when you signed up - we cannot help with this
Mar 12, 2017 | Cameras
Can i jumper w1 and w2 on ahka20c15kw heat strip
I would say absolutely if you are using electric heating, or electric heating with a heatpump.
Feb 16, 2015 | Heating & Cooling
Cannot get Hunter stat 44155c that is connected to a Rheem 1210b to shut off after the stat reaches the set temp. How is an original 7 wire connected to the Hunter stat?
y is to condensor contactor wire
c is common
r is power
w/w1 heat strips
o/b reversing valve
e/w2/aux heat strip also
g is blower
For a rheem unit, make sure reversing vavle is set for "B" not O.
Blower may run for up to 120 seconds after shut off. My experience with hunter stats are not good (even out of box). Recommend honeywell tsat.
Apr 05, 2011 | Heating & Cooling
My service technitian put a jumper on my tappan air handler (model B5BMT60KC) in which W1 and W2 are jumpered all the time. He cut out the black wire entirely. Does this mean everytime the unit is powered...
No it means when you make a call for heat both stages of heat are going to come on. They wont come on if your just running the fan or if its in ac. Thanks please leave feedback
Dec 16, 2010 | Heating & Cooling
New heat pump system freezing, questioning wiring.
W1 and E on stat need tied together. When W1 comes on wire where all heat elements come on. On the outside unit defrost board set the 45-60-90 to 45 and see if that takes care of the frost problem.
Jan 03, 2010 | Heating & Cooling
I am tying to install an RTH6400 5 in 1 thermostat but the colors of wires i have on my wall are RED, GREEN, BLUE AND BLACK, where as the book has RED , YELLOW,WHITE AND BLUE. please which do i connect to...
You need to open up the panel at your furnace(air handler) and find the terminal strip and see what your existing thermostat wires are connected to. Normally your red wire connects to the R terminal(24 volts), the yellow wire to the Y1 terminal(cooling), the white wire to the W1 terminal(heating), the green wire to the G terminal(indoor fan). You can use whatever color of wire you have existing, just make sure that the R,W1,Y1,and G wires at the furnace match the R,W1,Y1, and G terminal screws at the thermostat. Also make sure the power to the furnace(air handler) is turned off before you make any wiring connections at the thermostat or furnace.This is very important! If you don't and you short any wires to ground(especially the R wire) you will possibly ruin the system step down transformer or blow the low voltage fuse.
Nov 10, 2009 | Honeywell Electronic Programmable...
How to network
You need to go to the microsoft website or use windows help. If you come accross a certain problem we can help but to walk you through a whole networking process is a little much. Though it is pretty self explanitory. Set up all the computers the same Wired and wireless will be different of course but not too much jst a couple extra steps for the wireless is all. Let me know if you get any questions
Dec 29, 2008 | Dell Inspiron 1721 (dndwna2_5) AMD Turion...
Installing a stat to a furnance
You need a 7 conductor minimum, 8 will suffice.
Depending on what type of thermostat you are using, hard wired or battery will make a difference, some model thermostats have a "C" on the terminal strip regardless of the power being supplied to the thermostat. If your Thermostat does NOT have a "C", and the furnace does not require a common, then disregard that terminal.
The Terminal strip on the thermostat and the terminal board on the furnace should be close to this, and let’s assume you have 2 stages of cooling as well. This is a general rule of thumb for the wiring and their correct place.
R - 24VAC
W - Heat
G- Fan
Y - Cooling
W1- Stage 2 Heat
Y1 - Stage 2 Cooling
C - Common
Nov 30, 2008 | Goodman GMS90703BXA Heater
Sony-DSC W1 lens not closing
batteries may be low. Dont force it unless its your only option. You could strip a gear.
Mar 02, 2008 | Cameras
Control dial -W1
needs replacement! In warranty no problem, otherwise you will have to pay maybe not too much. On your own you may try to disassemble it and try cleaning the contact brushes and metal stripes. Problem may be caused by dirt.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Computers & Internet Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
