Question about Thermador 36 in Built In Bottom Mount Refrigerator w/ Masterpiece Handle - KBULT3655E / KBURT3655E
Ice maker is not making ice on a Thermadore KBUDT4850A02 Refrig.
Ice maker uses a IR sensor to determine when the bucket is full.
The light by the ON/Off switch continues to blink.
I have water on the door dispenser and the ice dispenser operates,just no ice is being made.
Can you help with any troubleshooting tips. There are test points on the ice maker, but I have no service manual to determine what output I should have.
Does the light by the On/Off switch suppose to blink continuously?
Thanks for any help you have to offer!
4 Suggested Answers
SOURCE: Thermadore Freezer
I assume you mean do not work? I have the freedom 18" with through the door ice water. Themador has replaced the whole unit already. The second stoped woking after six weeks, call is in to repair again......
Posted on May 03, 2008
Macmarkus
  • 2605 Answers
SOURCE: The ice maker stopped working in the middle of a
This could indicate a heater or thermostat issue. If you are mechanically inclined, here's what to do. Shut off the water supply to the unit. Pull off the white cover at the head of the ice maker unit. Now you'll see the module for the ice maker, it will have a large white gear/wheel (don't attempt to turn manually, you'll strip it out) and several holes identified by letters, i.e. "t" "h" "n" etc. What you want to do (make sure the bailer arm-metal arm is in the down position) is get a short "jumper" wire, either solid core or braided it doesn't matter. jump between "T" and "H". The ice maker will now start, you'll should see the "wheel" turning, shortly after it will be followed by a slight buzzing noise likely, this is the unit "calling" for water, but it's off, that's ok. We just want to advance to the "harvest' part of the ice making process.
If the unit does advance and empties the mold of ice, you may want to remove the complete ice maker and clean out the mold. It is a common occurrence that over time you'll have a build up of mineral deposit from the water which will cause the cubes to "stick" or if you will, impede the ice from dumping.
If the unit doesn't empty but you can feel the bottom of the mold is hot **be careful-wet your finger first** (you can actually see a small heater/element if you look at the bottom) you'll have to remove it and clean it anyway. If it's NOT hot, you'll need an icemaker assembly, **unless you can test the heater and or the thermostat and find replacement parts. It's becoming difficult to justify replacing parts versus the entire unit from an economical point of view when servicing professionally when one consider's the labour cost etc to the client. It may be easier to justify for a do-it-yourselfer.
Try this procedure, let me know either way if it works or not I'll try to follow up on a remedy.
Hope that helps, Good Luck
macmarkus :)
Posted on Nov 01, 2009
imufo2
  • 3773 Answers
SOURCE: ice maker red light on
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 31, 2011
How do I make the IR controlled ice maker store more ice. The level of the ice is 4" below the IR sensor
The sensor is not the problem, you are not producing enough ice.
Ice production increase if the freezer is pretty full and is set to lower temperature.
Nov 01, 2015 | Whirlpool Refrigerators
Why does ice maker keep making ice?
The level sensor is jammed or not fully retracted
Aug 20, 2015 | KitchenAid (KSRD22FKST) Side by Side...
Only 83 volts to icemaker
yes , when you measure in series with a load in an electrical circuit , you will measure the voltage loss the device causes by exerting its load on the supply power , this is what I suspect your seeing , if the optical sensor looks ok on the bucket thing , I suspect your having the old whirlpool water inlet solenoid problem , id ck that
try adding a small amount of water to ice form tray , if it makes ice in 24 hrs then yep you need a solenoid , also those tiny little sensors they use to sense where ice level is at , can be seen with the use of a simple home video camera (not your phone) , seems home vid cams are extra sensitive too IR light so you can view the light source with it to check it !!
Jun 06, 2017 | Kenmore Side by Side Refrigerator
Ice Maker will not stop making ice
the beam is defective. Its called an optic eye it does tell the IM that the bins full and cuts power to IM when beams dont see each other.
Nov 04, 2009 | KitchenAid (KSRD22FKST) Side by Side...
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker stopped working
if there is ice in the mold then the problem is the ice maker unit , replace the ice maker for the fix.
Phil
Jun 10, 2009 | KitchenAid KSRG25FKSS Side by Side...
Ice bucket broke on my edgestar, IP210TI, ice maker
call Edgestar support at 1-866-319-5473. i had the same probvlem with my ice maker and had no problem ordering a replacement with installation instructions
Feb 13, 2009 | EdgeStar Titanium Portable Ice Maker
Ice maker does not consistently make ice...
try turning off ice maker for a day. remove the bucket that holds the ice. look all around bucket and into ice maker to determin if there is a jam, or if there is a cube stuck there preventing operation. Check that the ice arm can move freely and it is properly inserted on both ends. Make sure there is nothing in your freezer that could be getting in the way of the ice maker operation, either above or below the unit. One hint-wear disposable gloves when working with the ice maker-if you have any moisture on your hands, you tend to stick to the unit.
Jan 17, 2009 | KitchenAid KSCS25FKSS Side by Side...
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
Thermador 36 in Built In Bottom Mount Refrigerator w/ Masterpiece Handle - KBULT3655E / KBURT3655E Logo
163 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
ray gallant
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
