Question about Battery Biz Computers & Internet
I have a 5th wheel 1987 cargo i need parts
1987 5th wheel trailor battery went dead
    Problem Solver:
  • 5 Answers
Check for Rust/Corrosion at the point where the Ground Cable bolts to the Frame/Ground. Remove bolt or nut and sand the area with 80 grit sand paper, and the eye on the Grounding Cable,,, apply a liberal amount of Axel grease to the entire connection, AFTER reconnecting !
Posted on Apr 19, 2014
Have power issue with 5th wheel trailor
Check for burn fuses. There might be more than one fuse involved.
Feb 02, 2015 | Cars & Trucks
My car is missing in 5th gear and battery is draining over night
First thing I would do is have battery fully charged and perform a load test on it. Then check charging system for proper output voltage.
Jan 06, 2014 | 2001 Ford Mustang
Lost speed.5th gear stoped working
old car. 5th gear? is this M/T? 1987 ?
A/T? is 4speed
what does stopped working mean .
1: shifter fails to select 5 gear H pattern slot.
2: grinds?
3: cant force it to 5th with clutch depressed.? is free play at spec?
4: raise front wheels off ground, can you get in to 5th now? keyout and running?
5: can you get into 5th parked engine off, and select 5th and then start car in 5th with clutch depresses first step. then slowly very slowly attempt to move car starting in 5th, but dont finish, just feel the gear, feel that its there and not neutral.
not working ,says nothing at all.
Sep 13, 2013 | 1987 Honda Prelude
Need transmission repair instructions for 1987 acura integra 5 speed transmission. 5th gear went - getting bearings, seals - repair kit will be here tomorrow. my sons book is in washington state and he...
changing 5th gear on most manual gearboxes can be done without removal of the gearbox ,remove the inner wing and then access is quite easy ,take the rear cover off the back of the gearbox undo a nut or bolt on a stud and then gear selector can be removed and then a circlip at the end of the shaft and of it all comes ,
Sep 01, 2011 | 1987 Acura Integra
1987 F350 DUALLY WHAT IS MAX WEIGHT OF TRUCK & 5TH WHEEL?
look in the driver door it will tell you i pull a gooseneck with 30000 on it all the time with no prolbem my wieght is 30000
Feb 15, 2010 | 1987 Ford F 350
2004 Dodge Durango electrical issue
the problem started because the battery was disconnected
try using a scan tool to reset the ECM program
Apr 29, 2017 | 2004 Dodge Durango
1987 Chevy R10 project truck won't start
check the float on the carb is stuck shut not letting fuel in
Aug 17, 2009 | 1987 Chevrolet R10
Right turn signal will not work
do both trailers use same plug off truck? does both trailers have break lights both sides? can you get turn signal from plug on truck? have you chk. ground on that side? most problems like this is a ground.
Jan 22, 2009 | 1996 Dodge Caravan
Computers & Internet Logo
49 people viewed this question
Top Battery Biz Computers & Internet Experts
justwinwin
Lawrence Oravetz
Greg Baldwin
Are you a Battery Biz Computer and Internet Expert? Answer questions, earn points and help others
