Question about Uniden BCD396XT Handheld Scanner
I accidentally locked out a "grp" and need to get back into it
I have tried the owners manual, but so far nothing seems to work. I am not sure if I am reading the correct section. The rest of the "bank" (SO on the screen) are all numbered, but the one I need to get into shows as an asterisk (*) which in other places means it is locked out. I am trying to figure out how I locked it and then unlock it.
  • Uniden Expert
  • 509 Answers
Not sure if yours works the same as mine, but simply pressing the number button of the bank you've switched off will put it back into the scan again. So if you a dash or "*" instead of say bank #6, simply press the '6' button while it's scanning and it will be back in the scan. At least that's how my old one worked. Let me know if it works for you too. Good luck. You can also go to 'radioreference DOT com' and there is a Uniden scanner forum there I believe where you could also ask your question. 73.
Posted on Mar 21, 2014
Why won't the back doors open - they are not locked?
Re you referring to the interior or exterior handles....or both? If the doors are not locked and only the interior handles do not work, it is possible that the child safety switches are activated. This prevents the accidental opening of the doors by a child while the car is in motion. The owners manual will have the procedure to disable this feature.
Aug 30, 2014 | 1999 Buick Park Avenue Ultra
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
NO PICTURE ON TV / JUST BLUE SCREEN / W/RED SYMBOL.Have an Advent TV -- seems locked up, can't get a picture, just a blue screen with a red symbol in upper right hand corner
Look to the owner manual if you have it as it will likely have the answer you need--if no manual Google the model number with "manual" to try to locate the owner manual---if get or have it read it carefully as it sounds like to me the parental lock is on or something similar to it.
May 23, 2012 | Televison & Video
I replace my uv bulb and now have no power
Some connection has not been firmly made, or the little safety switch at the back of the machine was accidentally pushed.
1) Check the back plug and make sure it is inserted FIRMLY. Does the machine work now?
2) If not, check the little switch in the back with the 0/- markings. Make sure it is depressed to allow power to the machine (try it after checking the plug.)
3) Check the fuse.
4) Unplug the machine and go back in to make sure the UV bulb is firmly inserted. It needs to be turned so that it "clicks," or "seats" correctly at both ends.
If none of these steps work, go through your Owners Manual step by step, checking all connections and wires. Make sure nothing is visibly loose, corroded, or broken. An owners manual is available at http://www.vollara.com or call Vollara customer service at 1-800-989-2299
Jan 29, 2011 | Ecoquest Fresh Air Living Air Purifier
Touch screen needs to be calibrated (i.e., when typing an "a", I might get an "o", or nothing at all. Same applies to numbers. I was unable to get to the calibration screen following instrucitons in...
That is actually how you should do it, it's just that it's very hard to succeed. Personally I have to try 3-4 times before making it work. The "trick" is to start touching the screen right after it was turned on, but right before locking it, but still locking it right after it was turned on.
It's stupidly hard on this specific series for some very weird reason.
Also, since it seems to be very calibrated to the left, try pressing far left on your screen, so the touch is registred too, don't know if it helps, but possibly.
Jun 18, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Locked computer
If you did the steps according the manual and the computer remain unlocked seem to be a malfunction. Usually the screen blank is caused by the video card, memory or inverter malfunction.
Dec 10, 2008 | Computers & Internet
2005 Malibu MAXX car stereo dead, rear radio too.
Please check your owners manual for the location of the 10 amp fuse for the radio. On some models you have to reset the security feature on the radio/CD player for it to work.
The info below has been stated to work on a no go radio. I have not confirmed this procedure.
Remove the lower fuse box cover, with the power off, removed the 10 Amp fuse for the "Radio." the fuse may be good. Fuses are diagrammed in the owner's manual. With the fuse removed, start the car, turn the car off, replace the fuse and turn the key to "ACC" to see if the radio was "Reset."
Would the alarm cause the radio to malfunction? If your Anti Theft lock was activated check your owners manual under radio and check for a 4 number password. Sometimes it is taped to the upper part of the glove box. If you do not have the CODE you will need to take the vehicle to a dealership or a repair center. They use your vehicles vin number get the code.
Jul 21, 2017 | 2005 Chevrolet Malibu
Citizen tv wont unlock
Try to unplug it for a day and maybe it would lose its memory
Jul 06, 2008 | Televison & Video
6515 wont turn on "help"
you should try to do a hard reset. While holding down on the far left (calendar) and far right (iTask) press in on the reset button (reset hole) with your stylus for about 2-3 seconds. The Pocket PC should reset and power back on. If the device does not power back on, make sure that the battery lock switch is to the left (locked).
Oct 09, 2007 | HP iPAQ hw6515 Pocket PC
Uniden BCD396XT Handheld Scanner Logo
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
