TV will not on with remote or on off button even though has power
Power light on but tv will not turn on with remote or on/off button on tv
    Top Expert:
  • Televison & ... Master
  • 74,378 Answers
Main board fault. Check its main system control section circuit. Contact any service technician. This is not a user repairable fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 20, 2014
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 188 Answers
SOURCE: power light keeps blinking and power will not turn
Check back light inverter,if ok then check the 12V and 5V line,if not OK probably the IC in the power supply is defect ( F9222 )
Posted on Jul 20, 2009
  • 5 Answers
SOURCE: Power to TV, cant power on, red light flashing
The repetitive blinking light is a trouble code which is used to determine which series of boards may need to be replaced. How many times does the red light blink?
Posted on Aug 30, 2009
roety
  • 585 Answers
SOURCE: my samsung 330 lcd-tv wont turn on. the red power
Hi my name is Roety,
I can help you with your issue ,
Most common issue is the power supply capacitors, check and replace any that look swollen like this
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Posted on Oct 28, 2009
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
LN55C750R2FXZA Samsung LCD
What your describing is symptoms of a power surge, Many LCD Tv's are sensative to Slight fluctuation in power during rain, thunder and lightning storms, i myself was happily watching Tv through such a storm at one time, and when i went to bed the TV would not respond remotely or manually, i also disconnected the power from the wall waited for the ready light to disolve and try to turn on, unfortunatley the damage was done, a Tv Repair was nessecary and since then i now use a belkin power surge protector board for my TV and appliances......one question to you is i would guarantee you do not use a surge protection my friend......and your set will need a Tv Repair, it is not major as what is neccesary is a firmware dump on the internal memory and replace the BIOS Battery as well.
Aug 17, 2014 | Samsung UN55B8000 55 in. LCD HDTV
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
BPL TV NOT STARTING
if no any power indicator that light or even blinking, the first place to be check will be the power supply section you must check weather the fuse is blown.if the fuse is blown before you replaced with new one you need to check other component in the power supply section like transistor and diode. so this case need proper trouble shooting, if you think you don't have enough idea in any electronic repair just leave it to the trained tv technician.
Aug 12, 2012 | Televison & Video
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
I need a code to program a remote for a sanyo tv
all you need to do is press the code search button until the red light is on then press tv button...then point the remote at the tv and continue to press the power button until your tv turns on/off...then press enter. Be patient...it may take any wear from 2 or three clicks up to 100 clicks....but it will eventually operate your television....be careful though...if you press the power button even 1 more time after it turns your tv on or off...you will have to start all over....Good luck! and if this doesnt work..you can always buy a universal remote from any department store..some are as cheep as 5.00. and they all come with program guides.
Nov 03, 2011 | Sanyo DP42849 42 in. HDTV
When i go to turn the tv on the green light go on and then off. i did the coe test error code repeated 10 times
I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again
Jan 02, 2011 | Mitsubishi WS-55807 TV
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
Its a tiny 42'' plasma tv which was working perfectly until my grandaughter dropped the remote control and the tv went off and now wont switch on even though the stand by light is on.It wont even turn on...
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
Thanks,
Chris
Boise LCD
www.BoiseLCD.com
Oct 08, 2009 | Televison & Video
118575 remote stopped working batteries are new lights light up but wont control tv or satellite anymore even though it just worked
The receiver more than likely received a software update or reset itself and reset the codes to the receiver and tv. We will need to set the remote address again and run a power scan to control the tv. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. Now we need to do a power scan - press and hold the upper left TV button until all buttons across the top light up and release. Press the red TV button and release, The TV button should be lit constantly. Now press the channel up button slowly until the TV turns off. Once it does press the channel down once and then cannel up to see if the TV turns back on. If it does press the pound sign. Now press the record button and you are back in business. If you have further issues let me know. Thanks for using Fix Ya.
Apr 03, 2009 | DISH Network IR Remote Control
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
