Question about BenQ Scan to Web 5000U Flatbed Scanner
Scan rod working slowly
Scan rod working very slowly
How do I go about fitting a headliner to a mk2 ford consul
Start with the first, front supporting wire / rod & feed it through the lining hoops & roof mounts, then work your way back along the roof doing the same for each rod. This rods fully support the liner & do most of the work.
When all the rods are fitted, start loosening any trim where required, push the liner under & re-seat the trim. Use a blunt tool to lift the edge of any window seals & run it slowly along the seal, inserting the edge of the liner as you go
Dec 10, 2014 | Ford Cars & Trucks
Chevy cavalier had new ignition put in and was working fine. A few months later the key would not stay in run position after starting. I had to hold key and slowly let go to kkeep car running. Now car wont...
when you turn the ignition key it activate a metal rod to ignition switch on top of column steering
this switch is adjustable by loosing the two bolts and nuts
look if you bend that rod could be the problem
hope it helps
Oct 18, 2013 | 1985 Chevrolet Cavalier
I have a canon dr 5020 that just started scanning slowly
Check if there is enough disk space in the comp target area. Run defrag and scandisk.
S. Mohan, india
Mar 01, 2013 | Canon DR-5020 Path-Through Scanner
My scanner scans really slow and does not play any of the frequencies I have they worked before
if the frequencies you had before were police, ambulance, fire ect. then they have all gone onto the new tetra digital system and so you will not be able to pick them up.
if its things like the coastguard, airband, amateur radio that you caan no longer pick up, then the scanner may be faulty.
From memory the pro 97 used to scan fairly slowly anyway, but if its scanning like REALLY slowly, say a channel every couple of seconds, then check the Squelch setting on the scanner
Sep 01, 2010 | Radio Shack Pro-97 Handheld Scanner
2002 ford escort brake lights won't go out. I found a blue disc broken on the floor board but I have no idea where it came from.
More than likely that blue disc came from the brake light switch. You state that the brake lights will not go off. The solution is a relatively easy fix. Under the dash near steering column, attached to the brake rod (or above brake pedal) is the switch that controls the brake lights. It is usually held in place with a small connecting rod with a kotter pin or clip. Remove the pin or clip and slowly pull the switch out while (depending on design) slowly pulling the brake pedal rod the opposite direction. Be careful when removing the plug(s) on old switch. Replace the new switch in the opposite order in which you removed the old switch.
Jul 17, 2010 | 2002 Ford Escort
Sunroof leaks
Use bicycle spoke or anything similar, pour in some water and thn poke it slowly through the tube and you will feel the choked dust give away, you may need a longer rod kinda thing say a CCM gas weilding rod would work out best as its longer in lenght and about 3mm in diameter.
Hope this helps!
Nov 24, 2009 | 2005 Pontiac G6
Scans very very slowly. Thought it wouldn't scan at all. Left it. Just see half a page scanned. One cm at a time or so..
I presume that you mean "photocopies slowly".
Check the "resolution" of the scan, i.e., 300-by-300 or 2400-by-2400 or something else. Bigger numbers mean slower (but better) scanning.
Oct 07, 2009 | HP PSC 1210 All-In-One InkJet Printer
Nikon scan was unsable to find any active device
I may have a solution for the unrecognized film holder/clunking problem.  The fix is not for the faint of heart, but you can do it yourself and save a bunch of money.  The problem lies in the two rails inside the scanner that the film carrier rides on.  After unplugging you scanner, remove the 8 screws from the rear of the unit and slide the cover rearward about 3/4" and then lift it straight off.  Inside you will see two shiny machined rods running from front to back.  The problem is those two rods have dried up lubricant on them and the film carrier drags a bit during film carrier insertion and/or scans.  The easiest way I found to clean the rods is to remove the front cover (look for screws inside on each side), and then carefully slide those rods out (but NOT all the way) and wipe off what is exposed and then apply a little silicone lubricant to the rods (be very careful to not get any down into the lens area).  Then slide the rods back in and repeat for the portion that is exposed in the rear.  Carefully re-assemble everything and you should be all set.  This fix worked for me on an 8000ED that I purchased used on eBay.  Hope this helps someone.  Brian
Nov 24, 2008 | Nikon Super Coolscan 8000 ED Film Scanner
Scanner won't initialise properly
There is rust on the roller rod please open it and oil the rod and wipe it with clean cotton.
Thaks.
Apr 01, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
BenQ Scan to Web 5000U Flatbed Scanner Logo
13 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
