Question about Sennheiser HD 433 Consumer Headphones
Hd433 repair cable
Iwas wanting to know if i can repair the shift cable myself instead of buying a new one?.... cable just snapped and gear shifter just went limp.. please help.
unless the adjuster fell of then you cannot repair the cable
if it snapped then it was need of a replacement one anyway
Apr 20, 2015 | Cars & Trucks
How do I repair the self propel cable
There is no way to repair the cable if it is actually broke it has to be replaced with new. If the inner cable does not move it must be replaced.
Sep 17, 2014 | Toro Garden
How to repair a clutch cable on a toro recycler mower
Did the cable break? Or did it just stop working? In general you have to figure if it came off, break or did the adjustment slip. Readjust if necessary or replace the hole cable or re install it correctly. Simple Question, so many answers. And if all else fails, take it to a lawn mower repair shop.
Aug 21, 2014 | Toro Lawn Mower With Toro Power Tools
How to repair cable on rear flip up seats?
sometimes you can get a screwdriver down into the latch were the cable hooks and prey the latch up as the cable would
Jan 29, 2014 | 2004 Toyota Tundra
Can a differential repair cause a problem with the auto transmission cable?
I AM A AUTO REPAIR MECHANIC NEVER SEEN THAT HAPPEND TO MY EXPERIENCE NO I DONT THINK THAT WOULD COUSE IT BE HARD TO SHIFT IN TO GEAR DONT SEE A REASON FOR THEM TO MESS WITH SHIFT CABLE TO FIX REAR END NOW BEST THING TO DO TAKE TO DIFFRENT SHOP AND GET A SECOND OPINION SEE IF WHAT SHOP IS TELLING YOU IS TRUE THAT CABLE IS BAD LET ME KNOW IF NEED MORE HELP THAT WHY IM HEER FOR VIC
Nov 28, 2012 | 2008 Toyota Highlander
Is the shutter flex cable of A470 self-replaceable?
$35 is very inexpensive for this repair. But an A470 is only worth about that price these days. I know that flex cables are available on eBay, but the average person CANNOT repair this problem. The shutter flex cable is buried DEEP inside the camera, and inside the actual lens mechanism of the camera. You need to completely disassemble the camera to access it. If a new camera is out of the question, and you are certain that the $35 repair business is reputable, then would recommend them instead of you attempting to repair this yourself.
Nov 20, 2011 | Canon PowerShot A470 Digital Camera
Blue wire sparking into fitting how do i take the monitor apart for me to change the wire
Hi
I would strongly recommend that you do not attempt such a repair.
Even when disconnected from the mains electricity, the internal parts of monitors and TVs are dangerous working environments unless you are experienced. These devices contain large number of capacitors (electrical storage units) that retain a very high electrical charge, easily capable of inflicting serious shocks and electrical burns and that are even capable of killing someone.
You do not say which cable type is involved, but since you imply that the cable is fixed to the monitor, this would seem to be an older, VGA or DVI cable. VGA and DVI cables are multi-strand cables that have to be soldered in the correct complicated configuration and are not conducive to amateur repair attempts.
If the cable is not permanently fixed to the monitor, then simply replace the cable.
I strongly recommend you either refer this repair to a monitor or TV repair specialist.
Because of the reasns listed above, I also recommend you stop using this monitior, because the sparking could pose a fire hazard.
Most monitor repairs are uneconomical. So it may well be that you end up buying a new monitor with a detachable cable, where if the cable develops a fault, all that needs to be replaced is the cable.
Hope this helps.
Aug 02, 2011 | Acer Computers & Internet
Broken brake cable.Where do I get a replacement?
Hi. I repair walkers wheelchairs and mobility scooters. I sometimes get asked to repair broken brake cables on walkers and wheelchairs. I get new cables from the local bicycle repair shop. Take in your old cable so they can measure its lenght, and find one the same. They only cost a few dollars.
Good luck. Neil.
Jun 07, 2010 | Medline MDS808210AB ExcelT Deluxe Aluminum...
Part # for aspire 5043 motherboard
There are a few motherboard this series:
MB.AA101.001RF - Refurbished Main Board AB2 V128 w/MDM&Cable
MB.AA101.002RF - Refurbished Main Board AB2 V64 w/MDM&Cable
MB.ADX01.001RF - Refurbished Main Board AB2.UMA w/MDM/Cable/RTC
MB.ADX01.001 - Main Board Ab2 UMA w/Mdm/Cable/Rtc - Repair Flow Only (repair flow. send failty motherboard in advance)
MB.AA101.001 - Main Board Ab2 V128 w/Mdm&Cable LF - Repair Flow Only (repair flow. send failty motherboard in advance)
MB.AA101.002 - Main Board Ab2 V64 w/Mdm&Cable LF - Repair Flow Only (repair flow. send failty motherboard in advance)
www.acerparts.com
other guy asked for aspire 5100 motherboard, look here
http://www.zandparts.com/acer/index.php?cPath=40886_40887_40929_41356
Nov 22, 2008 | Acer Aspire 5100 Notebook
I have a Panasonic PVGS19 Mini DV Camcorder. The problem is the flip screen. Will not work when fully open. There is a picture when it is opened at about 1/4 of the way. Also, when opened and flipped...
There is a small flat ribbon cable between the camera and the LCD display that probably has a small crack in it. Move the cable the right way and it works. The cable neds to be replaced. This is NOT a repair to be done by anyone without prior repair experience as there are too many cables and connectors that can be damaged easily.
The repair shouldn't be too much as the hinge with the cables (part number LSXY0764) is only $17.14. Add in the local labor rate for the total repair cost.
Dan
Jul 08, 2008 | Panasonic Cameras
Sennheiser HD 433 Consumer Headphones Logo
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
