Question about Cell Phones
Bad contact charger error message displayed after 2 minutes of charging
When i connect the charge it says bad contact of charger after charging for 2 to 3 minutes. if i reconnect the charger it repeats the problem. what is the problem
  • Cell Phones Master
  • 928 Answers
What this means is that your cellphone is most probably not compatible with that charger or USB cable. You don't state which phone model you are referring to, but this happen a lot with iPhone. Try borrowing or buying the correct cable or charger for your phone. Best of luck.
Posted on Mar 20, 2014
4 Suggested Answers
  • 3 Answers
SOURCE: warning bad connection charger
charger is broken...get a new charger or charge it on pc via usb cable provided....hope it helps you guys....
Posted on Dec 21, 2008
SOURCE: i have nokia 3315 mobile
U need A new Battery
Posted on Jan 01, 2011
  • 251 Answers
SOURCE: I have a LG GX200
Hi
Please never try this as PIN specifications for the charger are vendor specific and it may damage your mobile phone. Only use the accessories of the manufacturer from whonm the cell has been purchased.
Posted on Jan 30, 2011
I keep getting the message "connecting to computer" on Samgsung SH100
Disconnect the camera, remove the battery and after a few moments reinsert the battery. Then switch on again.
When you charge the battery in the camera, the camera could think it is connected to a PC, because the USB cable is inserted. It could be you are using a USB cable, that not came with the camera. If the error keeps coming back buy an external (Universal) charger, to charge your battery. Modern universal charges can charge almost every camera battery on the market. In the long run, it is better for the camera and for the battery, when you charge in an external charger.
Keep the contacts clean with a dry cloth.
May 10, 2014 | Samsung Sh100 black 14.2mp 5x Zoom Digital...
Phone is using more current than the charger is able to deliver
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 02, 2012 | Cell Phones
Warning bad contact charger yxtel model x88
i connect phone for charging, A few minutes it gives awarning of "BAD CONTACT OF...i changed anthor charger battery so tel me waht problam
Oct 22, 2011 | Cell Phones
I have a LG GX200 dual sim mobile. It charges well with its charger. But when I connect it through a connector lead having a nokia jack on one end & lg jack on the other end, error message...
Hi
Jan 30, 2011 | Nokia Cell Phones
When charging my w595 after only 1 minute a message appears on the screen saying serious error stop charging stop using your phone and contact a sony ericsson call center
You are using a wrong charger that is not original. Please change the charger or use a universal charger, you may damage your phone if you insist
Jun 06, 2010 | Sony W595a Cell Phone
Charging only few minutes then have warning Bad charger contact
The charger seems to be Ok from your description. It seems that your connection in the phone is loose. Have it checked.
Jul 31, 2009 | Dual Electronics N99i Cellular Phone
Charger Error Pop Ups
dear,
this issue directly related with the charging circuitry... the issue can either be with the charger itself or majorly with the charging ic ...
i had faced this problem with the chinese mobile phone but this can be either with the chinese model or can be with the other...so check the both things one by one...hopefully the issue will be resolved..
regards,
dont forget to rate this if issue resolves.....
Jul 18, 2009 | Dual Electronics CECT P168 Cellular Phone
"unable to charge"
I had an old Motorola V3, which used to show me that error. It could result if the charger is not firmly connected to the phone. To diagnose this, try borrowing someone's moto charger. It's also possible that battery contacts could have dust. Try dusting them off so that they're nice and shinny as usual. Finally, try removing the battery for a few minutes, reinsert and charge, leave the phone off when you charge. The phone usually starts working after the regimen. If the problem persists, you'd know which method worked and what failed, so you can press for a warranty. Cheers
Jun 02, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Warning bad connection charger
Nov 07, 2008 | Dual Electronics N99i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
