Question about Canon NP 6035 Copier
Km-6230 paper jam everywhere
3 Suggested Answers
SOURCE: Paper jam
unplug printer from wall and plug back in somtimes this forces trapped paper out of machine as it wrams up.
also remove paper drawer to make sure paper isnt trapped in this area
Posted on Jan 15, 2008
edy_bubat
  • 259 Answers
SOURCE: how to handle paper jams on bypass tray on Canon
in which part the paper has jammed ?
there is intruction on display.
but the first step you must open the front cover.
Posted on May 17, 2011
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Paper jam
This would indicate that one of the sensors in the machine is either sticking or needs to be replaced.
May 13, 2013 | Kyocera Mita KM-2050 Printer
How to handle paper jams on bypass tray on Canon np 6230?
May 17, 2011 | Canon NP 6230 Copier
Can't get it to make copies. I need it to show "letter" size when choosing the size parer...it shows A4.
You may have a piece of paper jammed behind the paper tray? I would take the paper trays out of the copier and look inside to see if there is paper jammed toward the rear of the copier..... There are switch's that till the copier what size paper is in the tray. It can also be a small tab on the back of the paper tray is not adjusted correctly? Good Luck
Apr 05, 2011 | Canon NP 6230 Copier
Error Message C5100 Kyocera KM-4530
your main charger is shot... order a new one...
Dec 18, 2009 | Office Equipment & Supplies
Phantom Paper jam
Pull out the paper tray, shut off the printer.
check all paper path.
turn on the printer
inser the paper tray.
Aug 23, 2008 | Brother MFC 8500 All-In-One Laser Printer
Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Jul 20, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Paper jam
Dec 06, 2007 | Canon imageCLASS D780 All-In-One Laser...
Canon NP 6035 Copier Logo
16 people viewed this question
old marine
old marine
