Question about Konka DLC-3211UT 32 in. LCD Television
Usb not full screen only small in the middle of the screen
Usb small screen
Tecra8100 not going full screen
Try changing the screen resolution to 1024 X 768.
Jan 16, 2012 | Toshiba Tecra 8100 Notebook
I was scanning documents to my USB drive and in the middle of the scan it said Storage Full
A msg saying that your USB drive was full. Try scanning at a lower resolution or remove files of USB to free up space.
Aug 25, 2010 | Brother MFC-9840CDW Laser Printer
SONY BLUE RAY ONLY SHOWS IN SMALL SQUARE. THE
Have you gone through your TV's menus? You may have to change screen resolution from within the TV's settings to get a full screen presentation.
Dec 29, 2009 | Sony BDP-S350 Blu-Ray Player
Boot failure at USBd checkpoint
There are 2 steps you can do to fix the problem
1. Change the USB Emulation Setting in the BIOS
NOTE: It is recommended to disconnect any USB devices before performing the following steps.
Restart the system.
Wait until the Dell Logo appears.
At the Dell Logo screen, press F2 right away to enter the System Setup.
The System Setup screen will appear.
Press the down arrow key to highlight Integrated Devices (LegacySelect Options).
Press Enter.
A small box with a list of devices appears in the middle of the screen.
Press the down arrow key to highlight USB Emulation.
The default setting is On.
Press the Space Bar on your keyboard to change the setting to No Boot.
Press the Esc key.
The small box disappears.
Press the Esc key again.
A small box with list of options appears in the middle of the screen.
Make sure that Save Changes and Exit is highlighted in blue.
Press Enter.
The system will then restart.
The recommended changes have now been made to the BIOS.
2. Reset the Dell Dimension desktop System Setup (BIOS) to factory defaults.
Restart the system.
The Dell logo screen appears.
Press F2 to enter the System Setup (BIOS).
The System Setup screen appears.
Press the ALT + F key combination.
Press the Esc key to Save and Exit.
Press Enter to Save changes and exit now.
The BIOS is now set to the default settings.
Apr 02, 2009 | Dell Dimension 3000® Pentium® 4...
I can viwe only small space in screen before it was half screen
I can guarantee to fix this tv for $400-900. I have all good boards and know the procedure to determine which board is bad.
Nov 04, 2008 | NEC PlasmaSync 50MP1 50 in. Television
I've been trying to download a full screen desktop (wallpaper ... I don't know the difference) for months. All I get is a small picture so I therefore, have about 5 small pictures of Barack and I want a...
Here are a couple of wallpapers I found, simply click on the link....when the image loads, right click it and select "Set as desktop background".....that should do it for you!
1: http://magdelene.files.wordpress.com/2008/02/barack-obama-08-desktop-wallpaper.jpg
2: http://nostromus.files.wordpress.com/2008/03/obama-wallpaper_change.jpg
3: http://obamamedia.files.wordpress.com/2008/03/change-we-can-believe-in-1024px.png
Also , if you want to use one of the wallpapers you downloaded before (the small ones) you can stretch them to be full screen by following these instructions:
  1. Hit the "Start" button
  2. Goto "Control Panel"
  3. Double click the icon that says "Display"
  4. Click the top tab that says "Desktop"
  5. In the middle on the right is a drop down box that says "Position" , select the "Stretch" option.
  6. Hit OK
Sep 29, 2008 | Computers & Internet
Small screen
Could be the software is meant to run that size. i don't see any other reason.
if you kindly explain the problem more....
Jul 08, 2008 | Dell Latitude D800 Notebook
Hi text size small and web pages in middle of screen , tried changing text size but doesn't work . tried system restore and says it didn't work properly. many thanks for any help
Top of web-page Click View ( then text size to suit )
Page in the middle of screen, click Full-Screen Icon ( Top right of page ) Square Box.
Or highlight corner of Page and Drag To required Size.
Mike @ compurepair.
Mar 07, 2008 | Computers & Internet
Konka DLC-3211UT 32 in. LCD Television Logo
20 people viewed this question
Top Konka Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
