Sansa express battery
My sansa express is 5 ear old. Used quite regularly until last december. Then totally discharged and kept idle till date. Now battery swollen and compartment bursting 9wont close) although still plays excellently. Please help... i am too passionate about this since its my first gift from my husband
    Problem Solver:
  • 5 Answers
Simply change the battery
Posted on Mar 20, 2014
SOURCE: SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
Thanks Guest:
The battery did recharge after I did those things. After it had charged; I made a special effort to pay particular attention to what was happening. The one special note is that this mp3 player turns itself on when it is pushed into the USB port and charges. I turned computer off one day after having it to charge overnight and I left it in the usb port for the ramainer of the day and when I did take it out of port...it was drained again.
Posted on Jun 02, 2008
shivam4529
  • 150 Answers
i tell you connect to the computer your device
and right click on your device and format it
Posted on Jun 11, 2008
SOURCE: Bad Track
thanks it ******* worked awesome.
Posted on Sep 26, 2008
SOURCE: the left ear of my headphones does not play when
sounds like a broken earphone jack - contact their tech support.
i believe it's 1-866-726-3475 :)
Posted on Mar 30, 2009
anujtaluka
  • 392 Answers
SOURCE: Sansa Express 2.0GB Mp3 player stopped playing. Battery is okay
Insert a microSD in the slot and then try turning it on....
Posted on Sep 11, 2009
Tip
NiMH batteries do not have memory effect. However, unlike NiCads, new batteries...
I'm not certain which camera models this applies to, but definitely quite a few:
Many of the camera makers to not emphasize that after your rechargeables become low, you still have to use the "discharge" function while in your camera, to drain them adequately, prior to recharging. Otherwise, the "memory" in the battery on how much charge it can take gets lower and lower. If that has happened, try the "discharge" function, which will restore full charge capability
on Mar 29, 2008 | Fuji FinePix S7000 Digital Camera
How can I tell if battery discharge is due to battery or alternator
What year and model is your BMW. How old is your battery? More than 3-4 years, may be past best by date. Once running does it keep running? Lights work? Does the battery go dead if the bike sits for a week or more? Was it kept charged when not in use? If yes to the above, battery is probably no good. If the alternator isn't working, your bike would run for a while after charging your battery, then die. The lights should become brighter as the rev's are increased from idle.
Mar 21, 2013 | BMW Motorcycles
2005 Ford Taurus low idle
Replace the idle valve with a factory one and remove the negative battery negative cable for 5 minutes to reset the idle control system to base line settings.
Oct 17, 2012 | 2005 Ford Taurus
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
I believe the mp3 player's charge to last for 15 hours. It is only holding a charge for about 5 hours
Ifthe recharageable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 26, 2011 | SanDisk Sansa Clip MP3 Player
NUMBERS ON BLOCK
Hello there:
Casting dates are usually expressed this way, “C 18 4.” In this example, the “C” means the month of
March, “18” is the day of the month, and “4” is the last digit of the year. This last digit may mean ’64, ’
74, ’84 or ’94, so you must also check the other characteristics of the block to determine in which
decade and year it was made. Some parts have the decade and year cast on them; these identifiers
look like this: “C 18 84.” GM introduced new model years in September or October of each year, so
when you see a casting date of “L 16 7” for example, this indicates a casting date used in the 1968
model year because it translates into December 16, 1967. A 1968 model Camaro assembled on
January 6, 1968, might contain a number of parts that were cast in December, 1967. Casting dates
should precede hand-stamped engine assembly dates.
Nov 20, 2009 | 1990 Chevrolet Corvette
Braun shaver won't charge
Batteries have an expiry date, Even if you're not using them they are still discharging. Even the regular AA type you buy at the shops.
Batteries can die even if there is a lack of use. And even regular rechargeable shavers that are used all the time have only a limited life a little shorter that=n what you've had.
Should you get new batteries or a new shaver? probably not, you're using 2-3 times a year. I'd recommend buying a cheap Braun or Remington that can take AA's.
Apr 07, 2009 | Braun Health & Beauty
Toshiba a75-s125
It sounds like your battery is out of time. Buy a new one.
Nov 21, 2008 | Toshiba A75-S125 Satellite Notebook
Samsung YP K3 only lasts for 2 hours
1. totally discharge the battery so it wont come on.
2. Charge the battery fully
3. Reset the player
Now check how long the battery lasts. If it is still 2 hours there is a problem with the battey and you will need to return the player.
Oct 29, 2007 | Samsung YP-K3 MP3 Player
49 people viewed this question
 Grubhead
Grubhead
