Windows cannot be installed to this disk. This computer's hardware may not support to the disk. ensure the hard disk controller is enable in the bios menu
    Master:
  • 397 Answers
If it's supported by your system have you tried enabling or disabling ACHI?
Posted on Mar 20, 2014
2 Suggested Answers
  • 18 Answers
SOURCE: im trying to install windows vista but its not
To resolve this problem, follow these steps:
  1. Create one or more partitions on all the hard disks that are not initialized.
  2. Restart the computer.
  3. Install Windows Vista.
Microsoft Support Link to article
Posted on Jan 12, 2010
I need driver for diamondmax 21
Turn the computer off.
Turn the computer on, and press <DEL> to enter BIOS SETUP.
Ensure that the hard-drive is "enabled", and set to 'AHCI'.
Save the BIOS settings.
Reboot, and install Windows.
May 03, 2015 | Seagate 250GB Maxtor DiamondMax Plus 21...
Won't Record
Did you format the disc with the unit or with a PC?
Feb 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Tip
INSTALLING WINDOWS XP ON A SATA HARD DRIVE
SATA HARD DRIVE ? XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP.
The FIX.
Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
If enabling the SATA in the BIOS does not allow the computer to boot up with SATA hard drive then change the BIOS back to what it was previously.
on Mar 14, 2010 | Computers & Internet
Disk wil not format/keep dipaying format fail
hi .. nt sure whether your talking about an external hard disk or somethingelse..
But here goes
In detail
Causes
  • If the hard drive is not setup correctly in the BIOS or is not jumpered correctly, this may cause the BIOS and Windows to detect the drive incorrectly.
  • Viruses or spyware program are capable of conflicting with Windows programs such as the format utility built into Windows.
  • If the partition on the hard drive is corrupt or damaged, this would cause Windows to stop the format process or show an error message.
  • If the computer system does not have the latest BIOS and hardware drivers, and the operating system does not have the latest Service Packs installed, Windows may not address or recognize the drive parameters correctly.
  • You are attempting to format a partition larger than 32GB as FAT32 in Windows 2000, XP, or 2003., win7
  • If the hard drive or data cable is physically damaged or defective.
  • There may be a conflict between the hard drive and another device (on the same IDE cable).
Solution please try
It is recommended to low-level format the hard drive to resolve any partition corruption issues that may be present. For directions on how to low-level format a hard drive
If it's an internal hard drive, please ensure that the latest BIOS is installed for the computer, motherboard, or PCI controller card. BIOS updates can be obtained from the computer, motherboard, or controller card manufacturer. The BIOS should be setup to Auto-Detect the hard drive. If there is a Mode option, this should be setup as LBA, Large, or Auto
  1. Ensure that the latest drivers are installed for the hardware in the computer. Drivers for the hardware should be available from the respective hardware manufacturers.
If this occurs on an external hard drive, connect the drive to another USB of FireWire port on the computer. You can also connect the hard drive to another computer system to perform the format. This issue may be caused by attempting to reformat a FAT32 partition as NTFS without deleting the partition first. You will need to repartition and reformat the hard drive
hope this helps you out
Aug 28, 2014 | Electronics - Others
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
BLANK SCREEN FLASHING CURSOR
Ok, here is my next dilemma. I got the install disk and it gets to the point of asking where I want to install windows. The only option is Disk 0 unallocated space with 149 GIGs free. The 3 options I have are Refresh, load driver and Drive options (advanced). What do I do from this point? It says that this computer's hardware may not support booting to this disk. Ensure that the disk's controller is enabled in the computer's BIOS menu. I am stumped at what that means.
Oct 05, 2012 | HP Compaq Presario CQ50-130US Notebook
I am trying to install SBS 2011 (Win Server 2008 R2 OS) on an IBM x3400. I have created a Raid 1 (mirrored) array. When partitioning the RAID to install we get the message "Windows cannot be installed...
A few questions:
1. Is this a new (clean) install? If so, have you installed the drivers for the RAID controller BEFORE you install the os? Most of the time Windows will ask for this as the os check your sysem. (You will see at the bottom of the screen "if you have a 3rd party controller and need to install drivers, do so now" or something to this effect.
2. If you already have an os on this system, (Server 2008) you may need to check the the HCL for SBS 2011 to make sure you hardware is correct for the install.
Good Luck
C2Solutions
Aug 11, 2011 | IBM x3400 Server
My laptop doesn't recognize my 80gb harddisk. The light goes on but it down't show in My Computer or anything. What can I do?
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 18, 2011 | Freecom 80 GB USB 2.0 Hard Drive
I just recently installed this motherboard and wiped my hdd clean. I'm now trying to install a fresh version of windows 7. When i try to install the OS to my C: drive it says "Windows cannot be...
It sounds like maybe the hard drive is not in the boot order in the BIOS. You can get into the BIOS by hitting F2, F10, or DELETE during POST (it should say which key to hit to enter setup.) Once in the BIOS (looks like an old DOS menu system) you'll want to look for the boot device priority (you may have to look for a while before you find it.) Once you do, just make sure the hard drive is the second item in the list after hte optical drive and try again
Mar 01, 2011 | Gigabyte GAMA78LMTS2 Socket AM3 AMD 760G...
Im trying to install windows vista but its not leting me its saying "this computers hardware may not support botting to this disk ensure that the disl controller is enabled in the computer bios menu"
Jan 12, 2010 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
