Question about Memorex MVDT2002 20" TV
My tv is the memorex mvdt2002b 21in with the vhs and dvd,it plays the vhs and dvds just fine and also displays the guide and programs for cable but will not show the picture,the prodlem is only with cable channels. jared
5 Suggested Answers
SOURCE: memorex tv programming
I am trying to start remote ucr3110B00 on memorex MT 1120A please help me.
Posted on Dec 30, 2007
SOURCE: memorex mt2024
try 1234, 0000, 1111, 2222, etc
Posted on Jul 23, 2008
  • 8 Answers
SOURCE: 27" Memorex MT2274 won't play blu ray player
Chances are, you are trying to view on the station set for your VCR or other peripheral equipment, such as channel 3 or channel 4. You need to be sure that you have your TV set for on one of the two auxillary stations, instead, which will show up on your TV as "Aux 1" or "Aux 2."
Posted on Mar 15, 2009
gopakumarg43
  • 75774 Answers
SOURCE: Our Memorex model #MVDT2002B, SH
Hello
There is a protection fuse inside your tV, which can be located at the power regulator section, to which the main power cable enters to the board. It is a class cartridge type, and can be replaced. Check it first. If found blown off, replace it with an other with same rating; which will be marked on its end metal caps. Never use an other rated one in place. Switch on your TV, while its back cover opened, and watch if the newely inserted fuse also blo up. if blow up, certainly there will be some short circuit inside the circuit board, which occured during power surge. Check these and inform me if the fuse blows again. I'll assist you further. Let me know the result by Fixya. OK.
Posted on Apr 06, 2011
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
Can't play finalized DVDs dubbed from VHS on other Sony DVD players or PC
It sounds like the disc were not finalized properly. Are you sure the player finalized the discs?
Apr 08, 2008 | Sony RDR-VX500 DVD Recorder/VCR
My dad just purchased a 2004 memorex t.v. with built in dvd and vhs players. He wants to know if he could record a vhs to a dvd on t.v.
No,the DVD player build in tv can't record,only play DVD Disc only.Want to record personal VHS tapes only to DVD Discs,must have a seperate device unit VCR/DVD RECORDER device player not a device unit VCR/DVD PLAYER.Connected to the tv record VHS tapes to DVD Discs.
Mar 14, 2011 | Memorex Televison & Video
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
We just bought a new 32" panasonic led tv. Hooked everything up and works fine with normal television broadcast. However, we have a Sony DVD/VHS combo hooked up that doesn't perform well. When we play...
If you are using the composite cables (RWY) make sure the red and white are plugged into the audio jacks and NOT the component cable plugs (RGB.) If you have the red audio cable plugged into the red component plug this will cause issues, especially with the sound.
Aug 10, 2010 | Panasonic Televison & Video
I can play dvds but not vhs. how do i hook it up or program it, etc, so I can watch vhs?
Hi dave
To answer your question;
In order to watch both the dvd and vcr on the same tv input , you need to use the dvd/vcr output of your jvc.
The component output is for the dvd only.
So if you want to keep the component output for high definition when playing a dvd you can connect another rca cable from the dvd/vcr output of your jvc to another input on your tv when playing vhs.
If you want the owners manual online you can find it HERE
You`ll find all the info on page 11
Hope this help Good luck
Apr 27, 2010 | JVC HR-XVC19S DVD Player/VCR
New DVDs - New Problem
Same speed U bought 1-4x 1-8x 1-16x make sure have same speed disc.
Dec 17, 2009 | Sony RDR-VXD655 Recorder
VCR will play, but not record.
You gotta connect the signal cable to the input of the vcr and in the output of the vcr other cable to the tv input,when you got to record some program you need put the channel number on the vcr not in the tv if you conect the vcr to the tv in the avinputs the tv will be in video mode,because the vcr receipt the signal.
Good luck
Apr 13, 2008 | Samsung DVD-V5500 DVD Player/VCR
The insigina combo
i would check the tv TO DVD/VHS COMBO connections OR REPLACE OLD AUDIO VIDEO CABLES especially if the tv plays clearly.
Dec 11, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
The DVD will play and display, but the VHS will play but not display.
It could be that the output to TV from VHS only works through the composite cables (the red, white, yellow).
Dec 11, 2007 | Samsung DVD-V8600 DVD Player/VCR
Memorex MVDT2002 20" TV Logo
69 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
