Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Tractor will roll in neutral but will not drive when put in gear. Will not roll when in gear.
I had a similar issue when I first got my tractor. the problem was with the linkage in the transmission just behind the lever you engage or dis-engage to make the mower roll freely ( on mine it is on the lower right, next to the rear axel- brassish in color ) what I noticed was when I changed to position of that lever the linkage in side didnt move all the way ( kinda like how a cars door lock/latch might stick) anyhow I was able to press the linkage forward by using a long-large standard head screwdriver in side of the notch where the lever protrudes thru the transmission ...the slight click in place cured my issue hth
-p
Posted on Jun 27, 2009
  • Debra Wirkner-Vance
    Debra Wirkner-Vance Apr 11, 2014
    WE tried that - push, pull both ways.
Transmission issues on a 2003 Buell XB9S Lightning.
sounds like shift lever adjustment problem
take it into a service center and have it properly diagnosed and a quote
Sep 09, 2016 | 2003 Buell Lightning XB9S
Craftsman 917273482 will not shift into gear, and I can't push it because it won't disengage
If there is too much play in the drive belt due to belt stretch or linkage wear, the belt will be too loose to drive the tranny but still cause the tranny input shaft to rotate preventing it from being put into gear.
Do the gears grind when trying to put into gear? With engine off you should still be able to push the machine if you put it in neutral. Unless, of course it is a hydrostatic transmission, in which case there should be a lever to push/pull which will put the hydrostat in neutral. This is all assuming that it is a hydro and while running the machine won't move when putting the drive lever into forward or reverse.
Mar 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My 1992 wrangler won't roll at all. It starts fine, and stays running but when I try to put it in gear it stalls out. Even in neutral, I can't seem to push it to get it rolling. Any suggestions?
This sounds bad, even in neutral it stalls, you cant even push it. i would start by putting the transfer case selector in neutral and see if it rolls, if this jeep is only two wheel drive then start by jack the front wheels up and do this for the four wheel drive also, this is to see if its in the trany or the wheel, check and see if you can spin the wheels in the front, if this is two wd then if the wheels dont spin then you have a problem with the brakes but what concerns me is that it stalls in neutral, i would have to say the problem is in the trany and if this is a stick shift trany i would say the clutch broke and will not release but when its in neutral it should roll. anyway do the same in the rear wheels, jack them up and see if the wheels move, if they dont then remove the driveshaft at the rearend and then see if the wheels move. if the wheels turn with shaft off then theres a problem with the trany oor transfer case if its 4wd, if its 2wheel drive then its something in the trany, if the wheels dont spin with shaft off then start truck and see if it still stalls but dont let it go into gear with driveshaft off you will not be able to stop driveshaft when disconnected, just see if it stalls in neutral. good luck.
Mar 13, 2011 | 1992 Jeep Wrangler
04 Envoy won't go into reverse. When put in reverse just sits there. When put into neutral starts to roll forward as if in gear. It drives in neutral as well as the other gears.
The linkage from the selector in the car to the selector on the transmission needs to be checked. This is a physical problem and inspection should reveal what needs to be easily adjusted or straightened out to fix it.
Sep 02, 2010 | 2004 GMC Envoy
I'm driving an automatic gear car. At traffic light, do I put gear to neutral and pull handbrake, or do I continue to step on the brake. Any difference on either action.
just keep your foot on the brake. It cannot do any damage, the auto box is designed for this
If you put in neutral you risk making a mistake and selecting reverse. or may not select gear inadvertantly on a hill and roll backwards.
May 27, 2010 | Toyota Yaris Cars & Trucks
I have a 1992 gmc sierra 1500 and i put in in
Why are you putting it into drive while you are rolling backwards? That is a big NO NO. If you are at a stop and put it into drive and accelerate, and nothing happens, then your trani needs to be rebuilt.
Nov 10, 2009 | 1992 GMC Sierra K1500
Transaxle locked in gear won't roll freely in neutral
Sounds like the pins in your brake caliper have gotten dirty and/or rusty and are not releasing all the way. When I had my shop, we found a lot of these and I or my mechanics pulled and cleaned them then took a drill 1/64th larger than the pin and ran it through the holes in the caliper, NO MORE PROBLEMS!
Check your tire pressures, too, if they are low it will be difficult to roll.
Sep 14, 2009 | Garden
Car wont roll forward or back even in neutral
I assume it's a manual transmission.
If the car will not roll backward or forward in neutral (with or without the clutch engaged) the transmission is most likely locked in two gears at the same time.
This may happen if gear selectors are excessively worn. If you are able to examine the gear selection levers external to the gearbox, ensure they are in the 'neutral' (no gear selected) position when the gear lever is in Neutral. If not in correct position, you may be able to manually reset the levers to correct neutral position and thereby unlock the gearbox.
In any case, if it's happened once, it will happen again, so get the gearbox and gear selection mechanism checked for wear or breakage.
Jul 31, 2009 | 1997 Subaru Legacy
1997 ford explorer rolls/creeps forward while in park
linkage is off, not starting in park, neutral safety switch maybe bad
Nov 26, 2008 | 1997 Ford Explorer AWD
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
210 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
