Question about Refrigerators
Samsung cooltech fridge freezer
Hi, my sumsung cooltech fridge freezer is dripping water from the front internal vent. The evaporation tray is empty and dry. I think the problem could be a blockage, please advise on how fix
SOURCE: Dripping water inside
At the back of the refrigerator, you will find a evaporation tray, unscrew it and empty it.
Posted on Sep 06, 2008
  • 6 Answers
SOURCE: freezer drips water into frigde filling up ottom tray
Hello, If it is a top mount freezer then there is a drain that runs from the freezer to the drain pan that gets gummed up sometimes and if that happens then the water has no place to go but the fridge. Look all the way in the back of the fridge and you'll see a yellowish colored tube. You can just pop that out and take it to the sink and clean it out.. Hope this helps
Posted on Feb 18, 2009
diodeic
  • 1622 Answers
SOURCE: hi i have a samsung cooltech fridge freezer and
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope that this will helpout in solving the problem.....
Posted on Dec 09, 2010
heatman101
  • 43501 Answers
SOURCE: I have just defrosted the
Yes, it is to have water in it...the coils evaporate the water and the water helps the refrigerant system to work a bit more efficiently...
Do not worry about it the water is good!! :-)
heatman101
Posted on Apr 19, 2011
Testimonial: "That's great thank you for your prompt reply - I feel reassured now :-)"
  • 56 Answers
SOURCE: I have a Samsung Cooltech Fridge/Freezer.....I changed the internal light bulbs and have no Internal light....what do I do ?????
before I sugest an idea I will ask you to make sure the new bulbs are not damage you can make a test with anything you may have at home that requieres a bulb less than 100 watts.if the new bulb is working unplug the fridge and try to pull out the center of the socket were the bulb rest is a small metal plate.use a pen,pensil plastic knif or regular kitchen knife tu open it but no to break it all the way just make sure your fridge/freezer is completly UNPLUG FROM THE POWER OUTLET
Posted on Aug 12, 2012
My Samsung SRL550DW keeps cutting out. If you turn the power off it restarts and works fine and then cuts out again after a few hours. Is this a main PCB problem. Prior to this happening the door chim
I have had the exact same issue and its not a samsung issue but any modern fridge with a defrost system in the freezer (fridge doesn't generally frost up as its not run at freezing temperatures.
You need to check a few things:
1. Clear the freezer draws out and clear any ice build up.
2. Be careful and unclip the first white plastic vent panel (hint: pull from the middle an inch or two then push the sides in so the tabs are pulled towards the middle and the panel pops out)
3. Unscrew and unclip the 2nd panel (holds the circulation fan) to view the freezer coils - you will need to unclip the power for the fan and the heating coil for the drip tray under the freezing coils.
4. This is where the issue usually is:
If the tray is full of ice then do the following. If not and you can poor water through the drain hole on the bottom, then the issue is a dead sensor or control board - seek professional advice or if your game, there are swap out kits you can buy.
So the drip tray is full of ice ? Unscrew the freezer coils from the back wall but DO NOT touch it any further in case you damage it. There should be some silver tape tape that holds the tray in place - remove it and then gently lift the coils up to allow the tray out. If its too full of ice, use a hair dryer or warm water to de-ice. Once the tray is out, defrost it completely and dry it - be careful not to damage the heating wires under the tray as this is used to deice it during a normal defrost cycle. Clear any remaining ice on the coils or along the back wall - Dry it well.
Usually the cause for the drip tray to freeze up is a blockage in the drain pipe that empties into the back of the fridge. Unscrew the back panel and you will see 2 soft plastic pipes drain water into a water tray. pull both off and clean/inspect. You will notice they pinch in the middle to stop air getting back in, but allows water to drip out. If they are blocked, they will back fill the internal drains and freeze, thus fooling the fridge into thinking it hasn't defrosted yet and not turning the compressor back on. (Since this ice is hidden at the back, it is the last to melt thus the freezer gets warmer waiting for the insulated ice near the drain to melt.
When I did my freezer, the water is dripping out slowly (it was cold) but once I removed the pipe, it emptied properly. inspection of the pipe showed dirt/insect blocking the pinched section of the pipe.
Reassemble the pieces in reverse order, ensuring the water was been dried with a cloth. My fridge/freezer hasn't skipped a beat since.
May 07, 2012 | Refrigerators
Water is dripping from the bottom of the fridge (slow drip). How do I fix it. I have a Maytag French Door stainless steel fridge (4-year-old) with freezer on the bottom.
There should be a drip tray catching the defrost water... it may be overfull... Try to remove it and empty it. The tray is actually supposed to have a heat evaporator to dry up the water before it overflows. Your may be fuller due to excessive frost also... from hot temperatures outside or opening the fridge too often or for too long... good luck!
Jul 24, 2011 | Freezers
I have just defrosted the freezer and water was pooling underneath, so I emptied the drip tray. I noticed that on the bottom right hand corner there is another tray with copper piping inside. This was...
heatman101
Apr 19, 2011 | Refrigerators
It has a nasty smell like diesel fuel in the freezer but it works fine.
Your cooling unit may have a leak, and you are smelling the coolant, though normally this would be ammonia.
You may have food that is spoiling as well. Check the condensate / drip tray at the back of the fridge (inside). Look for water building up (likely green as well). If water is not draining, clean the hose that leads from the drip tray to the exterior back of the fridge. There will be a small evaporator cup / tray that the hose empties into. Check the end of the hose for insect activity. Note that it is normal for the end to be crimped, or it may have a plastic plug (perforated) inserted as well.
May 31, 2010 | Thetford Norcold RV Cooler/Freezer
WATER LEAKING FROM FREEZER VENTING INTO FRIDGE
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 12, 2010 | Refrigerators
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
Jun 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water dripping from top of fridge then freezing under crisper's
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
We own a samsung cooltech plus, something, something. The freezer is working fine, but the fridge's temperature suddenly jumped from 3 degrees celsius to 9 degrees celsius. We can't seem to change the...
Im no expert, but you can try this, take the back bottom cover off and you will see two drairn pipes going into a drip tray. remove those pipes ( just pull them down ) make SURE they are not blocked ( there is a rubber thing at the top that can close up--- just cut it open ) place a bucket under those pipes and leave your fridge off and the doors OPEN........ it may take a couple of days for ALL the ice to defrost. when you think its done--- leave it a few hours and if there is any water being collected --- you still have ice in there. i was amazed at how much and for how long water kept dripping out of the fridge drain pipe.... the pipe nearest to the compresser is for the frezzer, If the sensor that tells the fridge to get cold is all iced up it wont even try to get cold--- it thinks it is already.
Dec 18, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Jul 19, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
