Question about HP Designjet T610 InkJet Printer
Hpt790 staying at 94% initilising for too long
Its making some noise as if its failing to hook up with some things in side.
  • HP Master
  • 1,121 Answers
Star wheel motor assembly broken. HP part no Q6718-67017.
To confirm: Enter in to diagnostic menu as
Entering the Diagnostics Menu
1. Make sure the printer is switched off with the Power key on the front of the printer and not with the power switch on the back of the printer.
2. Press and hold the Up and OK keys. While holding the Up and OK keys down, press the Power key to turn on the printer, then release it while continuing to hold down the Up and OK keys. Wait until the HP logo appears in the front-panel display, then release all keys.
3. In the Diagnostics menu, select a diagnostic test with the arrow keys and press the OK key to begin the highlighted test.
4. Select scan axis > enter ok
5. Select star wheeler lifter > enter ok
follow the message.. check for the result.. If its OK then start wheel is good.. If any error persists.. you need to replace star wheel unit..
Only professional can do the part replacement, not suggestible to user to replace this part..
For technical guys:
1. Power off the unit, remove power & data(USB/Network) cable.
2. Remove formatter & housing
3. Remove front cover
4. Remove screws(Left cover)
5. Remove left side panel(ch 538-67005)
6. Remove pinch arm leaver
7. Remove left cover
8. Remove spit on
Follow the snaps: hpt790 staying at 94% initilising for too long - 9c6ef43c-a766-4620-8f8c-e3b95b9387cc.jpg fa8b1961-8828-404a-a635-46fd6634e5aa.jpg 586b962e-67e2-4410-9f34-e11f21f4a29f.jpg eb8f62hpt790 staying at 94% initilising for too long - 035896bf-a3cf-4516-969e-cde6edebd47c.jpgs= cf0cabdb-7f73-43de-b9a8-5fffcf345e20.jpg 3915469b-2f28-4183-850d-560afe1edc61.jpg 035896bf-a3cf-4516-969e-cde6edebd47c.jpg
Best of luck....
Posted on Mar 20, 2014
Service engine soon comes on and stays on, idles too fast and fast idle solenoid makes noise after turning car off
Check the engine computer again for trouble codes, you may find the idle speed solenoid has failed, there is a vac leak, or the throttle plate is sticking open.
You should be able to check a 94 model yourself using the ac control panel on the dash.
The procedure and code list is available online.
Mar 27, 2015 | 1994 Cadillac DeVille
Ihave 94 chevy camaro v-6..just replaced alternator and 2 out of the 3 wires hooked into the clip on the top side of alternator have come out of clip, red n black ones, the one wire thats still attach
Auto zone has free repair guides on the site. Make a free account and put in the year make and model and then look at the electrical diagrams. It is doubtful that the alternator is causing your lack of power though
Jul 29, 2017 | 1994 Chevrolet Camaro
Fluke 1651portable multifunction tester is displays Err 1
Error 1 is an indication that the self test has failed. This will require repair at an authorized Fluke service center. There is an internal problem with the meter. The only thing that you can try is to replace the internal battery. Should the battery be defective, the internal testing can be effected. I have only seen this occur once, but it is worth the attempt. Should a new battery not fix the problem, return the meter to Fluke for repair.
Dan
Apr 15, 2010 | Fluke Networks Fluke T+PRO Electrical...
My 94 plymouth voyager sounds and acts like a wheel bearing humm. i've replaced front and rear wheel bearings and the humm is still there.
I'd certainly rotate tires to see if noise changes at all, as well as take a good look at tread on front tires, especially for excess or unusual wear on edges, especially outside of right front, if your quite sure the noise is coming from the right side. Does the noise increase, decrease, or stay same, on a left hand turn? Another thing would be to check all motor, and transmission mounts and see if it looks like things may have shifted slightly, or if they appear worn or broken, as well as If engine/transaxle has shifted slightly it can cause similar noises as well. As far as left front bearing goes, I wouldn't rule it out 100% either, unless you are positive noise is from right front area. You have to remember, either way you turn the wheel, will slightly shift either bearing if there is play in it. Rule out easy stuff first like tires.
Apr 01, 2010 | 1994 Plymouth Voyager
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whining noise
Could be a few things:
Belt slipping- adjusted through tensioning bolt on bottom of power steering pump
Pulleys- take off belt and hand turn pulleys. Find one that gives resistance and possible makes the whining noise. It's probably the idler pulley.
Feb 12, 2009 | 1994 Jeep Cherokee Country
HP Designjet T610 InkJet Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
