Question about Winter Sports
My dell laptop d510 was wiped now it says no bootable device no boot sector on internal hard drive
It just says no bootable device
  • 31 Answers
SOURCE: no boot sector on internal hard drive
If the bios or setup utility can't detect your hard drive then this can be a physical problem. I suggest that you reseat or tighten the cable connecting your hard drive to the motherboard. You need to open the hard drive panel then unplug and replug the hard drive cable.
Posted on Jun 10, 2009
  • 336 Answers
SOURCE: no boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Posted on Jul 29, 2009
bob_computer
  • 3153 Answers
SOURCE: ''No boot sector on internal hard drive'' message on INSPIRON 6000
It does sound like the hard drive has died but the only sure fire way to check that is to remove it and try it from a proper PC using a cheap 2.5" enclosure.
If a normal PC can read it then it is more likely to be the hard drive controller on the motherboard which can be an expensive repair.
You can always get another drive if yours is pooched and you are not limited to the same size, You could get a larger one
You will however need an operating system.
Posted on Aug 14, 2009
SOURCE: From Dell a "new" refurbed hard drive. ''No boot sector on intern
Go here and choose operating system. skip the first bit about backing data up. You should have an Operating sytem CD and a driver/diagnostics CD.
http://support.euro.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=75911D39302C7A64E040AE0AB5E13D7E&docid=361935&type=force&lx=179256&lv=339949&l7=362048
Posted on Oct 10, 2009
  • 916 Answers
SOURCE: Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Posted on Oct 27, 2009
No boot sector on internal hard drive. No bootable
Windows Vista
7.
Regards,
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
No boot sector on internal hardware
There are several causes for this. First make sure the Bios recognizes the Hard Drive as the Primary Hard Drive. Second, double check to be sure the drive is properly seated and connected . If these are both done and set properly your drive has either been erased or lost it's master boot record due to a Virus or Error. You can try using the Windows recovery system to recover the boot sector but I would simply use system recovery and format the drive and reload it to factory specification.
Nov 12, 2011 | Dell Latitude 110L Notebook
Follow this procedure if the hard disk is detected. Insert dos bootable cd with fdisk in your DVD ROM. At the dos prompt a:\>fdisk/mbr
and press Enter. Your boot record will be restored.
Sep 13, 2011 | Dell Latitude D510 Notebook
Dell inspiron 1525 shows black screen after dell logo?
The computer cant find a bootable device. Either your boot sector on your Hard drive is gone/damaged (most likely a virus) or the Hard drive failed. Start with booting with your windows disk and try to do a repair installation.
Nov 03, 2010 | Dell Inspiron 1525 Notebook
Won't turn on
Oct 27, 2009 | Dell Inspiron 1521 Laptop
I have just rep[laced my hard drive on my laptop (dell inspiron 6000) and have a no boot sector on internal hard drive / no bootable devices on the screen. what do i do next to fix this?
You need to run your installation/restore CD/DVD that came with the Dell. If you do not have them, you can order them from Dell for a nominal amount.
Jun 29, 2009 | Dell Inspiron 6000 Notebook
No boot sector on internal hard drive no bootable device-f2 for setup utility
Jun 10, 2009 | Dell Inspiron 6000 Notebook
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Winter Sports Logo
80 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
