Question about MotorGuide Electrical Supplies
I have a motorguide magnum 748, trolling motor and need a 50 inch shaft. New boat is higher in the water and 42 inch shaft isn't long enough. help!!!Are all the lower shafts from motorguide the same, threads,etc.
5 Suggested Answers
  • 64 Answers
SOURCE: how to replace shaft
STOP THE MOTOR! OPEN IT AND TKAE OUT AND REPLACE NEW ONE!~
Posted on Nov 04, 2009
SOURCE: wanting to install motorguide 24v trolling motor
I have installed a selectable 12/24 volt trolling motor on my boat. When in the 24 volt mode, the motor works well for about 3-4 minutes the loses all power. After about a 15-20 minute "cooling off period" the motor will work again for about 3-4 minutes. In the 12 volt mode, the motor works well all the time, only at about half the speed of the 24 volt mode. Why is my motor losing all power in the 24 volt mode?
Posted on Mar 30, 2010
SOURCE: motorguide t47 powerplus trolling motor
t 47 power plus motorguide prop wont turn but you can feel the power going to motor to try to turn it
Posted on Jan 01, 2011
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
Great white wont turn motor runs but wont turn
Do you mean you can hear the motor turn but the propellor doesn't turn?
Then check the break-pin of the propellor. It's a security device that will break when the propellor hits an object in the water...
Sep 27, 2016 | MotorGuide Great White Saltwater Series...
The first thing to check,(After making SURE the electricity is disconnected to the trolling-motor) remove the propeller and see if the shear-pin (Usually made of brass) in in place and not sheared/broken.
If it is, your local marine shop should be able to provide a new one. I always carry spares. If the pin is OK, the windings may have an electrical fault that would require a factory-repair.
Sep 05, 2014 | MotorGuide Transom Mount Great White...
My motorguide trolling motor keeps tripping the 50 amp in line breaker every time I turn it on high speed. It is a 75 lb thrust digital tour model. When I take it out of the water and run it on high...
All motors will draw higher amperage with varying loads. Your hi speed motor winding has probably shorted some its winding's without having gone to ground. It probably needs to be replaced to get your hi speed back. I have run into similar problems in heavy commercial hydronic pumps. Best to have mechanic check it out. An OHM test with factory specs. will tell for sure.
Sep 04, 2013 | Electrical Supplies
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Motorguide t47 powerplus trolling motor
Jul 06, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Wanting to install motorguide 24v trolling motor in boat will it work on just 12 v system
It should but may not run at it's intended potential. It may also run your battery down a lot quicker.
May 13, 2010 | Electrical Supplies
Electrical Supplies Logo
693 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
