Videocon tv old model 30 channel tv showing horizontal line
  • 61 Answers
May be issue with horizontal Integrated Circuit issue.
Contact service center or nearest technician to resolve this issue.
Posted on Mar 30, 2014
Vertical color bars on half of TV, remain on black, 25v instead of 180v on CRT base, from LOT, 135 V ON LOT without CRT base connect, on videocon old CRT TV.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. Check all the supply smoothing capacitors. Use of a high quality digital multimeter is recommended. Low quality ones will show false voltage readings, at high frequency.
Oct 19, 2016 | Televison & Video
Videocon bazoomba tv circuit diagram
If it shows picture at first, and after some time displays a vertical line at the center of the screen, check the connector that goes to deflection yoke for loose connection at its bard end socket, and check all the solder terminals of capacitors at horizontal output section. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 14, 2013 | Televison & Video
What is the EHT No OF videocon tv model no 5128 R
EHT Not work m.5128 r videocon old model
Aug 31, 2012 | Televison & Video
Horizontal line comes with no picture when I switch on my tv (Videocon Bazoomba). What may be the problem?
The vertical sweep output section circuit to your TV is faulty. Check and replace all the electrolytic capacitors; 5 or 6 of them; at the vertical output section. Check for any loose solder terminals. Resolder the suspected solder terminals, by applying a little more fresh solder, without making any solder bridge short in between adjecent solder terminals.
May 31, 2012 | Vizio Televison & Video
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
My videocon tv 5137RU service code on my remote
Hai !...
Ther was a nothing problem to worried.
I want my old Vediocon (Model -5302R) Tv's
Remote model number. Because i lost my remote.
I want the solution. Pls help me.
Thank you.
Jan 11, 2009 | Televison & Video
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Samsung 42" HCM4216W Dim Horizontal line across screen
THIS HAS NOTHING TO DO WITH CONVERGENCE or any of the stk integrated circuits.There are few capacitors close to the vertical output ic, they are usually blue or red (could be 1000uf 50volts for e.g.)That where the problem is
Nov 03, 2007 | Samsung HCM4216W 42" Rear Projection...
Philips TV showing horizontal lines model 27pt6441/37
You likely have an elevtrlytic capacitor bad on the B+ line to the vertical ouput ic. If you continue to use the set like this it is likely the vertical ouput ic will fail.
Jun 26, 2007 | Philips 27PT6441 27" TV
TV Screen Problem
Turned on TV and all that shows up on the screen is horizontal colored lines
Jan 25, 2007 | Daewoo DSC-30W60N 30" TV
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
