Question about Kicker Car Audio & Video
Radio cut out above 20 volume
If I turn the radio up past 20 the car speakers cut out and the subwoofer is the only thing that plays is this an amp and subwoofer problem or should I check the speakers in the car
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 82 Answers
Your exceeding the output of the amp powering the main speakers. if you're using deck power, time to buy a full range amp to add to the sub amp. if you have an amp already, check to see if there's a thermal protection cutout. Mine has a light that lets me know its out due to overheat
Posted on Feb 20, 2015
Draco
SOURCE: when i turn my radio up all the way my speakers cut out and then come back on
i soundds like its too powerfull for them beouse some new speakers now have a shut off if they are ready to go out or blow to make sure you dont damage them
Posted on Jan 15, 2007
  • 12 Answers
SOURCE: Car Audio Problems-Amp cuts out
No the reson for the amp overheating is do to the OHM ratting that you have the sub if to have the both wired up then just wire  one up and that will give you the OHM ratting that your amp is ratted for the way that you might have it is the way that we wire them for coms. where it is on for 30sec and no more. if you would like more help let me know.
Gennisthgreat2000@yahoo.com
Posted on Oct 25, 2007
Zackd9184
  • 56 Answers
SOURCE: New car speakers cut out when I turn up the volume.
You just have to check all of the speaker wiring.It's a wire touching somewhere and it will do that till you fix it. What it is is just where the negative wire which is the ground for your spreakers it's touching the positive wire which is know as a power wire.When this happends it lowers the frequency of the volume which will cause the speakers to cut out and volume level to drop.
Posted on Dec 21, 2007
heavymetal77
  • 721 Answers
SOURCE: Subs cut out at low volume no matter the settings
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
Posted on Jun 20, 2009
  • 133 Answers
SOURCE: speakers cut off when bass goes up...
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
Posted on Jun 27, 2009
My radio cuts out when i turn it up and the bass hits on my subwoofer
You are drawing to much power to the amp. I assume that there is no dedicated power fron the battery to the amp. If there is you should look into a capacitor
Feb 13, 2013 | Car Audio & Video
I have a clarion m 309 radio and I'm trying to hook up a fusion FM 402 amp for a sub woofer. I had all speakers playing but, I could not control the volume of the sub with the radio. I need to know...
Amps usually receive their signal through RCA wires. Your radio should have one pair of RCA outputs on the back. (red and white) You will adjust your subwoofer volume by adjusting the gains on the amplifer (little knob next to the RCA inputs of the amp), then you can turn up the bass on your radio.
Sep 06, 2011 | Clarion Car Audio & Video
I hooked up a Sony deck and new Kenwood 12' subwoofers and amp that came together in a box set in my 95 Jeep Grand Cherokee and when I play the radio the stock car speakers play but the subwoofers are...
their should be a blue and blue white wire on the Sony radio. cut the blue wire and then connect the car side to the blue white wire and tape off the blue wire that is on the radio side.
the blue wire only turns on when the radio is activated. the blue white wire is activated when the radio is turned on.
please rate my solution.
Jul 02, 2011 | AudioBahn Car Audio & Video
Hi I have a sony CDX-GT500U car radio. The problem is that when i turn the volume up over 20 it cuts out. What can i do to fix this problem?
Check pos and neg wires on speakers and radio they may be crossed.Does the radio have bass to it or sound like tweeter
Mar 20, 2011 | Car Audio & Video
My alpine keeps shutting down when the volume is turned up past 20. Plus I have no sound coming out of my subs. I tried switching rca cables. And I sent my amp off thinking it was my amp. Their is a little...
so it turns off suddenly and then the next second it turns back on and starts playing
from that and personal expericance i belive that the radio system (radio and amp) is not reciving enough power
is this radio inside a car
if so what car
what i would do is attach bigger thicker wires to the positive and negative of the amplifier
direct from battery
positive of battery>>>> positive of amp
metal grounding point on car>>>>>> negative of amp
(do not use negative of battery use the metal of the car)
May 12, 2010 | Car Audio & Video
Very low volume output even with the volume turn all the way up. I connected the system to different computers and came up with the same problem. The volume on the computer is also turn all the way up and...
I had the same problem and found the root cause to be the RF speaker connector at the back of the subwoofer. The male and female connectors are OK. It is the 5 male pins inside the connector and the way they connect to the female holes that is the problem. Wiggle the RF speker connector as you move it in and out until you get 100% of audio voilume back. Once you get it back, do not move the connector. Have not found a permanent solution to date beyond this.
Jan 08, 2010 | Dell ADA745 Computer Speakers
Speakers cut off when bass goes up...
Mar 21, 2007 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
When i turn my radio up all the way my speakers cut out and then come back on
Yes it is probably too powerful for those speakers. Or the speakers could be defective.
Jan 13, 2007 | Swiss Audio SW12 Car Subwoofer
Car Audio & Video Logo
46 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
