Question about Black Bull CHOI2 2 Ton Capacity 8 Chain Hoist
Will not hoist down
Lifted ok. stuck in up position
What safety tips should I follow when using lifting hoists?
Lifting hoists are tasked with the pivotal job of lifting heavy loads that would otherwise be rather impossible to lift. Used in many industries worldwide, there are various safety tips and guidelines one should follow thoroughly, to ensure both the safety of the workers, and to extend the lifting hoist's lifespan. The equipment should first be inspected before and after every use, so as to make sure there are no defects and that the equipment is clean, as slight issues with the equipment could be dangerous if left unattended for any period of time. One should also always be aware of the lifting load limit of the lifting hoist and comply to this limit - never, for any reason, exceed this limit! This can be extremely dangerous, as placing too much strain on the lifting hoist can cause it to break. These are just a couple of the number of factors that could cause a normally sound piece of equipment to be dangerous. To find out more on this topic, this handy infographic from Lifting Hoists Direct, titled "Safety Tips for the Effective Use of Lifting Hoists" was helpful in answering all my questions.
safety tips for the effective use of lifting hoists infographic (final)-3lnz3eczbu0rpnl5hmzvm3sh-2-3.jpg
Sep 13, 2017 | Cars & Trucks
Are wire hoists as strong as chain hoists?
Wire hoists are as strong and in some cases can be stronger even than chain hoists being able to lift between 1/2 up to 80 tons.
Nov 21, 2013 | Hoisting
How much can my lever ratchet hoist lift?
Common ratchet lever hoists have the capasity to lift up to 5 tons, but some can only lift 1/2 ton its important to consult your user manual for exact numbers before use.
Pump lifts but will not gravity down.
either the ram is very new and tight not enough weight to bring it down oror the valve in the pump is not going across to let oil back into reservoir, usually need to power this across.
Jan 16, 2013 | Cars & Trucks
WHERE IS THE BEST POSITION TO JACK 2004 JAGUAR X-TYPE TO CHANGE THE ENGINE OIL?
Hey GUY,
The best way to safely lift your Jaguar is to use a wheel lift / car hoist.
The guys at the quicky lube use a pit ... which is even better yet!
Oct 01, 2011 | 2004 Jaguar X-Type
I purchased a radsportz kayak hoist which appears to be a sturdy, high quality product. The instructions say to position the two pullies no less than 6 feet 8 inches apart, but I need the hoist for a short...
you should be fine to go shorter. The reason for the 6-8 foot recommendation is balance. a 12-14 foot kayak would risk tipping it you had a 4-foot width and didn't denter it just right. Your shorter kayak should do fine at 4 ft, but I would be careful to center.
Jul 09, 2010 | HOIST NEW Kayak / Canoe Lift Hoist by RAD...
Spare tire won't release.
This is the worst GM engineering i have ever seen !!!! The secondary locking mech. rust itself in the locked position on will NOT allow the tire to lower. After lowering the tire down approx. 2-4" the saftey lock is still engaged. I was able to reach above the tire and remove the bolt holding the hoist in place. {15 mm wrench}. Keep a floor jack under the tire to support it and as not to fall on your head. After removing the bolt the hoist is hooked on the frame member and must be lifted off to remove. Once you get it on the garage floor it is possible to disengage the locking mech. with a few tools and a big hammer. Good luck This should be a Recall
May 20, 2009 | 2005 Chevrolet Silverado
How to wire
use a wireless controller it will be cheaper and easer http://www.telecrane.com/
the three wires are
x1 constant power
up
down
x1 is connected to the up or down wire to activate the hoist in the desired direction
Mar 16, 2009 | Jet Equipment Chain Hoist 1TON 10 Ft Lift...
Cant get the spare tire released from the hoist cable? Help
If like mine. Let tire down on ground.
Lift edge of tire up to take pressure off cable.and reach in under and turn cross piece parallel to cable.
Then will come out up through the center of wheel.
Just the reverse to put spare back up to storage position.
Luck
JC
Jan 18, 2009 | 2003 Chevrolet Suburban 1500
Black Bull CHOI2 2 Ton Capacity 8 Chain Hoist Logo
431 people viewed this question
Top Black Bull Hoisting Experts
Andrew Taylor
Andrew Taylor
Eric
Level 1 Expert
Are you a Black Bull Hoisting Expert? Answer questions, earn points and help others
