Question about Gigabyte (GA-M61PME-S2) Motherboard
Wiring connections where do the wiring connections go
    Brigadier General:
  • Gigabyte Master
  • 3,400 Answers
DO YOU MEAN FRONTPANNEL-CONNECTIONS.
http://www.pcityourself.com/building/frontPanelConnections.php
THIS IS IN GENERAL.
Posted on Mar 20, 2014
My fan motor terminal connection to wiring are all cut no color wire all live wire how do i connect it
no numbers, tags or colors on the motor leads or the wiring? Tracing each wire, investigating for clues may get you in the right path. A motor with a capacitor is wired so that two motor wires, (T1 and T2) connect to power (L1 and L2) and a third wire connects only to a capacitor, the other side of the capacitor connects to line 2.
If the motor has 4 wires, then two wires connect to power and the two brown motor wires connect to a capacitor.
Motors with a brown wire with a white line is the same wire as a white wire off the motor. This makes the sold brown wire connect to a capacitor by itself and the brown with a white streak or the white wire connect to the other side of the capacitor where a power line wire connects and the other power line connects to the remaining motor wire. Confused? Draw it out on paper as explained and draw what is actualy on your unit.
Apr 30, 2015 | Heating & Cooling
What do I do with the red wire on a Brinks Halogen Motion Sensing outdoor security light
Please perform these connections with the mains power off.
The standard is the Black wire is hot, the White wire is neutral, and the Red wire is switched. For your Sensor connection 120V is connected Black to Black and white to white while the Load is connected White to White and Black to Red (assuming your load is using standard color coding.
Here is a simple diagram for your connection.
Mar 01, 2015 | Electrical Supplies
Trying to connect a Tork A530 MW timer to a spa tub pump
  1. The white wire (neutral) in your feed cable from the electric panel should be connected to the white (neutral) wire going to the pump.
  2. This switch is wired in 'series' in the hot (black wire) leg. That means one black timer wire connects to the black wire in the feed cable from your electric panel and the other black timer wire connects to the black wire that goes out to the pump.
  3. I the diagram the switch is your timer and the light bulb is the pump. The switch is in series with the pump.
Nov 13, 2013 | Tork Spring Wound Interval Timer
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Wiring bath fan with Fan/ light combo. Want to operate the features on seperate switches. Have power wire Black/ White/Green. Each switch has own wire Black/White/ Green. In the unit there is a Blue/white...
If I understand correctly you are installing two wall switches.
Your switches are switch1 and switch2
Each switch has 2 brass-colored screws
If you have a double switch, see page bottom
And you are installing a fan/light combo with separate wires for fan and light.
Bare ground wires and green wires connect to each other and to green screw. A ground wire runs from fan/light to switch box where it connects to other bare copper wire and these wires will not be discussed.
Lets work from the fan/light down to the switch.
Blue-wire-fan connects to either brass screw on switch1
White-wire-fan connects to white Neutral (we'll talk about this wire as we go)
Black-wire-light connects to either brass screw on switch2
White-wire-light connects to same Neutral as White-wire-fan.
So you need 3 wires running from fan/light to your switch box.
One wire arrives at switch box and connects to brass screw on switch1
One wire arrives at switch box and connects to brass screw on switch2
One wire is the Neutral wire and it arrives at switch box and connects to other white wires inside switch box. Twist these wires together and cover with wire nut.
Now your white Neutral is connected to other white wires in switch box.
Each switch still needs another wire.
The Hot black wire from breaker box connects to brass screw on both switches
Pardon the crude drawing.
The switches would actually be located next to each other, but it was easier to draw like this.
Drawing shows 3 wires coming from fan-light to switch box.
The drawing shows the black and white wire arriving from breaker
The drawing does not show how the white wires are joined with a wire nut
If you have a double switch, with 2 switches stacked vertically.
The screw colors can be different.
Double switch could have brass screws on both sides, in which case your Load (fan-light) wires connect on one side of device, and your Hot from breaker connects to other side. It doesn't matter which side, but loads on one side, hot on other side.
Double switch could also have dark screw(s) on one side and brass screws on other side.
In this case, the black Hot from breaker connects to dark-colored screw(s)
And your Load (fan-light) connect to brass colored screws.
If you need more information, or if something is still confusing, answer back.
Oct 26, 2010 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Need to hook this up to a lutron eco-t528-277-2 ballast which only has a hot,dimmed hot and neutral
If I understand correctly, you have Leviton florescent dimmer
And you want to connect dimmer to Lutron ECO-series ballast
This is the ballast with 3 wires: Hot dimmed, Neutral and Hot
Is this your dimmer???? Has Black, White, Red, Yellow-red, & Orange
Here's how to do it:
Dimmer yellow-red is not used except for 3-way switch >> cap it off with wire nut
Dimmer orange wire connects to ballast Dimmed Hot
Dimmer red wire connects to ballast Hot
Dimmer white wire connects to ballast Neutral
Those are your wires going to ballast. As you can see, you need 3 wires going to florescent fixture
Next, let's focus on Dimmer:
Dimmer green wire goes to bare ground wire
Dimmer black wire connects to Hot from breaker box (we'll test for that next)
Finally the Dimmer white wire connects to ballast Neutral as discussed above BUT is also has to connect to Neutral from breaker box
This means the Dimmer white wire is connected to 2 wires >> one wire goes to florescent fixture and the other wire comes from breaker box
So which wires come from breaker box??
It should be a black and white wire.
Let's test to find Hot and Neutral that come from breaker box.
Mark your wires.
Disconnect all the wires and separate from each other
Turn on power
Use ordinary tester
Tape tester leads to wood sticks so hands stay away from electricity
Power is on
Test each wire to bare copper wire
When tester lights up, that is Hot from breaker box ... this wire connects to Dimmer black wire
Now, test the hot wire to each of the other wires
When tester lights up, that is Neutral wire ... this wire connects to Dimmer white wire, and also connects to Ballast neutral.
Connect one wire at a time, and it will work.
Oct 04, 2010 | Leviton Decora Light Dimmer Switch
GE digital timer. Instructions say to: 1) connect Hot/live wire of main to black wire of timer, 2) connect neutral (White) wires together, 3) connect Hot/live wire of load to red from timer. 4) green to...
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Sep 25, 2010 | UPM Programmable Wall Switch Timer
How to
Please follow the following instructions 1)Use a wiring harness equipped with an adapter plug for faster connection and installation.Disconnect the car battery while installing electronic equipment.
2) Make a note of the wire colors and connect the power supply wires to the DEH-45DH as follows:
Orange wire to the constant 12Volt
Yellow wire to the switched 12Volt
Black: ground wire
3) Connect these wires to control display functions on the DEH-45DH:
Attach the gray wire to the wire marked control panel illumination.
The brown wire connects to the dimmer.
4) Make the front speakers connections following this color scheme:
Left front positive (+) tan wire
Left front negative(-) Gray
The light green wire connects to the positive (+) terminal of the right front speaker.
Connect the dark green wire to the negative (-) terminal of the right front speaker.
5) Make these rear speaker connections:
Brown wire to the left rear positive (+) terminal
Yellow wire to the left rear negative (-) terminal
The dark blue wire attaches to the right rear positive (+) terminal
The light blue wire connects to the right rear negative (-) terminal
Hope this helps
Thanks
Smith.
Sep 09, 2009 | Car Audio & Video
Trying to hook up a dimmer switch it has a red black yellow and green wire the box has a black white and ground which wires get connected together?
For a single-pole installation:
1. Connect the 2 white wires together (one from the source and the other to/from the light fixture) - 2 wires
2. Connect the black wire from the source to the black wire on the dimmer switch - 2 wires
3. Connect the black wire to/from the light fixture to the red wire on the dimmer switch - 2 wires
4. Connect the ground wires - 3 wires
Mar 23, 2009 | Electrical Supplies
Gigabyte (GA-M61PME-S2) Motherboard Logo
54 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
