Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
Can no light up a new Rheem 22V40FN water heater
I bought a brand new Rheem fury 22V40FN, but I couldn't light it up even I followed all instructions, turning the thermostat dial clock wise, gas control knob to pilot position, depress and hold, depres the piezo-elctric spark generator button several times. It just doesn't light up.
    President:
  • 3,433 Answers
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
Posted on Jun 15, 2009
Need manual for model # GE50M06AAG
GE is a Rheem-made product:
Any generic electric water heater manual will work for this heater since it uses same standard wiring, generic parts, and materials used for years to make electric water heaters. Nothing special. Except do not expect many specifics from any Rheem manual pertaining to insulation thickness or comprehensive troubleshooting.
Copy following link. Click on tab for specs and docs:
http://www.rheem.com/product/residential-electric-water-heaters-fury
If you have specific question about water heater troubleshoot or maintenance, copy following links for professional diy resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
Add a comment.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 20, 2013 | General Electric Water Heaters
Can't locate the year of manufacture of my Rheem Fury Model 29-40S-2
Generally the year of manufacture for Rheem is 3rd and 4th digit of serial number. 06 is 2006, 92 is 1992 etc.
Older gas water heaters are better than new ones, and easier to keep repaired and maintained.
Regardless of age, the key factor is whether tank is rusted, or rusting.
Open drain valve and check if water is rusted.
http://waterheatertimer.org/Replace-anode-rod.html
Aug 18, 2012 | Rheem Fury 40 Gallon Natural Gas Water...
I just bought a house, and the water heater instructions posted on the water heater is all covered up by the earthquake straps! The earthquake straps are a requirement in California, I can't remove them....
1) Model 41VR50N is Rheem fury gas water heater.
Look on tank label, the second 2 digits of serial number are year of manufacture.
2) Rheem does not show that specific model number, but has generic manuals for Fury series:
Open link to read about Fury series, and access brochures and manuals.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
3) Sample manual for Fury appears on following link:
http://globalimageserver.com/fetchDocument.aspx?id=01091171-3bac-4cb9-a0a8-a11aac3bd668
4) Rheem phone number: 1-800-432-8373
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | Rheem Water Heaters
TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL NUMBER 81V52D C SERIAL NUMBER RH 1297B30669 50 GAL US TANK ELECTRIC WHAT IS THE UPDATED VERSION?
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
May 25, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Does the Rheem Fury model 22V50F1 qualify for an energy tax credit?
Unfortunately, no... According to the Rheem website, the Rheem Fury model 22V50F1 has an energy factor of 0.58:
In order to qualify for the credit, the energy factor must be 0.82 or greater...
Jan 31, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem glas fury model 22-40 gas water - leaking
Dear Hank McNeal; I have successfully used a "boiler plug" to seal a water heater tank leak in 2007. It was a 100 gallon electric commercial hotel unit. To this day it's still in use. It depends where the leak is located....Predrilling the leak is necessary to be sure the plug will ernguage it's threads into good material... Start as small as possible, then use the best suited plug. they come in an assortment of sizes. rheem-glas-fury-model-22-40-gas-water-qbzdprdp3yetvbzozs4dsujq-4-0.jpg
Oct 23, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
1,567 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
