What can I do about my picture tube on my prestige
What can I do about my picture tube on my prestige 10?
  • Televison & ... Master
  • 10,291 Answers
Say a prayer over it then bury it. I don't know anyone selling replacements or how much it would cost.
Posted on Mar 20, 2014
My Visual Land Prestige Pro Android tablet will not charge
Visual Land Prestige Pro 7D Repair - iFixit
https://www.ifixit.com/Device/Visual_Land_Prestige_Pro_7D
iFixitVisual Land Prestige Pro 7D troubleshooting, repair, and service manuals. ... Tablet is fully charged but it won't stay on ... Why won't my device charge? ... The 7D runs on a newer Android 4.1 Jelly Bean, and has 1GB of RAM, compared to the ...
prestige 7 wont power on - Tabletroms.com
www.tabletroms.com > ... > Visual Land Tablets > Prestige 7
Sep 7, 2012 - 9 posts - ‎2 authors
I found this forum from searching about the prestige 7 and watching the videos ... It showed the charging animation for a few mins and then went off. ... I'd like to figure out what the problem is as I quite like the tablet and it was half .... prestige pro 7d won'tturn on. ,. visual land 8q has power but will not turn on. prestige 10D wont turn on after charging help!
Mar 23, 2014
Visual Land Prestige 10 charging issue
Jan 2, 2014
Ack... Help... Major Battery Issue!!!
Jan 24, 2013
Power Port Charging Issue
Jun 12, 2012
More results from www.tabletroms.com
Jan 07, 2016 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
4A Slow Blow Fuse keeps blowing in my Prestige Triangle Tube 110 Solo LP with U125
Jack,
I just got mine fixed, so can for sure try to help you.
Something on the low voltage side is misbehaving. I can walk you through narrowing it down if necessary, but it's most likely the blower motor.
Here is how you can confirm. Unplug the wiring harness or harnesses at the top of the blower motor. The plastic can be brittle, so be gently. This will remove the blower from the equation. Then, start up the boiler. Did a new fuse blow? If not, it's the blower motor.
If there is a tube attached to the blower intake, remove it. Then stick a screwdriver into the small hole where the air sucks in. Try to rotate the fan. Is it stuck? Does it spin freely? You might be able to free it and get heat for a while, but you will probably need a new blower kit if it's noisy or stuck.
Post back if you need more help.
- Paul
Feb 22, 2015 | Honeywell Triangle Tube Prestige Solo 110...
My visual land prestige internet tablet 7inch cracked I wanted to know how I could get it fixed .Help please
hi Imani.
do it yourself.
go to e bay and order the panel and you can do it yourself try you tube ant it has tons of videos .or ask professionals to do that.
regards,
nuwan
Jan 27, 2014 | Visual Land Prestige 7 ME-107-8GB 7" 8 GB...
Hi, could any one help me reset zyxel prestige 100ih password?
There should either be a small button or a pin sized hold on the back labeled "Reset". Hold this in for about 10 seconds and the router will be reset back to factory settings.
Apr 02, 2012 | Zyxel Prestige 100IH Router
My Sony tv CRT
If it's between 5-10 secs, that's normal. You will turn the tv on and hear a loud (buzz/hum) that is the picture tube firing up, once it's fired up, it has a few more seconds until your picture comes up fully. That is about 5-10 secs from pushing the power button.
If it's taking longer than that, your picture tube may be going out.
I had a 36XBR250 and it took about 10 secs to fire up and show a picture, and it was 5 1/2 years old.
Nov 25, 2007 | Televison & Video
What is the main difference between WinGate and the Prestige 310 ?
# WinGate is a software only solution that needs to be installed in a dedicated Windows 95 PC based server. The total cost and complexity are many times over ATI?s product. The Prestige 310 Internet Access Sharing Router is a plug-n-play internet appliance. # WinGate requires all TCP/IP applications such as Netscape Navigator to be reconfigured to have the dedicated server as a proxy. The Prestige 310 Internet Access Sharing Router does not require users to reconfigure any software at all. # The Prestige 310 Internet Access Sharing Router uses Network Address Translation (NAT) scheme, which supports all TCP/UDP ports. WinGate only supports limited number of ports, such as http(80), ftp(21), telnet(23), and pop3(110). # WinGate works as a proxy, while the Prestige 310 Internet Access Sharing Router works as a gateway. The gateway approach is more efficient than the proxy during the processing of TCP/IP commands. As a result, the Prestige 310 Internet Access Sharing Router achieves 10% to 20% higher performance than that of software solutions such as WinGate. # The Prestige 310 Internet Access Sharing Router uses Solid State Disk technology. There are no moving parts in the product. It is much more reliable than any hard disk based system, such as the one for WinGate.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
What is the Prestige 310 Internet Access Sharing Router?
The Prestige 310 Internet Access Sharing Router is a robust solution complete with everything needed for providing Internet access to multiple workstations through your cable or ADSL modem. The router equipped with 10Mbps Ethernet WAN port and an auto-sensing 10/100Mbps Etherent LAN port is the most simple and affordable solution for multiple and instant broadband Internet access. Virtually all-popular applications over Internet, such as Web, E-Mail, FTP, Telnet, Gopher, are supported. The Prestige 310 is designed for SOHO, branch offices, workgroups, and educational users.
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
