Question about Nordic Track Nordictrack C2200 Treadmill Walking Belt Ntl109052
Nordi Track Treadmill C2200
When I try to program or increase speed, it kicks the 15 amp breaker. I have it plugged into a single outlet with a TVSS. There are two bedrooms that use the same circuit. I read about moving to a 20 amp circuit or installing one but that would be too costly. Does anyone know of any other possible cause and/or solution? I bought it used. I checked the Information/Demo mode and it has 80 miles and 31 hours. I don't know if it is related but I discovered that the left fan doesn't work.
  • susanjeffers Mar 20, 2014
    I can increase and decrease the speed at .1 increments. I noticed that certain factors the breaker to kick at different speeds. If the belt is too tight, it kicks the breaker at 2 mph. If the belt is too loose, it kicks the breaker at 3 mph. I adjusted the belt and got it up to 3.8 before it kicked the breaker. I will try lubing the walking belt and see if things improve.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
Treadmills draw alot of amps when being used. they recommend a 20 amp dedicated outlet.i ran into the same problem with a treadclimber.
you can try using a 15 amp but make sure nothing else is on that line
Posted on Apr 13, 2014
  • susanjeffers Apr 14, 2014
    I lubed the walking belt and turned off everything that shares the same circuit and it works. I am not sure what fixed it, but as long as it works, I'm happy. Thank you
maxtreadmill
  • 832 Answers
SOURCE: Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
Posted on May 20, 2010
  • 6 Answers
SOURCE: my c2200 treadmill will not reset or operate other
This is dinesh from AADHI FITNESS SERVICE CENTRE...
Search for the details in justdial india...
Can we come to ur place and check the machine... My contact no is 9986202487
Posted on Jul 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Posted on Feb 28, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
  • 13 Answers
SOURCE: Nordic Track c2200 no speed
It likely is the controller if it was speeding up and down erratically. Check the position of the reed switch to make sure it is positioned about 1/8" away from the magnet in the side of the front roller pulley. Run a diagnostic program as follows. Press the stop and speed arrow up buttons until you insert the key. Press the stop once or twice until you get to a screen with 2 sets of zeros. Now press and hold the speed arrow up button until one number set shows 8.5. The unit will go to full speed so be careful not to be on the walking belt. The other number set should top out shortly at either 10.0 or 12.0 based on whether your speed buttons go up to 10 or 12. If the motor races past your top number,( don't let it run that way as you may damage the motor), pull the key. If the readout is above or below your target by more than .4 and not flucuating a lot, you may need to tune the potentiometer on the controller. Counter clockwise turn with a phillips screwdriver turns the motor speed down. Be carefull not to short out the controller board by touching components with screwdriver. If not comfortable ask a friend with electronics background. If you turn the pot. too far it will break. It will not go a full revolution in either direction and tiny movements are recommended. Again I believe your controller needs replacing.
Posted on Oct 03, 2010
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
How do you reset the nordictrack c2200
Connect the power cord on the NordicTrack treadmill firmly to a working power source if the treadmill does not operate. Use a single-outlet surge suppressor, available at most hardware stores, and plug the treadmill into a grounded outlet. Look at the "Reset/Off" circuit breaker on the treadmill base and wait five minutes before pressing the switch if it has popped .
sincerely.
E.CUADRA
MANAGUA,NICARAGUA. C.A.
Nov 23, 2011 | Exercise & Fitness
I have a Nordic Track C2050 treadmill and the key pad is not working properly. Only the #1, #7 and the down speed buttons work. I tried adjusting the ribbon cable connection and that worked for one day.
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Cleaning: Remove the covert and spray the Key Pad with special spray( contact cleaner) for to remove dust, etc, very carefully, you mus unplugged the machine.
Sep 27, 2011 | Nordic Track NordicTrack Treadmill, A2550
BUYER BEWARE!! I purchased the Nordic Track C2500 in 2009 and after 2 years of moderate usage (105 lb women walking 3-4 times a week) the console stopped working. None of the buttons respond and it beeps...
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
o 2
o 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Check too:Optical Sensor. If have it
Sep 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Tread mill wont turn on. it was on then while in use the screen flashed on and off then treadmill shut down and has not turned back on. tried reset button then unpluging for a while but still does not turn...
Dear Sir:
Thank you by your problem, I will help you inmediately.
Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor
that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor
must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation
of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps.
Important: The treadmill is not compatible with GFCI-equipped outlets.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
4)Check the on/off switch located on the treadmill
near the power cord. The switch must be in the on
position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
sincerely.
E.Cuadra
Sep 13, 2011 | Nordic Track NordicTrack Elite zi...
Just was given the exp2000 from a family member, machine is plugged in and when powered on, it immediately flashes all lights then it goes black. ALSO, we just noticed the key is missing. Would that effect...
1) Find the key.
2) Follow this:
    • 1
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Jul 24, 2011 | Nordic Track NordicTrack Treadmill, A2550
I have a nordic trac a2050, that is only working on 1, and 7. The speed down button is working but nothing else. Any ideas?
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Check the Optical sensor: if have it. very important!
http://www.youtube.com/watch?v=E-q-uS4t6so Watch this video.
Jun 12, 2011 | Nordic Track NordicTrack Treadmill, A2550
Just assembled a new Nordic Track 2155 - demo is turned off but when key is attached it comes up 'Welcome User 1' and no other buttons will work. Pressing start and a speed button does nothing. ...
Watch this video and Steps:
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Check too: Optical Sensor: if have it.
May 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
My Healthrider 400se Treadmill slows down after 10seconds
Use only a single-outlet surge suppressor that is
(TVSS). The surge suppressor must have a
and a minimum surge dissipation of 450 joules.
for 120 volts AC and 15 amps. There must be a
monitoring light on the surge suppressor to indicate
whether it is functioning properly. Failure to
use a properly functioning surge suppressor could
result in damage to the control system of the
treadmill. If the control system is damaged, the
walking belt may change speed or stop unexpectedly,
which may result in a fall and serious injury.
Jan 23, 2010 | HEALTHRIDER Pro H500i Exercise Workout...
Nordic Track Nordictrack C2200 Treadmill Walking Belt Ntl109052 Logo
139 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
