Question about Samsung Cell Phones
Model display blink
Blink rapidly
  • noli tero
    noli tero Mar 22, 2014
    how if the unit turn on,show only model blink rapidly
Why is the Rinse Cycle and Drying not working
Unfortunately you did not specify the model dishwasher so I'll give you a general answer.
(The indicator light, straight from Washing moves to completion stage where the light blinks rapidly) I believe you means the "End LED" (LED 3) blinks rapidly. If this is true and according to your description of failure (no drying, no rinsing) I think that appeared alarm AL04. It means the thermistor (NTC) not compliant - probable failure of the component that detects the temperature .
I suggest you to check: thermistor NTC, wiring and electronic.
24464652-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Rapidly flashing any combination of four LED diode means failure.
Dado
May 20, 2014 | Ariston Technologies Dishwashers
TV model # 42631 has a continuious green light blinking rapidly
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Electro help
Jan 16, 2014 | Mitsubishi Replacement Oem V33 Pwb-dm...
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
I have a Craftsman Garage Door opener model # 139.53674SRT2. It is sporadically going up and down to varying degrees. The LED indicator on the back is constantly blinking. If I trip the motion sensor it...
Rapid blinking of that LED indicates it is receiving a signal. Make sure you don't have an old remote somewhere that is sending a signal and that your other remotes do not have a stuck switch. Remove the batteries and check that light.
Jul 17, 2011 | Sears Craftsman LiftMaster Chamberlain...
Rapid green blinking green light on monitor and power & no video
try to acces the menu and to reset the display settings.
try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
Oct 27, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Switching on and off......rapidly
Check your line voltag to the dryer which should not exceed 120 volts for gas and 240 volts for electric. Unplug the dryer if the voltage is too high or low and reste the breaker. If voltage is good and unplugging and replugging don't solve it, you probably have a bad circuit board in the dryer.
Mar 15, 2009 | Whirlpool LGV4634JQ Gas Dryer
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
Cell Phones Logo
16 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
