Question about Philips DECT5112 Cordless Phone
Eircom Siemens 7010 "base" message after power cut. What a piece of **** it?s supposed to be "plug and play" Tried everything unplugging the whole thing, restoring defaults going into settings register handset and base nothing. Lost the user manual!! How frustrating can't use the phone at all
richa33
  • 71 Answers
SOURCE: Wharfedale IN120-1 How do I record my own answering machine message?
Generally, there is "greeting" key on base, hold serveral seconds untill you hear a "beep" , then begin to record.
Or handset have menu, like "answer machine" ,"Record OGM" like that. record OGM from handset.
Posted on Jan 21, 2009
SOURCE: phillips SE140 duo - had
you may have to input you country code again as you did at set up .then you will probably find that your handset will register as long as you use the master charger
Posted on Feb 11, 2009
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Posted on Mar 05, 2009
SOURCE: phillips id phone, the 2nd handset is constantly
lsp-350t unlok code
Posted on Jul 29, 2009
SOURCE: I cant register my phillips voip43315/05
my phone is saying unregistered
Posted on Aug 18, 2009
Siemens Gigaset 675 I'm just installing it and
check the power cord for faults at the base and the wall socket. make sure everything is tight.
Oct 07, 2011 | Lands Phones
We have a telephone handset and base the Gigaset A265 which is not ringing in the house but going straight to our message system on our computer via our internet provider orange. We can call out but are...
Hello.
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes. That way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the surge protector:
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone. It could be that the phone line plugged into the surge was loose or not plugged in securely.
Try a different phone plug, outlet.
Check the base:
Is the base dusty and have possible dirt in the prongs where the phone sits? Lift the base and blow off dust.
Check the handset for dirt.
Rub metal connections on handset and base:
Use a pen cap or coin and rub the metal connections on the bottom of the handset. Rub the prongs, metal connections on base.
Hope these suggestions help.
Sep 01, 2011 | Siemens Cell Phones
I have a set of JBL Creature Speakers that I take good care of. However, one day, I knocked one of the satellite speakers off my coffee table, and subsequently that speaker only plays very faintly,...
Without seeing it it is hard to tell, but it could be that the speaker cone is out of the magnet hole, and is missaligned, in other words the voice coil could be sitting on top of the magnet instead of in the magnet hole... If you DELICATELY push on the speaker cone does it move in and out???
side view cut away of a speaker...
Aug 20, 2011 | JBL CREATURE II Computer Speakers
We have a eircom 6010 siemens phone and it is constantly falshing base 1 and wont allow us to make or recieve a call on the handset
I have and eircom siemens phone and it is also constantly flashing base 1 and wont allow us to make or receive a call
Debbie
Jan 20, 2010 | Lands Phones
I am looking for a user guide for model 7010 Siemens Eircom,my phone no.is0214291987
Thank you for your reply, a daughter of mine solved my problem for me. So,I shall not be needing the User Guide after all.
Aug 31, 2009 | Siemens Lands Phones
"no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
May 01, 2009 | Lands Phones
Can't reset Panasonic KX-TG6700 phone
I have the same problem,,,
Dec 11, 2007 | Lands Phones
Help with siemens giga set4200
Hello, it sounds as if your base has gotten corrupt somehow. You can try defaulting it, but keep in mind you will lose all your messages, and will need to re-register your handsets if it works. To do so, get all your handsets together near you base. Unplug the power from your base and turn the base over. Push and hold down the Page/Registration key and keep it held down while you plug the power back in. Keep the key held down for at least 15 seconds, then release and begin registering your handsets. If you need help, I can email you a "cheat sheet" on doing so. You can contact me at www.cordlessrepair.com Good Luck !
Nov 05, 2007 | Siemens Gigaset 4000 Phone
Blinking light on base
apparently you can reset the whole system by unplugging everything including the phone jack and taking the batteries out - for 15 minutes and then re set up including registering 2nd handset
Sep 23, 2007 | GE 27831FE2 Phone
Philips DECT5112 Cordless Phone Logo
466 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
