Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Gaggia syncrony compact is leaking. Removed top and it appears it is leaking from the area that the line goes into the steam knob. Doesn't leak when using the steam knob, just when brew coffee
  • rlehmkuhl Jun 14, 2009
    what color should it be? still not sure I know if I'm looking at it or not. Do I need to remove the black cover with trough to see it? or is it visible by looking under it?
  • 1,089 Answers
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Posted on Jun 14, 2009
  • bansheracer Jun 14, 2009
    Hi
    You can look from the back where the white tube goes in. There is a clip there also. If you want to take the cover off you have to remove the tube. Pull the clip and then pull the tube out. Push the cover towards the back and then lift at the trough. Don't do this unless you want to confirm the color. Once the cover is off the manifold will push out towards the front. There is a metal clip holding the steam tube on. Just cut it and Use a zip tie to reattach it.
    Hi
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
My steam wand is leaking water and not just shooting pure steam. What is the problem?
Most likely the tap rod assembly and or the whole valve needs to be replaced.
Apr 11, 2010 | Gaggia Syncrony Compact Coffee...
Syncrony digital gaggia coffee maker leakage+ventilate message
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Feb 02, 2010 | Gaggia Syncrony Compact Coffee...
I have a Gaggia Syncrony Compact Digital, almost 2 years old, recently the digital display has been fading and today once i turn the steamer off, it still steams at a slow pace and evenutally it stoped,...
The steam valve has been leaking on the inside for awhile, the steam condensed on the display board. You will have to replace the steam valve assembly and maybe the display board.
Jan 20, 2010 | Gaggia Syncrony Compact Digital Espresso...
I have a Gaggia Synchrony compact. I recently decalsified it and it stopped working. The low water light is on and nothing works except, for the water pump. It will flow only cold water through the steam...
If it leaks from the steam wand then you need to get a new steam valve assembly. For the heat you will have to open the machine it is possible that the steam boiler is damaged or that the thermostat on there is bad, use an ohmsmeter to check thermostats and element. There are 2 screws in the grinder, 2 behind the water tank and about 2 or 3 in the front behind the door.
Jun 09, 2009 | Gaggia Syncrony Compact Coffee...
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Machine is leaking
the valve is available at partsguru.com in the US
Apr 16, 2008 | Gaggia Syncrony Compact Coffee...
Syncrony Compact leaking
Usually these cannot be adequately fixed. To get a replacement, depending on where you are, here is the link; http://www.gaggia.com/gaggia_nelmondo.asp If in USA: Importika 596 Fishers Station Dr. 14564, Victor, NY Mr. Salzman Ph. 585.742.5178 Fax 585.924.1499 web site: www.importika.com e-mail: sales@importika.com Hope this helps :)
Aug 22, 2007 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
515 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
