Question about Frigidaire Electric Dryer
Dryer overheating on timed dry/no heat settings
Frigidaire AEQB6000ES2 electric dryer was running but not producing heat. Had a repair guy come look at it and the heating element was broken. He replaced the heating element, but then the dryer started overheating, even on low heat setting or no heat setting. Additionally, the white plastic on the front control panel turned yellow and even with the door open, I could feel heat coming out of the dryer. I told repair guy what happened & tried to get him to come back to check it out, but every time he made an appointment he wouldn't show up or call so after a month and numerous missed appointments, I decided to call someone else. The new repair person I spoke with suspected that the heating element may not have been properly installed; and when he came to look at the dryer yesterday, he showed me that the coils on one end of the heating element were all bunched up with the loops touching each other. He said it couldn't be used and he had to install another new element, which I watched him do and could see how the other element wasn't properly installed. With the 2nd new element installed the dryer was still overheating when on the no heat/air fluff setting. The 2nd repair guy concluded that the new element that was put in last month started to ground causing the dryer to overheat and damage the control board, which is why it's still overheating on no heat setting. He said I could use the dryer on one of the auto settings which uses some sensor to control heat and figures out when the clothes are dry. But he said not to use dryer on a timed dry or no heat setting until the control board was replaced. Later the same day I called the first repair guy and he got really defensive and said he didn't do anything wrong. I said he's welcome to come look at it, so he said he would later in the week. I also sent him pictures I took of the heating element he had put in incorrectly. Last night I put some towels to dry on a high heat setting and the top of the dryer wasn't getting super hot like it did after heating element was replaced last month. I opened the door to check and the heat was working and towels were getting dried. I checked on the dryer several times while it was on and thankfully it still wasn't overheating. (There is a display with mins remaining, but after few mins into drying, it just shows "Ad" when using one of the auto dry settings.) Because I've typically used the timed dry setting in the past, I forgot that when using the auto settings, there is a "cool down" phase at the end of the drying cycle where I'm guessing the heat is suppose to turn off for the last few mins while clothes are still rolling around in the drum. When I went back to the dryer it was in cool down mode with 4 mins remaining on the display -- but the dryer was really hot when I touched the top and when I opened the door there was a lot of heating coming out. I just got an email from the first repair guy and he's telling me he thinks my dryer's thermistor is bad and is the reason for the overheating. Because it looks like he didn't install the element properly the first time which has now caused additional damage to the dryer I am hesitant to let him do more work on it and replace another part. To me, the explanation from the 2nd repair guy makes sense since we never had a overheating problem before (plus the outer control panel on dryer turning yellowish like it was burnt which happened after element was replaced last month). I understand that the heating element coil touching another metal part of the dryer can cause it to be grounded, which could explain the overheating, but can the element start to ground because the individual coil loops are touching each other? And could the grounded element damage the control board? Is the damaged control board the reason that with the new element put in yesterday I'm able to use dryer on auto settings without it overheating but it still gets hot on timed or no heat settings?
  • 1 more comment
  • Ajay S
    Ajay S Mar 20, 2014
    I couldn't figure out how to add pictures before, so these are pics of how the new element was installed last month. At one end of the element there is a section where the loops are touching each other.
  • Ajay S
    Ajay S Mar 20, 2014
    The yellowing that happened when dryer first started overheating after initial heating element replacement.
  • Ajay S
    Ajay S Mar 20, 2014
    This is the new heating element that was installed a couple of days ago - the one currently in the dryer
    Top Expert:
  • Frigidaire Master
  • 22,766 Answers
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Posted on Mar 20, 2014
  • Ajay S
    Ajay S Mar 20, 2014
    I don't understand how that explains why the dryer works fine and doesn't overheat when set on an auto dry setting. After the element was incorrectly installed last month (see picture), the dryer started overheating regardless of what drying cycle was selected, but with the new element installed this week it now only overheats on timed dry or no heat/air fluff settings.
  • Ajay S
    Ajay S Mar 20, 2014
    This is a close-up of the elements loops touching each other which I was told is what caused the overheating problem
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire Dryer only runs on "low Heat" setting
Mexitronics
Posted on May 20, 2009
  • 401 Answers
SOURCE: Frigidaire Dryer not drying clothes properly
TRY DISCONECTING THE VENTING FROM THE BACK OF THE DRYER THEN RUNNING IT .POSSABLE THE OUTSIDE FLAPPER STUCK?IM THINKING NOT THE DRYER. GOOD LUCK!
Posted on Jan 16, 2010
heatman101
  • 43501 Answers
SOURCE: have a frigidaire "gallery" series stackable
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 22, 2010
andrew_ha524
  • 19 Answers
SOURCE: Touch Panel Control Shorting Keys
I would check out the UK WHICH website.
Posted on Aug 28, 2012
AEQB6000ES2 dryer wont heat
There are 4 things that can cause this issue: 1. Thermal Fuse (Protects the dryer from overheating and fires) if this is blown, the drum will still turn but you will have no heat. {Cheapest Fix} 2. Heating Element Assembly {Third Cheapest} 3. High Limit Thermostat (if this is stuck OPEN, the dryer will not heat) {Second Cheapest but rare issue} 4. Main Control Board (Check all the other parts first as this is not cheap and there is no way to test it, if the other parts do not fix the issue, replace this. Not a common issue but can be a manufacturer defective item)
Feb 27, 2013 | Kitchen Appliances - Others
Model #ALFRIGLEGLIS152ES Frigidaire gallery series won't heat. It stays on for a while and sometimes cuts off. When you set the time on it and press start all the lights start blinking on the o
Hi Robert Burch - From what you have described the unit could possibly have a communication problem with the control panel. However, if the unit is not producing any heat please have a professional diagnose the heating element and the blower assembly as well. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Oct 12, 2012 | Frigidaire Electric Dryer
The dryer runs but produces no heat. After a little the machine stops running and the lights that indicate what part of the drying cycle the machine is in all blink simultaneously. I am wondering what the...
if you dryer is gas check out this gas no heat tip....
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Dryer is taking much longer to dry clothes than it once did. Took 3 hours to dry clothes last night and had an unusal odor. Dryer is 3 years old, the dryer vent is not clogged up.
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
If you have any questions, please post back and let me know. I hope you find this information helpful.
FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
Nov 03, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire FEQ1442ES Electric Dryer not producing heat. Quits running part way through cycle... Lights flashing green.. Clothes never get dry. Code E95
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Oct 10, 2010 | Frigidaire FEQ1442ES Electric Dryer
Jan 16, 2010 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Nov 23, 2008 | Frigidaire GLER642A Electric Dryer
Asko T701 Runs for full cycle but does not dry
thermal cuttouts(thermal fuse or half a dozen other names for the same thing) on the exhaust duct look like this 088c0f1.jpg or this 89f91e6.jpg, the high temp one is blown.
locate and test with ohmmeter or bulb and battery
replace, not a repairable item, but inexpensive,
there are very few cutouts common to many dryer models
the local parts guy will have one to suit even if marked frigidaire or ge
while the dryer is open is a good time to de-lint the fan and exhaust ducting to the outside wall to prevent recurrence
Jun 25, 2008 | Asko T701 Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Frigidaire  Electric Dryer Logo
132 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
