Question about 94-98 GMC Sierra C/K 1500 Grille Front Black Chrome GM1200392 12388709
Brake adjustment actuator keeps breaking off - 94-98 GMC Sierra C/K 1500 Grille Front Black Chrome GM1200392 12388709
  • 35 Answers
Which side man !!!!!!!!
Posted on Mar 23, 2014
Brake adjustment actuator comes loose
This is just a guess but I would guess you had to manually back the rear brakes off to get the drum off and backed it too far off--try with drum removed to see if it moves the pads, if it does tighten it so you can just get the drum back on---I am not a mechanic but happened to see your question here and have for about 50 years since 14 been working on my own cars.......hands on experience.
Dec 17, 2012 | 1999 Oldsmobile Cutlass
I HAVE A 1984 CHEVY PICKUP THE BRAKE LIGHTS DONT WORK REPLACED BRAKE SWITHCH STILL DONT WORK. I JUMPED A WIRE FROM ONE CONNECTION TOO THE OTHER AND BRAKE LIGHTS LIGHT UP? TESTED OLD AND NEW SWITCH .
If you make the jump with a wire at the switch and the brake lights work your new and old switch are not adjusted right on the brake peddle arm. make sure when you move the brake peddle that the switch is moving right to make/break the switch.
Sep 04, 2011 | 1984 Chevrolet Blazer
How do I get the rear spindle off so I can replace the emergency brake shoes on my 2006 chrysler pacifica?
Adjustment
  1. Place parking brake lever in -full released- position.
  2. Raise and support vehicle.
  3. Remove plug in parking brake shoe support to access adjuster star-wheel.
  4. Through the access hole, rotate the adjuster star wheel in the following direction to expand the shoes outward against the drum:
    1. Left brake - Rotate star-wheel toward rear of vehicle.
    2. Right brake - Rotate star-wheel toward front of vehicle.
  5. Using an appropriate tool, turn adjuster star wheel until wheel will not rotate (dead lock).
  6. Back off adjuster six detents (teeth).
  7. Rotate wheel, checking for light drag. If drag is too heavy, continue to back off adjuster one detent at a time until light drag is present. Do not back off star-wheel more than 17 detents from wheel lock.
  8. Install access plug.
  9. Adjust opposite wheel parking brake shoes using same method.
  10. Lower vehicle.
  11. Apply and release parking brake lever once to ensure proper operation of parking brakes.
Removal & Installation NOTE The following procedure may be used to remove shoes on either side of the vehicle.
  1. Lock out automatic adjuster in parking brake lever.
  3. Access and remove rear hub and bearing.
  4. Remove parking brake cable bolt at knuckle.
  5. Completely back off parking brake shoe adjustment.
  6. Remove parking brake shoe adjuster spring.
  7. Remove shoe adjuster.
  8. Remove upper brake shoe hold-down clip and pin.
  9. Remove lower brake shoe hold-down clip and pin.
  10. Remove upper and lower shoes with return spring from shoe actuator.
  11. Remove return spring from shoes.
    Fig. View of the actuator (1), support (2), adjuster spring (3), return spring (4), caliper adapter (5), shoes (6), hold-down clips and pins (7) and adjuster (8)
To install:
  1. Install return spring between upper and lower shoes.
    NOTE Before installing shoes on actuator, make sure actuator hooked to rear cable is positioned with word -UP- facing outward.
  2. Install upper and lower shoes with return spring on shoe actuator located on parking brake cable.
  3. Install lower brake shoe hold-down pin through rear of support and lower shoe, then install hold-down clip.
  4. Install upper brake shoe hold-down pin through rear of support and upper shoe, then install hold-down clip.
  5. Install shoe adjuster. Place end of adjuster with star wheel upward.
  6. Install parking brake shoe adjuster spring.
  7. Install bolt securing parking brake cable to knuckle and tighten bolt to 21 ft. lbs. (28 Nm).
  8. Using Brake Shoe Gauge, Special Tool C-3919, or equivalent, measure inside diameter of parking brake drum portion of rotor.
  9. Place Gauge over parking brake shoes at widest point.
  10. Using adjuster star wheel, adjust parking brake shoes until linings on both park brake shoes just touch jaws on gauge. This will give a good preliminary adjustment of parking brake shoes, before a final adjustment is made at end of this procedure.
  11. Install hub and bearing with wheel speed sensor as well as all components necessary to access it.
  12. Lower vehicle.
  13. Unlock automatic adjuster in parking brake lever.
  14. Perform final adjustment of parking brake shoes
  15. Adjustment This vehicle is equipped with permanently sealed rear wheel bearings. There is no periodic lubrication or maintenance recommended for these units.
    1. Raise and support vehicle.
    2. Remove wheel mounting nuts, then tire and wheel assembly.
    3. If equipped with AWD:
      1. Remove cotter pin, nut lock and spring washer from half shaft.
      2. While a helper applies brakes to keep hub from turning, remove hub nut and washer.
    4. Remove brake caliper and rotor from hub and bearing assembly.
      Fig. Hub assembly
    5. Disconnect vehicle wiring harness connector at wheel speed sensor connector.
    6. Unclip wheel speed sensor connector from spare tire mounting support.
    7. Disconnect two sensor cable routing clips on rear suspension crossmember.
    8. Disconnect two sensor cable routing clips along toe link.
    9. Disconnect sensor cable from bracket on brake support.
    10. Completely loosen, but do not remove four bolts fastening hub and bearing in place. Once loosened from threads in hub and bearing, push bolts up against rear of hub and bearing to keep brake support plate in place when hub and bearing is removed.
      Fig. Rear hub and bearing mounting bolts
    11. Pull hub and bearing off knuckle and half shaft (if equipped with AWD), then thread wheel speed sensor cable through hole in brake support plate as it is removed with hub and bearing.
    To install:
    1. Position hub and bearing bolts though rear of knuckle and parking brake support just enough to hold support in place as hub and bearing is installed.
    2. Install hub and bearing by first feeding end of wheel speed sensor cable through hole in bottom of parking brake support. As this is being done, if equipped with AWD, slide hub and bearing onto half shaft. Place hub and bearing through brake support, onto knuckle, lining up mounting bolt holes with bolts and placing wheel speed sensor head at bottom.
    3. Install four bolts fastening hub and bearing in place. Tighten mounting bolts to 60 ft. lbs. (81 Nm).
    4. Place wheel speed sensor cable routing grommet into bracket on parking brake support.
    5. Route wheel speed sensor cable along toe link and rear suspension crossmember connecting routing clips where shown.
    1. Connect vehicle wiring harness to wheel speed sensor connector.
    2. Install brake rotor and caliper.
      1. Install washer and hub nut on end of half shaft.
      2. While a helper applies brakes to keep hub from turning, tighten hub nut to 180 ft. lbs. (244 Nm).
      3. Install spring washer, nut lock and cotter pin on end of half shaft.
    4. Install tire and wheel assembly. Install and tighten wheel mounting nuts to 100 ft. lbs. (135 Nm).
May 18, 2011 | 2006 Chrysler Pacifica
My break light swithes on sometimes without me even pressing the breaks. The break light also sometimes stays on even when I have taken my feet off the break. I have tried changed the break light switch...
Did you adjust the brake light switch correctly? To adjust the brake light switch, first press the brake pedal down a few inches, then pull the switch plunger rod out of the switch toward the brake pedal arm, as far as you can without using excessive force. Next, return the brake pedal to the pedal stop position against the pedal stop and pull the brake pedal toward the rear to push the brake light switch actuating plunger rod into the switch housing limited by the travel of the brake pedal arm rear travel stop position. This procedure automatically adjusts the brake light switch correctly.
If the brake lights still don't turn off with the brake pedal released, check the brake pedal arm for sticking or binding that is preventing the brake pedal arm from returning fully to the pedal stop when the brake is released.
Feb 21, 2011 | 2002 Audi A4
I'm replacing my rear brake shoes on my 2001 chevy venture,i've assembled new parts and what has been happening is when i push on the brake pedal the adjuster actuator and actuator spring keep popping off...
Parking brake lever on leading shoe (end of retractor spring in its hole on the leading shoe). Make sure the the adjuster screw assembly is engaged properly with the leading shoe (also, engaged with the parking brake lever). Adjuster actuator installed on the trailing shoe (also, engaged with the adjuster screw assembly). After inserting the retractor spring in its hole on the trailing shoe, insert actuator spring in its hole (just below wheel cylinder) in leading shoe and stretch across and connect it to the adjuster actuator. Adjust star wheel to get shoes close to drum. Reinstall drum (shoes close with no rub). Reinstall wheel. Push brake pedal for final adjustment. Test forward. Test Backwards. If everything is in the correct place, nothing should pop off. I hope you have a before picture. Haynes manual has good pictures. I own a 2002 Pontiac Montana, but a family member has taken it out of town. My info is from the Haynes manual. I replaced the brake shoes a couple years ago.
Feb 20, 2011 | 2001 Chevrolet Venture
When engaging the hand break it does not keep the car from rolling.
You will need to tighten the adjustments on the rear wheels so as to keep the links without much play .
jack up the car and checck the hand brake cable and the adjustments. While inthe resting postion make the play reduced. Also adjust the brake pads to come closer so that a good action comes in when the hand brake is pulled.
Nov 01, 2010 | Jeep Grand Cherokee Cars & Trucks
Picture or directions for repairing rear drum brake
Brake Shoes Removal & Installation Duo-Servo Type To Remove:
  1. Raise the vehicle and support it safely.
  2. Remove the tire and wheel assembly.
  3. Remove the brake drums.
  4. Using a brake tool, remove the shoe return springs.
  5. Remove the shoe guide.
  6. Remove the hold-down springs and pins.
  7. Remove the actuator lever and pivot.
  8. Remove the lever return spring.
  9. Remove the actuator link, parking brake strut, spring retaining ring.
  10. Remove the parking brake lever and washer.
  11. Remove the shoe assemblies.
  12. Remove the adjuster screw and spring from the shoe assembly.
To Install:
  1. Use brake cleaning fluid to remove dirt from the brake drum. Check the drums for scoring, cracks and for out-of-round; service the drums as necessary.
  2. Check the wheel cylinders by carefully pulling the lower edges of the wheel cylinder boots away from the cylinders. If there is excessive leakage, the inside of the cylinder will drip fluid; repair or replace as necessary.
  3. Check the flange plate, which is located around the axle, for leakage of differential lubricant.
  4. Lightly lubricate the parking brake cable, parking brake lever where it enters the shoe and the backing plate-to-shoe contact points. Use high temperature, waterproof, grease or special brake lube.
  5. Install the parking brake lever into the secondary shoe with the attaching bolt, spring washer, lockwasher, and nut. It is important that the lever move freely before the shoe is attached. Move the assembly and check for proper action.
  6. Lubricate the adjusting screw and make sure it works freely.
  7. Connect the adjuster screw and spring to the bottom portion of both shoes. Ensure the spring does not interfere with the adjuster rotation when installed. The primary (smaller shoe pad area) to the front and secondary shoe (larger shoe pad area) to the rear of the vehicle.
  8. Install the shoe assembly. Ensuring the shoe webs are positioned correctly against the wheel cylinder.
  9. Install the parking brake cable.
  10. Secure the primary shoes with the hold-down pin and spring.
  11. Install the parking brake strut and the strut spring.
  12. Install the actuator lever and pivot, securing the assembly with the hold-down pin and spring. Install the actuator link and spring.
  13. Install the return springs.
  14. Check the operation of the self-adjusting mechanism by moving the actuating lever by hand.
  15. Adjust the brakes and install the drum.
  16. Adjust the parking brake.
  17. Install the tire and wheel assembly.
  18. Lower the vehicle.
Leading-Trailing Type To Remove:
  4. Raise the lever arm of the actuator until the upper end is clear of the slot in the adjuster screw.
  5. Slide the actuator off the adjuster pin. Disconnect the actuator spring from the shoe.
  6. Remove the hold-down spring assemblies and pins.
  7. Pull the bottom ends of the shoes apart and lift the lower return spring over the anchor plate. Allow the shoe ends to come together and remove the spring.
  8. Remove the shoe assembly, along with the upper return spring and the adjusting screw assembly.
  9. Remove the upper return spring and the adjusting screw assembly from the shoes.
  10. Remove the retaining ring, pin, spring washer, and parking brake lever.
Typical rear drum brake assembly (Leading/Trailing type) 93026g52.gif
To Install:
  1. Clean adjuster wheel and the backing plates with a suitable cleaner. Lubricate the backing plate contact points, levers and adjuster with a suitable lubricant.
  2. Assemble the parking lever, spring washer (concave side facing the brake lever), pin, and retaining ring onto the rearward shoe.
  3. Install the adjuster pin in the forward shoe with the pin projecting 0.276 in. (7mm) from the side of the shoe web where the adjuster actuator is installed.
  4. With the brake shoes resting on a flat surface (the shoe with the parking lever to the rear of the vehicle), install the upper return spring.
  5. Install the adjuster screw assembly with the spring clip facing the backing plate.
  6. Place the shoes in position on the backing plate. Do not place the lower shoe webs under the anchor plate.
  7. Install the lower return spring, spread the bottom of the shoes and position the shoe against the backing plate.
  8. Install the hold-down pins and spring assemblies.
  9. Install the adjuster actuator over the end of the adjuster pin so the top leg engages the notch in the adjuster screw.
  10. Install the actuator spring, being careful not to over-stretch it more than 3.27 in. (83mm).
  11. Install the parking brake cable to the lever.
  12. Adjust the parking brake if the shoes will not totally retract.
  13. Install the drum, tire and wheel assembly. Adjust the rear brakes and lower the vehicle.
Aug 17, 2010 | 1999 Chevrolet Suburban
My rare break lights won't switch off when I turn the car off. The garage already charged me over a $100 to reset the electrical system which worked fine, but now (1 month later) it's doing it again. I...
The brake light switch is inexpensive and easy to change. It might not even need replacing, just adjusting. Don'y disconnect your battery.The brake switch is ounder the dash where the brake arm can actuate it,
Jun 23, 2009 | 1996 Ford Contour
Rear brakes scrubbing on 1998 chevy venture van
Removal Procedure Tools RequiredJ 38400
Caution: Keep fingers away from rear brake shoe springs to prevent fingers from being pinched between spring and shoe web or spring and backing plate.
  1. Remove the brake drum. Refer to Brake Drum Replacement
    Notice: Do not over stretch the adjuster spring. Damage can occur if the spring is over stretched.
  3. Use the J 38400 in order remove the adjuster spring (1). Disengage the adjuster spring loop from the tab on the adjuster actuator.
  4. 2.1. Remove the loop end of the adjuster spring from the adjuster actuator. 2.2. Remove the straight end of the adjuster spring from the secondary brake shoe.
  5. Use the J 38400 in order to spread the brake shoes apart.
  6. Remove the adjuster.
Installation Procedure
  1. Use the J 38400 in order to spread the brake shoes apart.
    Important: Ensure that the adjuster (2) engages the brake shoes (4 and 5), the park brake actuator (3), and the adjuster actuator (1) properly.
  3. Install the adjuster.
  5. Install the adjuster spring (1).
  6. 3.1. Install the straight end of the adjuster spring into the secondary brake shoe. 3.2. Install the loop end of the adjuster spring to the adjuster actuator.
  7. Install the brake drum.
Dec 06, 2008 | 1999 Chevrolet Venture
1999 Trans Am Rear Rotor Problem
Look around at posts if you can see any flat head small bolt if not it is rust the only hammer can do this job I saw using a torch too.
Apr 20, 2017 | 1999 Pontiac Firebird
94-98 GMC Sierra C/K 1500 Grille Front Black Chrome GM1200392 12388709 Logo
Top CARPARTSDEPOT Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a CARPARTSDEPOT Vehicle Part and Accessory Expert? Answer questions, earn points and help others
