Question about LG Microwave Ovens
F10 My lg solardom displaying F10
Hello the solardom microwave works, however the convection part is not working.
Hello, you must check the thermostat that is serial linked with the resistance of the convector.
Nov 12, 2017 | Microwave Ovens
Replace door on lg solardom microwave
You need to be carefull. You need a tester to use to check aroud the door after installing door. You should have a qualified tech. check it.
Jul 09, 2016 | LG Microwave Ovens
LG Solardom MP-9483SLA bought 2 yrs ago,
Idont understand the problem pls write the main problem
Sep 15, 2014 | Microwave Ovens
I have an LG solardom microwave and when I want to heat a small amount of liquid, it sparks and the base(not the turntable) of the microwave gets hot.
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
Nov 24, 2013 | LG Microwave Ovens
Lg solardom oven innerdoor replacement
go to www.repairclinic.com or www.appliancepartspros.com and buy it
GOD BLESS YOU
Jul 16, 2012 | Microwave Ovens
Solardom microwave won't stop turning
quite possibly the door switch has failed . take it in to a repair shop , if you can find one locally
Oct 17, 2017 | LG Microwave Ovens
I would like to know if it is possible to change a light bulb in the LG solardom Microwave without calling an electrician?
If your owner's manual doesn't cover lamp replacement, you will have to take the oven apart to do it.
If you don't have your manual, you should be able to download it from here.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's here.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Otherwise, please reply back with your model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | LG Microwave Ovens
Microwave Ovens Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
