Question about Datacard Group Datacard Imagecard Magna Ps Platinum Series Photo Id Badge Card Printer Icm Usb
Cannot print id card - Datacard Group Datacard Imagecard Magna Ps Platinum Series Photo Id Badge Card Printer Icm Usb
ID Settings to print id cards 2 side in one page
it is possible if you follow this procedure; special fonction-2/1-ok.
put the id cards in the glace in the limit of A5; print the first time. and return the id card in the same position and print it aigain the next page. after print the 2 time- ok or end.
Jul 03, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Printers that can print cards as thick as ID for corporate pass
Most companies that have ID cards for their employees prefer the 30 Mil thick CR80 cards. Most have electronics inside the card to allow access to buildings/rooms. If you do not need a thick card printed, then print on a laser printer and place that print inside a card holder. If you do need the thick card but very few and rarely, have a service company provide that service for you.
Dec 11, 2013 | Office Equipment & Supplies
Estudio223.i dont know about ID card print. please help.
Put your ID card, select the ID card template, it will scan, then turn over your ID card and press START, it will scan again, it will output your ID card front & back on the same page.
Sep 24, 2013 | Toshiba EStudio 223 Copier-Stand-Base
Epson t60 wont print on pvc id card
Change your driver to R290 instead of T60. Select your T60 as printer (with an R290 driver) when printing. That would take the CD margin off the PVC card your printing on.
Aug 17, 2012 | Epson TM-T60 Printer
Ribbon cuts or stick over Id surface when printing with Eltron
Turn the heat settings down in the driver. Clean the printer with the available cleaning card. Have the printer serviced.
Jan 21, 2010 | Zebra Eltron P420C Printer
Asure ID Express hangs up in image editing mode, before printing.
The problem turned out to reside in the software itself. The company was aware of it and promptly provided a fix.
Sep 01, 2009 | Synercard Asure ID Express
After ribbon change, can't print ID card background colors - only text is printed
this machine use the thermal pressure to press out ribbon and card,
so you need check
1) your new installed ribbon is original parts or fake one
2) check again your ribbon install at properate possition and move normally when printing, or reinstall it.
3) check if there is any gap which will lost the presure balnace betwwen printer head and pressure base.
just give you some idea, send any question please
hope you fix it.
May 21, 2009 | Datacard Group SP75 Color Card Printer
Print quality with Fargo DTC500 printer
You might go to the print driver settings to change the way the printer prints the card. This can be found in the printing preferences. Go to the device options tab and choose "rotate front 180 degrees". Then print a card. This may fix the problem.
If not, try downloading the latest print driver from www.fargo.com.
Visit our id card printer technical assistance blog at www.safecardid.com/blog.
Sep 24, 2008 | Fargo DTC525 ID Card Printer
Datacard Group Datacard Imagecard Magna Ps Platinum Series Photo Id Badge Card Printer Icm Usb Logo
14 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
k24674
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
