Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Doesn't suck up the soap from the tray while washing
I have an LG Tromm..and of late i dont see the auto suck up of the soap powder from the tray..i have to force feed it into the drum by pouring water into the tray..dunno whats the problem..would need your help
  • 146 Answers
Re: Doesn't suck up the soap from the tray while washing
Try to open your water tap to full or check the filter in the inlet valve or hose. There seems to be a problem with the water pressure entering the machine.
Posted on Oct 31, 2007
0 characters
3 Points
Soap tray has water in after wash
take the tray out, take the white indicator off and clean everything
Sep 06, 2015 | LG WM2688HWM TROMM SteamWasher
I have a lg tromm wm2277hw washer Why does it leak soap down to the front of the washer
in my experience you would be much better off using powdered detergent instead of liquid. it will stop leaking down front and will not leave residue in tub that eventually leads to mold mildew issues.
Jul 18, 2015 | LG Washing Machines
My Tromm washer is leaving residue on my clothes
Make sure you are using the correct soap. (Front load soap powder) Also use a bit less than suggested on the packet. If you are often using cold or low temp wash cycles, dirt and build-up in the machine will be common and come off on your clothes. Use a very hot wash at least once a month to clean it out and stop using fabric softener. It sticks to everything and any dirt in the water gets stuck on and then comes off in later wash cycles.
Sep 25, 2014 | LG WM2688HWM TROMM SteamWasher
Water sits in the pull out soap/bleach drawer?
ur using to much powder.remove drawer from machine and clean away all the excess gunk
Jul 27, 2014 | LG WM2688HWM TROMM SteamWasher
LG tromm washer soap not empty after wash cycle
I have a front load He LG Tromm model 2455 HG. I never use more than 3 tablespoons for any load. This soap is so concentrated that is all you need, which really isn't very much. Too much soap could possibly cause foam to back up. Starting with the basics, could this be your problem?
Feb 19, 2013 | Washing Machines
Mold substance found in rubber ring of a front load washer WM2688HWM
comes from the powder/liquid soap solutions,,sorry,, claen after use allways dry
Jun 21, 2010 | LG WM2688HWM TROMM SteamWasher
Soap doesn't come out of clothes when I wash them on cold.
Use LIQUID soap instead. Powder does NOT dissolve fully in cold water, and may in fact BURN your clothing and ruin the pump and valves with its residue
Jun 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water and soap remains in the soap tray
You need to check for blockage in dispenser, remove completely and thoroughly clean every part of it.
Other possibility is not enough water pressure to take all powder down, check water pressure, filters in hoses if fitted..
Check hose from dispenser to drum for restriction.
Plz rate my solution.
Dec 16, 2008 | LG WM-1485FHD Front Load Washer
You can get your manuals at this site..
and sometimes the laundry drawer sticks..
BTW.. use ONLY HE type detergent and just a few drops ( do NOT fill the cup to the top or you will eventually require replacement hinges, a front panel and the door may leak ..
Hope this helps..
Aug 09, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
212 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
