Question about GMC Denali 700C Road Bike
My bike wont allow me to push it backwards
I can move my bike forward but not backward
  • 2039 Answers
SOURCE: Driverside power seats
check the wire if you hear no sound when you move foward or backward you probably got a bad switch ckeck that out hope it help fixya our post
Posted on Jul 13, 2008
  • 2039 Answers
SOURCE: driver side seat 03 ENVOY
the motor make sound disconnect the the cable that goes to the seat if they move you got something blocking the mouvement of the seat check that out pierre
  • 436 Answers
SOURCE: seat will not move forward or backward...
if motor seemed to slowly get worse over time then there is a great chance that the motor is gone. You will have to unplug the motor and test for power at the motors connector. if the power is good when switch is activated then the motor is dead, but if no power is found then you either have a bad switch or connector or a wiring harness problem. It will not be the fuses since the driver and passenger seats are the same. also one more thing to check is if your vehicle has memory seats then if no power is found at motor, this memory module mounted to seat could be the problem..
Posted on Aug 22, 2009
  • 50 Answers
SOURCE: driver side seat wont slide up only backof the
motor in the seat is bad
Posted on Oct 16, 2009
  • 286 Answers
SOURCE: polarity reversed on power seats
It shouldn't be possible to invert connector plug but what ever you did prior to this situtation is suspect ! Try reversing the plug wiring , It's designed to turn in both directions and will not damage the motor ie back / forward. Good Luck
Posted on Apr 11, 2010
My machines stitches backward instead of forward.
There is a forward and reverse switch you are missing. If you have a pedal it is a matter of pushing the pedal the right direction.
Jul 26, 2014 | Singer Inspiration 4205 Mechanical Sewing...
My saab 900 is stuck and wont go forwards or backwards but the gears aer moving help
1-clutch
2-broken axle or c/v joint
3- transmission failure
Mar 13, 2013 | 1999 Saab 9-5
The neutral lite wont stay on , the foot lever is not allowing it to go to neutral
The neutral light won't stay on because the gearbox isn't in neutral. try rocking the bike backwards and forwards, kick the gears down as many time as you can (at least 6) and then try moving the gear lever up one until the bike moves freely backwards and forwards. Your bike should then start. It would be easier to identify any problems if you let us know the make and model of the bike.
Feb 11, 2013 | Motorcycles
Mower run but wont drive forward or backwards?
check the drive belt also is the release lever pulled the one that allows you to push it
Apr 15, 2012 | Toro Garden
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My bike's suddenly not moving my bike's suddenly not moving backward..... its a Schwinn Suburban Sport 26" for women... bought it an hour ..
It's not supposed to move backward. Walk it forward and rotate the pedal FORWARD to get the chain and all aligned onto a gear. Then evaluate what is wrong.
Aug 14, 2011 | Schwinn Suburban Sport 26 Women's Comfort...
Son's can pedal 12" bike
Yes, something isn't turning freely. It's either the front wheel, the back wheel, or the pedals and chain. Lift the bike off the ground and turn the front wheel by hand. If it doesn't turn very freely, it could be the hand-brake is dragging or the hub bearing is too tight. Try the back wheel in both directions. It should move freely in the forward direction. When rolling it backwards it is normal for the pedals to move too if this bike has a coaster brake (that is the kind of brake that is applied by pushing the pedals backwards.) It the back wheel moves forward freely, but backwards is a problem, then try the pedals by hand with the rear wheel off the ground. If this doesn't turn freely, the pedal crank bearing (a.k.a. bottom bracket) is too tight. Once you have identified the problem take it back to where you got it. It should be easy to fix, or they should replace it.
Jul 28, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
Push forard on the drivers side electric set and
It isn't wired wrong. Mine does the exact same thing, but it didn't used to be backwards and the wiring has never been changed.
Jun 05, 2010 | 2004 Chevrolet Suburban
My front seat will not move forward. It will recline, move up and down but it will not move forward. I've tried reseting the seat positions but nothing seems to work. my seat wont move forward is there a...
You can move the drivers seat back by turning on the power, getting in the seat and position your feet firmly on the fron flor with your back firmly against he seatback, and then engage the switch pushing back - while pushing like hell with your feet. You can actually hear the seat drive shaft turning while the seat moves back. The principle should be the same for moving forward, but pressure would have to be aplide to the back of the seat.
Jun 02, 2009 | 2004 GMC Envoy
GMC Denali 700C Road Bike Logo
Top GMC Cycling Experts
Mike
Arnie Burke
Arnie Burke
Donald Ayers-Marsh
Are you a GMC Cycling Expert? Answer questions, earn points and help others
