Question about Logitech Harmony One Advanced Universal Remote with Color Touch Screen
Rf wireless extender
I have a harmony 1100 and a harmony rf wireless extender to control my devices. When I connect my wireless extender, my devices do not operate. However, when I delete my rf extender from my remote list, my devices work. I need the extender because my devices are in a cabinet. The only thing that I have read is that cordless phones could interfere the the rf signals. Is there any way to use the rf extender, if this is the problem.
4 Suggested Answers
  • 22 Answers
SOURCE: Harmony 1000 not doesn't seem to be communicating with IR extende
The number 1 thing if you have any power issues, unplug power to the RF extender, wait 5 secs, then plug back in. Make sure that the eyeballs are still the right place on the components as well.
Hope this helps,
81
Posted on Feb 14, 2009
  • 22 Answers
SOURCE: cannot interface with harmony rf wireless extender
the One doesn't have rf capabilities, so you can't use an rf extender
Posted on Sep 09, 2009
gdlkn84as528
  • 89 Answers
SOURCE: Harmony 890 Pro will not pair with Xbox360
The RF signal is on the XBOX is used for the controllers only.
When using the Harmony 890 with a 360, you will have to use it as an IR (infrared) device. That is the only way to use a remote with the 360. If you have an extra port on your RF extender, you can place the end on the remote senor on the 360 (located under the eject button).
I set these remotes up weekly, it is a product I recommend to people all the time!
But again, the only way to setup a remote with the 360, is to use the IR port as a standard IR remote. Since the controllers run off RF, the learn function will not work, unless you already have 360 remote control to use to do the learn function.
Hope that offers some insight. This information can also be verifies at Microsoft XBOX 360's FAQ page.
Posted on Oct 21, 2009
Testimonial: "Yes! This was VERY helpful as I did not know the Xbox360 accepted IR commands. However, after configuring my remote, I'm still unable to pair. ideas?"
Logitech Harmony remote having trouble changing the channel
Harmony remotes use IR commands, so you will always have to have line of sight for it to work.
However, if you are using the RF extender, ensure that the device you are using to change channels is assigned to the extender, and that the extender is properly paired.
Feb 20, 2010 | Logitech Harmony Remote Control
Oct 21, 2009 | Logitech Harmony 890 LCD Remote Control
IR doesn't transmit
I suggest that you contact Logitech to see if the remote is replaceable. are you out of your warranty period? (This is 90 Day free support and 1 year for the Warranty period) Also, when contacting them, have this information ready:
The PID of the remote:
*found under the battery.
The P/N of the remote:
*also found under the battery.
The PID of the RF Wireless Extender:
The P/N of the RF Wireless Extender:
Full Name:
Phone number:
Street:
City/Town:
Country:
Zip/Postal Code:
also let them know that you have already updated the firmware.
Oct 17, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
What is a ?????
The RF extender is a add-on device that communicates with the Harmony 1000 remote. You would actually hook up IR eyeballs to your equipment and then plug them into the RF extender. This allows you to have your equipment in a cabinet or closet and have the door shut. The Harmony 1000 sends RF signals to the RF extender and the RF extender sends that signal to the components. This way you don't have to point at the components to control their operation.
Hope this helps, if it did please indicate with vote.
81
Feb 14, 2009 | Logitech Harmony 1000 LCD Touchscreen...
Hope this helps,
81
Feb 10, 2009 | Logitech Harmony 1000 LCD Touchscreen...
I just bought a Harmony wireless extender but cannot get it to work. Do I have to also purchase a Harmony remote control or cannot it be used with any standard remote?
I would suspect that it would need to be used along side a Harmony remote. Get one they are great, you will not be disappointed. TigerDirect has some refurbished Harmony 720s, that's the one I have, it's the best value.
Jan 24, 2009 | Logitech Harmony RF Extender IDE / EIDE,...
Logitech harmony remote 1000 not operating CBus lighting
Is there an IR receiver (or if using the RF extender, IR eyeballs connected to device and the RF extender) that you are pointing at to control the CBus lighting? If not, there is no way to control it. The Harmony 1000 will only communicate with the RF extender through Zwave, so you can't communicate with other Zwave devices, like you can with the Harmony 890 for instance.
Hope this helps,
81
Dec 08, 2008 | Logitech Harmony 1000 LCD Touchscreen...
Cannot interface with harmony rf wireless extender
Jun 08, 2008 | Logitech Harmony One Advanced Universal...
Pull the battery out and re-insert it, also update the remote firmware
Aug 12, 2007 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
110 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
